Arthur Heymans has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/63378 )
Change subject: Kconfig: Add an option to ommit a cbfs master header ......................................................................
The CBFS master header is legacy feature that has no internal use in coreboot. Some payloads do depend on it however.
Change-Id: Ib3d5b32412db40df48c0ed4dd6216bdd9cb955e2 Signed-off-by: Arthur Heymans arthur@aheymans.xyz --- M src/Kconfig M src/lib/Makefile.inc 2 files changed, 10 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/78/63378/1
diff --git a/src/Kconfig b/src/Kconfig index eb1cac5..ae33e60 100644 --- a/src/Kconfig +++ b/src/Kconfig @@ -463,6 +463,14 @@ help If this option is enabled, coreboot will scan only PCI devices marked as mandatory in devicetree.cb + +config CBFS_MASTER_HEADER + bool "Include a legacy cbfs master header" + default y + help + Some payloads depend on this legacy interface. Payloads should use the active + region exposed in COREBOOT tables. + endmenu
menu "Mainboard" diff --git a/src/lib/Makefile.inc b/src/lib/Makefile.inc index 71a9d93..299bc9d 100644 --- a/src/lib/Makefile.inc +++ b/src/lib/Makefile.inc @@ -394,13 +394,13 @@
romstage-$(CONFIG_SPD_CACHE_IN_FMAP) += spd_cache.c
-cbfs-files-y += cbfs_master_header +cbfs-files-$(CONFIG_CBFS_MASTER_HEADER) += cbfs_master_header cbfs_master_header-file := cbfs_master_header.c:struct cbfs_master_header-type := "cbfs header" cbfs_master_header-position := 0
ifneq ($(CONFIG_TOP_ALIGNED_CBFS_BOOTBLOCK),y) -cbfs-files-y += header_pointer +cbfs-files-$(CONFIG_CBFS_MASTER_HEADER) += header_pointer header_pointer-file := master_header_pointer.c:struct header_pointer-position := -4 header_pointer-type := "cbfs header"
