Jamie Chen has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/39448 )
Change subject: soc/intel/cannonlake: Add usb configs for Usb3.1 Gen2 strength ......................................................................
Add usb configs for tuning USB3.1 Gen2 strength.
BUG=b:150515720 BRANCH=none TEST=build successful in puff
Signed-off-by: Jamie Chen jamie.chen@intel.com Change-Id: Id4860665619095139c329565d433d9eb495cac02 --- M src/soc/intel/cannonlake/fsp_params.c M src/soc/intel/cannonlake/include/soc/usb.h 2 files changed, 80 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/48/39448/1
diff --git a/src/soc/intel/cannonlake/fsp_params.c b/src/soc/intel/cannonlake/fsp_params.c index 80918f1..a6971a1 100644 --- a/src/soc/intel/cannonlake/fsp_params.c +++ b/src/soc/intel/cannonlake/fsp_params.c @@ -290,6 +290,36 @@ params->Usb3HsioTxDownscaleAmp[i] = config->usb3_ports[i].tx_downscale_amp; } +#if CONFIG(SOC_INTEL_COMETLAKE) + if (config->usb3_ports[i].gen2_tx_rate0_uniq_tran_enable) { + params->Usb3HsioTxRate0UniqTranEnable[i] = 1; + params->Usb3HsioTxRate0UniqTran[i] = + config->usb3_ports[i].gen2_tx_rate0_uniq_tran; + } + if (config->usb3_ports[i].gen2_tx_rate1_uniq_tran_enable) { + params->Usb3HsioTxRate1UniqTranEnable[i] = 1; + params->Usb3HsioTxRate1UniqTran[i] = + config->usb3_ports[i].gen2_tx_rate1_uniq_tran; + } + if (config->usb3_ports[i].gen2_tx_rate2_uniq_tran_enable) { + params->Usb3HsioTxRate2UniqTranEnable[i] = 1; + params->Usb3HsioTxRate2UniqTran[i] = + config->usb3_ports[i].gen2_tx_rate2_uniq_tran; + } + if (config->usb3_ports[i].gen2_tx_rate3_uniq_tran_enable) { + params->Usb3HsioTxRate3UniqTranEnable[i] = 1; + params->Usb3HsioTxRate3UniqTran[i] = + config->usb3_ports[i].gen2_tx_rate3_uniq_tran; + } +#endif + if (config->usb3_ports[i].gen2_rx_tuning_enable) { + params->PchUsbHsioRxTuningEnable[i] = + config->usb3_ports[i].gen2_rx_tuning_enable; + params->PchUsbHsioRxTuningParameters[i] = + config->usb3_ports[i].gen2_rx_tuning_params; + params->PchUsbHsioFilterSel[i] = + config->usb3_ports[i].gen2_rx_filter_sel; + } }
/* Enable xDCI controller if enabled in devicetree and allowed */ diff --git a/src/soc/intel/cannonlake/include/soc/usb.h b/src/soc/intel/cannonlake/include/soc/usb.h index 722a202..e321df5 100644 --- a/src/soc/intel/cannonlake/include/soc/usb.h +++ b/src/soc/intel/cannonlake/include/soc/usb.h @@ -133,6 +133,17 @@ uint8_t ocpin; uint8_t tx_de_emp; uint8_t tx_downscale_amp; + uint8_t gen2_tx_rate0_uniq_tran_enable; + uint8_t gen2_tx_rate0_uniq_tran; + uint8_t gen2_tx_rate1_uniq_tran_enable; + uint8_t gen2_tx_rate1_uniq_tran; + uint8_t gen2_tx_rate2_uniq_tran_enable; + uint8_t gen2_tx_rate2_uniq_tran; + uint8_t gen2_tx_rate3_uniq_tran_enable; + uint8_t gen2_tx_rate3_uniq_tran; + uint8_t gen2_rx_tuning_enable; + uint8_t gen2_rx_tuning_params; + uint8_t gen2_rx_filter_sel; };
#define USB3_PORT_EMPTY { \ @@ -140,6 +151,17 @@ .ocpin = OC_SKIP, \ .tx_de_emp = 0x00, \ .tx_downscale_amp = 0x00, \ + .gen2_tx_rate0_uniq_tran_enable = 0, \ + .gen2_tx_rate0_uniq_tran = 0x00, \ + .gen2_tx_rate1_uniq_tran_enable = 0, \ + .gen2_tx_rate1_uniq_tran = 0x00, \ + .gen2_tx_rate2_uniq_tran_enable = 0, \ + .gen2_tx_rate2_uniq_tran = 0x00, \ + .gen2_tx_rate3_uniq_tran_enable = 0, \ + .gen2_tx_rate3_uniq_tran = 0x00, \ + .gen2_rx_tuning_enable = 0, \ + .gen2_rx_tuning_params = 0x00, \ + .gen2_rx_filter_sel = 0x00, \ }
