the following patch was just integrated into master: commit 069795a94716cdc5d5dbeed81d491004c3e6a58e Author: Jens Rottmann JRottmann@LiPPERTembedded.de Date: Mon Mar 4 21:13:57 2013 +0100
FrontRunner/Toucan-AF: drop unnecessary compile time CPU model selection
The first reason for selecting the CPU model at compile time was a multi-second pause if booting a single core Fusion T40R with MAX_CPUS=2. Recent tests show the pause has disappeared, someone must have fixed it.
The second reason was me not knowing how to make a single vgabios image work with two different PCI IDs. Many thanks to Martin Roth for educating me! Quote:
"The way to make coreboot use the same vbios for different video device IDs is through the map_oprom_vendev function. In family 14 it's in northbridge/amd/agesa/family14/amdfam14_conf.c You would name your video bios 1002,9802 in the config and all the other device/vendor IDs for the family 14h processors will fall through the initial check for the video bios and will get remapped to use that vbios. This only works if you're initializing the vbios inside coreboot. I don't know if you're using SeaBios as a payload, but if you are you can add the vbios to cbfs as vgaroms/vbios.rom and the rom will always be initialized."
I'd like to add the vgabios is added as type 'optionrom' when Coreboot make adds it, however to work with SeaBios it has to be added manually with cbfstool and with type 'raw', or it will hang.
Change-Id: I8190d0c3202a60dfccb77dde232f9ba7ce5ce318 Signed-off-by: Jens Rottmann JRottmann@LiPPERTembedded.de Reviewed-on: http://review.coreboot.org/2584 Tested-by: build bot (Jenkins) Reviewed-by: Stefan Reinauer stefan.reinauer@coreboot.org
Build-Tested: build bot (Jenkins) at Mon Mar 4 22:14:28 2013, giving +1 Reviewed-By: Stefan Reinauer stefan.reinauer@coreboot.org at Mon Mar 4 22:54:13 2013, giving +2 See http://review.coreboot.org/2584 for details.
-gerrit
