Author: uwe Date: 2009-05-18 00:58:41 +0200 (Mon, 18 May 2009) New Revision: 530
Added: trunk/satasii.c Removed: trunk/sata_sii.c Modified: trunk/Makefile Log: Rename sata_sii.c to satasii.c for consistency (trivial).
Signed-off-by: Uwe Hermann uwe@hermann-uwe.de Acked-by: Uwe Hermann uwe@hermann-uwe.de
Modified: trunk/Makefile =================================================================== --- trunk/Makefile 2009-05-17 22:57:34 UTC (rev 529) +++ trunk/Makefile 2009-05-17 22:58:41 UTC (rev 530) @@ -33,7 +33,7 @@ sst49lfxxxc.o sst_fwhub.o layout.o cbtable.o flashchips.o physmap.o \ flashrom.o w39v080fa.o sharplhf00l04.o w29ee011.o spi.o it87spi.o \ ichspi.o w39v040c.o sb600spi.o wbsio_spi.o m29f002.o internal.o \ - dummyflasher.o pcidev.o nic3com.o sata_sii.o + dummyflasher.o pcidev.o nic3com.o satasii.o
all: pciutils dep $(PROGRAM)
Deleted: trunk/sata_sii.c =================================================================== --- trunk/sata_sii.c 2009-05-17 22:57:34 UTC (rev 529) +++ trunk/sata_sii.c 2009-05-17 22:58:41 UTC (rev 530) @@ -1,124 +0,0 @@ -/* - * This file is part of the flashrom project. - * - * Copyright (C) 2009 Rudolf Marek r.marek@assembler.cz - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; either version 2 of the License, or - * (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -/* Datasheets can be found on http://www.siliconimage.com. Great thanks! */ - -#include <stdlib.h> -#include <string.h> -#include <fcntl.h> -#include <sys/types.h> -#include <sys/stat.h> -#include <errno.h> -#include "flash.h" - -#define PCI_VENDOR_ID_SII 0x1095 - -uint8_t *sii_bar; -uint16_t id; - -struct pcidev_status satas_sii[] = { - {0x1095, 0x0680, PCI_NT, "Silicon Image", "PCI0680 Ultra ATA-133 Host Controller"}, - {0x1095, 0x3114, PCI_OK, "Silicon Image", "SiI 3114 [SATALink/SATARaid] Serial ATA Controller"}, - {0x1095, 0x3124, PCI_NT, "Silicon Image", "SiI 3124 PCI-X Serial ATA Controller"}, - {0x1095, 0x3132, PCI_OK, "Silicon Image", "SiI 3132 Serial ATA Raid II Controller"}, - {0x1095, 0x3512, PCI_NT, "Silicon Image", "SiI 3512 [SATALink/SATARaid] Serial ATA Controller"}, - - {}, -}; - -int satasii_init(void) -{ - uint32_t addr; - uint16_t reg_offset; - - get_io_perms(); - - pcidev_init(PCI_VENDOR_ID_SII, satas_sii); - id = pcidev_dev->device_id; - - if ((id == 0x3132) || (id == 0x3124)) { - addr = pci_read_long(pcidev_dev, PCI_BASE_ADDRESS_0) & ~0x07; - reg_offset = 0x70; - } else { - addr = pci_read_long(pcidev_dev, PCI_BASE_ADDRESS_5) & ~0x07; - reg_offset = 0x50; - } - - sii_bar = physmap("SATA SIL registers", addr, 0x100) + reg_offset; - - /* Check if ROM cycle are OK. */ - if (!(mmio_readl(sii_bar)) & (1 << 26)) - printf("Warning: Flash seems unconnected\n"); - - return 0; -} - -int satasii_shutdown(void) -{ - free(pcidev_bdf); - pci_cleanup(pacc); -#if defined(__FreeBSD__) || defined(__DragonFly__) - close(io_fd); -#endif - return 0; -} - -void *satasii_map(const char *descr, unsigned long phys_addr, size_t len) -{ - return 0; -} - -void satasii_unmap(void *virt_addr, size_t len) -{ -} - -void satasii_chip_writeb(uint8_t val, chipaddr addr) -{ - uint32_t ctrl_reg, data_reg; - - while ((ctrl_reg = mmio_readl(sii_bar)) & (1 << 25)) ; - - /* Mask out unused/reserved bits, set writes and start transaction. */ - ctrl_reg &= 0xfcf80000; - ctrl_reg |= (1 << 25) | (0 << 24) | ((uint32_t) addr & 0x7ffff); - - data_reg = (mmio_readl((sii_bar + 4)) & ~0xff) | val; - mmio_writel(data_reg, (sii_bar + 4)); - mmio_writel(ctrl_reg, sii_bar); - - while (mmio_readl(sii_bar) & (1 << 25)) ; -} - -uint8_t satasii_chip_readb(const chipaddr addr) -{ - uint32_t ctrl_reg; - - while ((ctrl_reg = mmio_readl(sii_bar)) & (1 << 25)) ; - - /* Mask out unused/reserved bits, set reads and start transaction. */ - ctrl_reg &= 0xfcf80000; - ctrl_reg |= (1 << 25) | (1 << 24) | ((uint32_t) addr & 0x7ffff); - - mmio_writel(ctrl_reg, sii_bar); - - while (mmio_readl(sii_bar) & (1 << 25)) ; - - return (mmio_readl(sii_bar + 4)) & 0xff; -}
