Felix Singer has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/40229 )
Change subject: sb/intel/bd82x6x/sata: Don't write RO register ......................................................................
Change-Id: Ide5f101b2e5bda84f3c2ff8c8ca636b8233bb948 Signed-off-by: Felix Singer felix.singer@secunet.com --- M src/southbridge/intel/bd82x6x/sata.c 1 file changed, 0 insertions(+), 4 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/29/40229/1
diff --git a/src/southbridge/intel/bd82x6x/sata.c b/src/southbridge/intel/bd82x6x/sata.c index e04f3ba..5bf6a2b 100644 --- a/src/southbridge/intel/bd82x6x/sata.c +++ b/src/southbridge/intel/bd82x6x/sata.c @@ -131,10 +131,6 @@ */ pci_write_config8(dev, 0x09, 0x8f);
- /* Set Interrupt Line */ - /* Interrupt Pin is set by D31IP.PIP */ - pci_write_config8(dev, INTR_LN, 0xff); - /* Set timings */ pci_write_config16(dev, IDE_TIM_PRI, IDE_DECODE_ENABLE | IDE_ISP_3_CLOCKS | IDE_RCT_1_CLOCKS |
Nico Huber has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/40229 )
Patch Set 1:
(2 comments)
https://review.coreboot.org/c/coreboot/+/40229/1//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/40229/1//COMMIT_MSG@7 PS1, Line 7: sb/intel/bd82x6x/sata: Don't write RO register Ooops, now that I see it again, it's actually not trying to write the read-only part (interrupt pin would be ro, interrupt line is r/w)... Of course there is a(nother) reason I dropped the code:
The interrupt line registers are configured in a central place, pch_pirq_init() in `lpc.c`, according to the PIRQ configuration. Hardcoding values here makes no sense.
https://review.coreboot.org/c/coreboot/+/40229/1/src/southbridge/intel/bd82x... File src/southbridge/intel/bd82x6x/sata.c:
https://review.coreboot.org/c/coreboot/+/40229/1/src/southbridge/intel/bd82x... PS1, Line 63: pci_write_config8(dev, INTR_LN, 0x0a); Please also remove this and the definition of INTR_LN in `pch.h`.
Felix Singer has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/40229 )
Change subject: sb/intel/bd82x6x/sata: Don't hard-code values ......................................................................
Patch Set 3:
(2 comments)
This change is ready for review.
Ooops, now that I see it again, it's actually not trying to write the […]
Done
Done
Hello build bot (Jenkins), Nico Huber, Patrick Rudolph,
Change-Id: Ide5f101b2e5bda84f3c2ff8c8ca636b8233bb948 Signed-off-by: Felix Singer felix.singer@secunet.com --- M src/southbridge/intel/bd82x6x/pch.h M src/southbridge/intel/bd82x6x/sata.c 2 files changed, 0 insertions(+), 9 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/29/40229/4
Patrick Rudolph has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/40229 )
Patch Set 4: Code-Review+2
Paul Menzel has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/40229 )
Patch Set 4: Code-Review+1
Nico Huber has submitted this change. ( https://review.coreboot.org/c/coreboot/+/40229 )
Change-Id: Ide5f101b2e5bda84f3c2ff8c8ca636b8233bb948 Signed-off-by: Felix Singer felix.singer@secunet.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/40229 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Patrick Rudolph siro@das-labor.org Reviewed-by: Paul Menzel paulepanter@users.sourceforge.net --- M src/southbridge/intel/bd82x6x/pch.h M src/southbridge/intel/bd82x6x/sata.c 2 files changed, 0 insertions(+), 9 deletions(-)
Approvals: build bot (Jenkins): Verified Paul Menzel: Looks good to me, but someone else must approve Patrick Rudolph: Looks good to me, approved
diff --git a/src/southbridge/intel/bd82x6x/pch.h b/src/southbridge/intel/bd82x6x/pch.h index 18383f6..0a236c6 100644 --- a/src/southbridge/intel/bd82x6x/pch.h +++ b/src/southbridge/intel/bd82x6x/pch.h @@ -167,7 +167,6 @@ #define PCH_IDE_DEV PCI_DEV(0, 0x1f, 1) #define PCH_SATA_DEV PCI_DEV(0, 0x1f, 2) #define PCH_SATA2_DEV PCI_DEV(0, 0x1f, 5) -#define INTR_LN 0x3c #define IDE_TIM_PRI 0x40 /* IDE timings, primary */ #define IDE_DECODE_ENABLE (1 << 15) #define IDE_SITRE (1 << 14) diff --git a/src/southbridge/intel/bd82x6x/sata.c b/src/southbridge/intel/bd82x6x/sata.c index e04f3ba..310d1a2 100644 --- a/src/southbridge/intel/bd82x6x/sata.c +++ b/src/southbridge/intel/bd82x6x/sata.c @@ -58,10 +58,6 @@
printk(BIOS_DEBUG, "SATA: Controller in AHCI mode.\n");
- /* Set Interrupt Line */ - /* Interrupt Pin is set by D31IP.PIP */ - pci_write_config8(dev, INTR_LN, 0x0a); - /* Set timings */ pci_write_config16(dev, IDE_TIM_PRI, IDE_DECODE_ENABLE | IDE_ISP_3_CLOCKS | IDE_RCT_1_CLOCKS | @@ -131,10 +127,6 @@ */ pci_write_config8(dev, 0x09, 0x8f);
9elements QA has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/40229 )
Patch Set 5:
Automatic boot test returned (PASS/FAIL/TOTAL): 3/0/3 Emulation targets: EMULATION_QEMU_X86_Q35 using payload TianoCore : SUCCESS : https://lava.9esec.io/r/2160 EMULATION_QEMU_X86_Q35 using payload SeaBIOS : SUCCESS : https://lava.9esec.io/r/2159 EMULATION_QEMU_X86_I440FX using payload SeaBIOS : SUCCESS : https://lava.9esec.io/r/2158
