Dear coreboot readers!
This is the automatic build system of coreboot.
The developer "stepan" checked in revision 4846 to the coreboot repository. This caused the following changes:
Change Log: hook up missing x86 SMM into Makefile
Signed-off-by: Stefan Reinauer stepan@coresystems.de Acked-by: Stefan Reinauer stepan@coresystems.de
Build Log: Compilation of a-trend:atc-6220 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=atc-6220&am... Compilation of a-trend:atc-6240 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=atc-6240&am... Compilation of abit:be6-ii_v2_0 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=be6-ii_v2_0... Compilation of advantech:pcm-5820 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=pcm-5820&am... Compilation of amd:db800 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=db800&v... Compilation of amd:dbm690t is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=dbm690t&... Compilation of amd:norwich is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=norwich&... Compilation of amd:pistachio is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=pistachio&a... Compilation of amd:rumba is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=rumba&v... Compilation of amd:serengeti_cheetah is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=serengeti_c... Compilation of amd:serengeti_cheetah_fam10 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=serengeti_c... Compilation of arima:hdama is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=hdama&v... Compilation of artecgroup:dbe61 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=dbe61&v... Compilation of asi:mb_5blgp is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=mb_5blgp&am... Compilation of asi:mb_5blmp is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=mb_5blmp&am... Compilation of asus:a8n_e is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=a8n_e&v... Compilation of asus:a8v-e_se is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=a8v-e_se&am... Compilation of asus:m2v-mx_se is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=m2v-mx_se&a... Compilation of asus:mew-am is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=mew-am&... Compilation of asus:mew-vm is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=mew-vm&... Compilation of asus:p2b is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=p2b&ven... Compilation of asus:p2b-d is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=p2b-d&v... Compilation of asus:p2b-ds is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=p2b-ds&... Compilation of asus:p2b-f is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=p2b-f&v... Compilation of asus:p3b-f is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=p3b-f&v... Compilation of axus:tc320 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=tc320&v... Compilation of azza:pt-6ibd is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=pt-6ibd&... Compilation of bcom:winnet100 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=winnet100&a... Compilation of bcom:winnetp680 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=winnetp680&... Compilation of biostar:m6tba is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=m6tba&v... Compilation of broadcom:blast is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=blast&v... Compilation of compaq:deskpro_en_sff_p600 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=deskpro_en_... Compilation of dell:s1850 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=s1850&v... Compilation of digitallogic:adl855pc is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=adl855pc&am... Compilation of digitallogic:msm586seg is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=msm586seg&a... Compilation of digitallogic:msm800sev is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=msm800sev&a... Compilation of eaglelion:5bcm is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=5bcm&ve... Compilation of emulation:qemu-x86 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=qemu-x86&am... Compilation of gigabyte:ga-6bxc is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=ga-6bxc&... Compilation of gigabyte:ga_2761gxdk is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=ga_2761gxdk... Compilation of gigabyte:m57sli is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=m57sli&... Compilation of hp:dl145_g3 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=dl145_g3&am... Compilation of hp:e_vectra_p2706t is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=e_vectra_p2... Compilation of ibm:e325 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=e325&ve... Compilation of ibm:e326 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=e326&ve... Compilation of iei:juki-511p is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=juki-511p&a... Compilation of iei:nova4899r is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=nova4899r&a... Compilation of iei:pcisa-lx-800-r10 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=pcisa-lx-80... Compilation of intel:eagleheights is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=eagleheight... Compilation of intel:jarrell is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=jarrell&... Compilation of intel:mtarvon is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=mtarvon&... Compilation of intel:truxton is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=truxton&... Compilation of intel:xe7501devkit is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=xe7501devki... Compilation of iwill:dk8_htx is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=dk8_htx&... Compilation of iwill:dk8s2 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=dk8s2&v... Compilation of iwill:dk8x is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=dk8x&ve... Compilation of jetway:j7f24 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=j7f24&v... Compilation of kontron:986lcd-m is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=986lcd-m&am... Compilation of kontron:kt690 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=kt690&v... Compilation of lippert:frontrunner is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=frontrunner... Compilation of lippert:roadrunner-lx is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=roadrunner-... Compilation of lippert:spacerunner-lx is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=spacerunner... Compilation of mitac:6513wu is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=6513wu&... Compilation of msi:ms6119 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=ms6119&... Compilation of msi:ms6147 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=ms6147&... Compilation of msi:ms6156 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=ms6156&... Compilation of msi:ms6178 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=ms6178&... Compilation of msi:ms7135 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=ms7135&... Compilation of msi:ms7260 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=ms7260&... Compilation of msi:ms9185 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=ms9185&... Compilation of msi:ms9282 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=ms9282&... Compilation of nec:powermate2000 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=powermate20... Compilation of newisys:khepri is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=khepri&... Compilation of nvidia:l1_2pvv is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=l1_2pvv&... Compilation of olpc:btest is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=btest&v... Compilation of olpc:rev_a is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=rev_a&v... Compilation of pcengines:alix1c is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=alix1c&... Compilation of rca:rm4100 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=rm4100&... Compilation of soyo:sy-6ba-plus-iii is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=sy-6ba-plus... Compilation of sunw:ultra40 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=ultra40&... Compilation of supermicro:h8dme is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=h8dme&v... Compilation of supermicro:h8dmr is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=h8dmr&v... Compilation of supermicro:h8dmr_fam10 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=h8dmr_fam10... Compilation of supermicro:x6dai_g is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=x6dai_g&... Compilation of supermicro:x6dhe_g is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=x6dhe_g&... Compilation of supermicro:x6dhe_g2 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=x6dhe_g2&am... Compilation of supermicro:x6dhr_ig is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=x6dhr_ig&am... Compilation of supermicro:x6dhr_ig2 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=x6dhr_ig2&a... Compilation of technexion:tim5690 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=tim5690&... Compilation of technexion:tim8690 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=tim8690&... Compilation of technologic:ts5300 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=ts5300&... Compilation of televideo:tc7020 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=tc7020&... Compilation of thomson:ip1000 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=ip1000&... Compilation of tyan:s1846 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=s1846&v... Compilation of tyan:s2735 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=s2735&v... Compilation of tyan:s2850 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=s2850&v... Compilation of tyan:s2875 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=s2875&v... Compilation of tyan:s2880 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=s2880&v... Compilation of tyan:s2881 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=s2881&v... Compilation of tyan:s2882 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=s2882&v... Compilation of tyan:s2885 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=s2885&v... Compilation of tyan:s2891 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=s2891&v... Compilation of tyan:s2892 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=s2892&v... Compilation of tyan:s2895 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=s2895&v... Compilation of tyan:s2912 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=s2912&v... Compilation of tyan:s2912_fam10 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=s2912_fam10... Compilation of tyan:s4880 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=s4880&v... Compilation of tyan:s4882 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=s4882&v... Compilation of via:epia is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=epia&ve... Compilation of via:epia-cn is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=epia-cn&... Compilation of via:epia-m is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=epia-m&... Compilation of via:epia-m700 is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=epia-m700&a... Compilation of via:epia-n is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=epia-n&... Compilation of via:pc2500e is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=pc2500e&... Compilation of via:vt8454c is still broken See the error log at http://qa.coreboot.org/log_buildbrd.php?revision=4846&device=vt8454c&...
If something broke during this checkin please be a pain in stepan's neck until the issue is fixed.
If this issue is not fixed within 24h the revision should be backed out.
Best regards, coreboot automatic build system
