Hello build bot (Jenkins), Nico Huber, Furquan Shaikh, Subrata Banik, Aamir Bohra, Andrey Petrov, Patrick Rudolph,
https://review.coreboot.org/c/coreboot/+/45952
to look at the new patch set (#20).
Change subject: soc/intel/common: add Kconfig to enable/disable the ACPI PM timer ......................................................................
Currently, the ACPI PM timer state gets set in devicetree by the option PmTimerDisabled. However, it is not board design dependent. Thus, add a user-selectable Kconfig option.
Also, make the TCO SMI option select ACPI PM timer, since TCO won't work without it.
The Kconfig option depends on CTC (Common Timer Copy), which a SoC has to support to do PM ACPI timer emulation.
This new Kconfig gets used in the follow-up commits of this series.
Note: On Apollolake USE_PM_ACPI_TIMER gets selected statically to avoid confusing the user in menuconfig, where the option is shown due to use of the common code for PM Timer emulation. Currently, there is no FSP option and no coreboot code to disable the PM ACPI Timer and it is unknown if that is desireable on that platform.
Change-Id: I7f607f277eb14f84a7370ffb25a13226e7ccc917 Signed-off-by: Michael Niewöhner foss@mniewoehner.de --- M src/soc/intel/apollolake/Kconfig M src/soc/intel/common/block/pmc/Kconfig M src/soc/intel/common/block/smm/Kconfig 3 files changed, 18 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/52/45952/20