Copied: trunk/satasii.c (from rev 529, trunk/sata_sii.c) =================================================================== --- trunk/satasii.c (rev 0) +++ trunk/satasii.c 2009-05-17 22:58:41 UTC (rev 530) @@ -0,0 +1,124 @@ +/* + * This file is part of the flashrom project. + * + * Copyright (C) 2009 Rudolf Marek r.marek@assembler.cz + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +/* Datasheets can be found on http://www.siliconimage.com. Great thanks! */ + +#include <stdlib.h> +#include <string.h> +#include <fcntl.h> +#include <sys/types.h> +#include <sys/stat.h> +#include <errno.h> +#include "flash.h" + +#define PCI_VENDOR_ID_SII 0x1095 + +uint8_t *sii_bar; +uint16_t id; + +struct pcidev_status satas_sii[] = { + {0x1095, 0x0680, PCI_NT, "Silicon Image", "PCI0680 Ultra ATA-133 Host Controller"}, + {0x1095, 0x3114, PCI_OK, "Silicon Image", "SiI 3114 [SATALink/SATARaid] Serial ATA Controller"}, + {0x1095, 0x3124, PCI_NT, "Silicon Image", "SiI 3124 PCI-X Serial ATA Controller"}, + {0x1095, 0x3132, PCI_OK, "Silicon Image", "SiI 3132 Serial ATA Raid II Controller"}, + {0x1095, 0x3512, PCI_NT, "Silicon Image", "SiI 3512 [SATALink/SATARaid] Serial ATA Controller"}, + + {}, +}; + +int satasii_init(void) +{ + uint32_t addr; + uint16_t reg_offset; + + get_io_perms(); + + pcidev_init(PCI_VENDOR_ID_SII, satas_sii); + id = pcidev_dev->device_id; + + if ((id == 0x3132) || (id == 0x3124)) { + addr = pci_read_long(pcidev_dev, PCI_BASE_ADDRESS_0) & ~0x07; + reg_offset = 0x70; + } else { + addr = pci_read_long(pcidev_dev, PCI_BASE_ADDRESS_5) & ~0x07; + reg_offset = 0x50; + } + + sii_bar = physmap("SATA SIL registers", addr, 0x100) + reg_offset; + + /* Check if ROM cycle are OK. */ + if (!(mmio_readl(sii_bar)) & (1 << 26)) + printf("Warning: Flash seems unconnected\n"); + + return 0; +} + +int satasii_shutdown(void) +{ + free(pcidev_bdf); + pci_cleanup(pacc); +#if defined(__FreeBSD__) || defined(__DragonFly__) + close(io_fd); +#endif + return 0; +} + +void *satasii_map(const char *descr, unsigned long phys_addr, size_t len) +{ + return 0; +} + +void satasii_unmap(void *virt_addr, size_t len) +{ +} + +void satasii_chip_writeb(uint8_t val, chipaddr addr) +{ + uint32_t ctrl_reg, data_reg; + + while ((ctrl_reg = mmio_readl(sii_bar)) & (1 << 25)) ; + + /* Mask out unused/reserved bits, set writes and start transaction. */ + ctrl_reg &= 0xfcf80000; + ctrl_reg |= (1 << 25) | (0 << 24) | ((uint32_t) addr & 0x7ffff); + + data_reg = (mmio_readl((sii_bar + 4)) & ~0xff) | val; + mmio_writel(data_reg, (sii_bar + 4)); + mmio_writel(ctrl_reg, sii_bar); + + while (mmio_readl(sii_bar) & (1 << 25)) ; +} + +uint8_t satasii_chip_readb(const chipaddr addr) +{ + uint32_t ctrl_reg; + + while ((ctrl_reg = mmio_readl(sii_bar)) & (1 << 25)) ; + + /* Mask out unused/reserved bits, set reads and start transaction. */ + ctrl_reg &= 0xfcf80000; + ctrl_reg |= (1 << 25) | (1 << 24) | ((uint32_t) addr & 0x7ffff); + + mmio_writel(ctrl_reg, sii_bar); + + while (mmio_readl(sii_bar) & (1 << 25)) ; + + return (mmio_readl(sii_bar + 4)) & 0xff; +}
Property changes on: trunk/satasii.c ___________________________________________________________________ Added: svn:mergeinfo +