#define USB3_PORT_DEFAULT(pin) { \ @@ -147,6 +169,34 @@ .ocpin = (pin), \ .tx_de_emp = 0x0, \ .tx_downscale_amp = 0x00, \ + .gen2_tx_rate0_uniq_tran_enable = 0, \ + .gen2_tx_rate0_uniq_tran = 0x00, \ + .gen2_tx_rate1_uniq_tran_enable = 0, \ + .gen2_tx_rate1_uniq_tran = 0x00, \ + .gen2_tx_rate2_uniq_tran_enable = 0, \ + .gen2_tx_rate2_uniq_tran = 0x00, \ + .gen2_tx_rate3_uniq_tran_enable = 0, \ + .gen2_tx_rate3_uniq_tran = 0x00, \ + .gen2_rx_tuning_enable = 0, \ + .gen2_rx_tuning_params = 0x00, \ + .gen2_rx_filter_sel = 0x00, \ }
+#define USB3_PORT_GEN2_DEFAULT(pin) { \ + .enable = 1, \ + .ocpin = (pin), \ + .tx_de_emp = 0x0, \ + .tx_downscale_amp = 0x00, \ + .gen2_tx_rate0_uniq_tran_enable = 0, \ + .gen2_tx_rate0_uniq_tran = 0x00, \ + .gen2_tx_rate1_uniq_tran_enable = 0, \ + .gen2_tx_rate1_uniq_tran = 0x00, \ + .gen2_tx_rate2_uniq_tran_enable = 1, \ + .gen2_tx_rate2_uniq_tran = 0x4C, \ + .gen2_tx_rate3_uniq_tran_enable = 0, \ + .gen2_tx_rate3_uniq_tran = 0x00, \ + .gen2_rx_tuning_enable = 0x0F, \ + .gen2_rx_tuning_params = 0x15, \ + .gen2_rx_filter_sel = 0x44, \ +} #endif
Kane Chen has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/39448 )
Patch Set 1:
(2 comments)
https://review.coreboot.org/c/coreboot/+/39448/1//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/39448/1//COMMIT_MSG@7 PS1, Line 7: strength Add configs for USB 3.1 Gen2 EV settings
https://review.coreboot.org/c/coreboot/+/39448/1//COMMIT_MSG@9 PS1, Line 9: Add usb configs for tuning USB3.1 Gen2 strength. Add configs for USB 3.1 Gen2 EV settings so that people can set the EV settings per board in device tree.
Patch Set 1:
https://review.coreboot.org/c/coreboot/+/39448/1//COMMIT_MSG@13 PS1, Line 13: successful in puff did you verify the settings are set accordingly by FSP log?
Hello build bot (Jenkins), Patrick Rudolph,
Change subject: soc/intel/cannonlake: Add configs for USB 3.1 Gen2 EV settings ......................................................................
BUG=b:150515720 BRANCH=none TEST=build coreboot and fsp with enabled fw_debug. Flashed to puff and checked the log. All usb configs were set correctly.
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/48/39448/2
Jamie Chen has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/39448 )
Patch Set 2:
(3 comments)
Add configs for USB 3. […]
Done
Done
Yes, I verified the fsp log. All usb settings are correct.
Signed-off-by: Jamie Chen jamie.chen@intel.com Change-Id: Id4860665619095139c329565d433d9eb495cac02 --- M src/soc/intel/cannonlake/fsp_params.c M src/soc/intel/cannonlake/include/soc/usb.h 2 files changed, 81 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/48/39448/3
Edward O'Callaghan has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/39448 )
Patch Set 4: Code-Review+2
Edward O'Callaghan has submitted this change. ( https://review.coreboot.org/c/coreboot/+/39448 )
Signed-off-by: Jamie Chen jamie.chen@intel.com Change-Id: Id4860665619095139c329565d433d9eb495cac02 Reviewed-on: https://review.coreboot.org/c/coreboot/+/39448 Reviewed-by: Edward O'Callaghan quasisec@chromium.org Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/soc/intel/cannonlake/fsp_params.c M src/soc/intel/cannonlake/include/soc/usb.h 2 files changed, 81 insertions(+), 0 deletions(-)
Approvals: build bot (Jenkins): Verified Edward O'Callaghan: Looks good to me, approved
