Brandon Breitenstein has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/41543 )
Change subject: mb/intel/tglrvp: Enable PCIEXP_HOTPLUG for TCSS TBT/USB4 ......................................................................
This change enables PCIEXP_HOTPLUG to support resource allocation for TCSS TBT/USB4.
BUG=b:149186922
Change-Id: Id3066204c8a780ade251c7be4052a60a861e43db Signed-off-by: Brandon Breitenstein brandon.breitenstein@intel.com --- M src/mainboard/intel/tglrvp/Kconfig 1 file changed, 13 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/43/41543/1
diff --git a/src/mainboard/intel/tglrvp/Kconfig b/src/mainboard/intel/tglrvp/Kconfig index d60918f..edbd486 100644 --- a/src/mainboard/intel/tglrvp/Kconfig +++ b/src/mainboard/intel/tglrvp/Kconfig @@ -15,6 +15,7 @@ select SOC_INTEL_TIGERLAKE select INTEL_LPSS_UART_FOR_CONSOLE select DRIVERS_INTEL_ISH + select PCIEXP_HOTPLUG
config CHROMEOS bool @@ -49,6 +50,18 @@ int default 8
+config PCIEXP_HOTPLUG_BUSES + int + default 42 + +config PCIEXP_HOTPLUG_MEM + hex + default 0xc200000 # 194 MiB + +config PCIEXP_HOTPLUG_PREFETCH_MEM + hex + default 0x1c00000 # 448 MiB + config DEVICETREE string default "variants/$(CONFIG_VARIANT_DIR)/devicetree.cb"
John Zhao has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/41543 )
Patch Set 1: Code-Review+2
Wonkyu Kim has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/41543 )
Patch Set 1:
https://review.coreboot.org/c/coreboot/+/41543/1/src/mainboard/intel/tglrvp/... File src/mainboard/intel/tglrvp/Kconfig:
https://review.coreboot.org/c/coreboot/+/41543/1/src/mainboard/intel/tglrvp/... PS1, Line 18: select PCIEXP_HOTPLUG Does it also enable hotplug for other PCIe port? FSPs upd has below UPD and we can enable/disable hotplug indivisually. PcieRpHotPlug[24]; CpuPcieRpHotPlug[4];
Patch Set 1:
Does it also enable hotplug for other PCIe port? […]
This PCIEXP_HOTPLUG selection only make sure resources are allocated for Thunderbolt PCIe root ports, not for others.
Jamie Ryu has uploaded a new patch set (#2) to the change originally created by Brandon Breitenstein. ( https://review.coreboot.org/c/coreboot/+/41543 )
BUG=b:149186922
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/43/41543/2
Jamie Ryu has uploaded a new patch set (#3) to the change originally created by Brandon Breitenstein. ( https://review.coreboot.org/c/coreboot/+/41543 )
BUG=b:149186922
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/43/41543/3
Patch Set 3: Code-Review+2
Patrick Georgi has submitted this change. ( https://review.coreboot.org/c/coreboot/+/41543 )
BUG=b:149186922
Change-Id: Id3066204c8a780ade251c7be4052a60a861e43db Signed-off-by: Brandon Breitenstein brandon.breitenstein@intel.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/41543 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Wonkyu Kim wonkyu.kim@intel.com --- M src/mainboard/intel/tglrvp/Kconfig 1 file changed, 13 insertions(+), 0 deletions(-)
Approvals: build bot (Jenkins): Verified Wonkyu Kim: Looks good to me, approved
diff --git a/src/mainboard/intel/tglrvp/Kconfig b/src/mainboard/intel/tglrvp/Kconfig index 8277875..867c88e 100644 --- a/src/mainboard/intel/tglrvp/Kconfig +++ b/src/mainboard/intel/tglrvp/Kconfig @@ -17,6 +17,7 @@ select INTEL_LPSS_UART_FOR_CONSOLE select DRIVERS_INTEL_ISH select EC_ACPI + select PCIEXP_HOTPLUG
config CHROMEOS bool @@ -55,6 +56,18 @@ int default 8