diff --git a/src/soc/intel/cannonlake/fsp_params.c b/src/soc/intel/cannonlake/fsp_params.c index 3794ffd..8f8c816 100644 --- a/src/soc/intel/cannonlake/fsp_params.c +++ b/src/soc/intel/cannonlake/fsp_params.c @@ -404,6 +404,36 @@ params->Usb3HsioTxDownscaleAmp[i] = config->usb3_ports[i].tx_downscale_amp; } +#if CONFIG(SOC_INTEL_COMETLAKE) + if (config->usb3_ports[i].gen2_tx_rate0_uniq_tran_enable) { + params->Usb3HsioTxRate0UniqTranEnable[i] = 1; + params->Usb3HsioTxRate0UniqTran[i] = + config->usb3_ports[i].gen2_tx_rate0_uniq_tran; + } + if (config->usb3_ports[i].gen2_tx_rate1_uniq_tran_enable) { + params->Usb3HsioTxRate1UniqTranEnable[i] = 1; + params->Usb3HsioTxRate1UniqTran[i] = + config->usb3_ports[i].gen2_tx_rate1_uniq_tran; + } + if (config->usb3_ports[i].gen2_tx_rate2_uniq_tran_enable) { + params->Usb3HsioTxRate2UniqTranEnable[i] = 1; + params->Usb3HsioTxRate2UniqTran[i] = + config->usb3_ports[i].gen2_tx_rate2_uniq_tran; + } + if (config->usb3_ports[i].gen2_tx_rate3_uniq_tran_enable) { + params->Usb3HsioTxRate3UniqTranEnable[i] = 1; + params->Usb3HsioTxRate3UniqTran[i] = + config->usb3_ports[i].gen2_tx_rate3_uniq_tran; + } +#endif + if (config->usb3_ports[i].gen2_rx_tuning_enable) { + params->PchUsbHsioRxTuningEnable[i] = + config->usb3_ports[i].gen2_rx_tuning_enable; + params->PchUsbHsioRxTuningParameters[i] = + config->usb3_ports[i].gen2_rx_tuning_params; + params->PchUsbHsioFilterSel[i] = + config->usb3_ports[i].gen2_rx_filter_sel; + } }
/* Enable xDCI controller if enabled in devicetree and allowed */ diff --git a/src/soc/intel/cannonlake/include/soc/usb.h b/src/soc/intel/cannonlake/include/soc/usb.h index ac5776c..ce87b4a 100644 --- a/src/soc/intel/cannonlake/include/soc/usb.h +++ b/src/soc/intel/cannonlake/include/soc/usb.h @@ -120,6 +120,17 @@ uint8_t ocpin; uint8_t tx_de_emp; uint8_t tx_downscale_amp; + uint8_t gen2_tx_rate0_uniq_tran_enable; + uint8_t gen2_tx_rate0_uniq_tran; + uint8_t gen2_tx_rate1_uniq_tran_enable; + uint8_t gen2_tx_rate1_uniq_tran; + uint8_t gen2_tx_rate2_uniq_tran_enable; + uint8_t gen2_tx_rate2_uniq_tran; + uint8_t gen2_tx_rate3_uniq_tran_enable; + uint8_t gen2_tx_rate3_uniq_tran; + uint8_t gen2_rx_tuning_enable; + uint8_t gen2_rx_tuning_params; + uint8_t gen2_rx_filter_sel; };
#define USB3_PORT_EMPTY { \ @@ -127,6 +138,17 @@ .ocpin = OC_SKIP, \ .tx_de_emp = 0x00, \ .tx_downscale_amp = 0x00, \ + .gen2_tx_rate0_uniq_tran_enable = 0, \ + .gen2_tx_rate0_uniq_tran = 0x00, \ + .gen2_tx_rate1_uniq_tran_enable = 0, \ + .gen2_tx_rate1_uniq_tran = 0x00, \ + .gen2_tx_rate2_uniq_tran_enable = 0, \ + .gen2_tx_rate2_uniq_tran = 0x00, \ + .gen2_tx_rate3_uniq_tran_enable = 0, \ + .gen2_tx_rate3_uniq_tran = 0x00, \ + .gen2_rx_tuning_enable = 0, \ + .gen2_rx_tuning_params = 0x00, \ + .gen2_rx_filter_sel = 0x00, \ }
#define USB3_PORT_DEFAULT(pin) { \ @@ -134,6 +156,35 @@ .ocpin = (pin), \ .tx_de_emp = 0x0, \ .tx_downscale_amp = 0x00, \ + .gen2_tx_rate0_uniq_tran_enable = 0, \ + .gen2_tx_rate0_uniq_tran = 0x00, \ + .gen2_tx_rate1_uniq_tran_enable = 0, \ + .gen2_tx_rate1_uniq_tran = 0x00, \ + .gen2_tx_rate2_uniq_tran_enable = 0, \ + .gen2_tx_rate2_uniq_tran = 0x00, \ + .gen2_tx_rate3_uniq_tran_enable = 0, \ + .gen2_tx_rate3_uniq_tran = 0x00, \ + .gen2_rx_tuning_enable = 0, \ + .gen2_rx_tuning_params = 0x00, \ + .gen2_rx_filter_sel = 0x00, \ +} + +#define USB3_PORT_GEN2_DEFAULT(pin) { \ + .enable = 1, \ + .ocpin = (pin), \ + .tx_de_emp = 0x0, \ + .tx_downscale_amp = 0x00, \ + .gen2_tx_rate0_uniq_tran_enable = 0, \ + .gen2_tx_rate0_uniq_tran = 0x00, \ + .gen2_tx_rate1_uniq_tran_enable = 0, \ + .gen2_tx_rate1_uniq_tran = 0x00, \ + .gen2_tx_rate2_uniq_tran_enable = 1, \ + .gen2_tx_rate2_uniq_tran = 0x4C, \ + .gen2_tx_rate3_uniq_tran_enable = 0, \ + .gen2_tx_rate3_uniq_tran = 0x00, \ + .gen2_rx_tuning_enable = 0x0F, \ + .gen2_rx_tuning_params = 0x15, \ + .gen2_rx_filter_sel = 0x44, \ }
