Shelley Chen has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/31358
Change subject: mb/google/hatch: Use MEM_CH_SEL to indicate single_channel sku ......................................................................
MEM_CH_SEL is used to indicate whether we are on a single or dual channel device, where MEM_CH_SEL = 1 for single channel skus and MEM_CH_SEL = 0 for dual channel skus. Initialize MemorySpdPrt pointers based on the value read from MEM_CH_SEL, which is read from GPP_F2. In the first build, we did not use GPP_F2, so we need to add an internal pulldown as those early devices were all dual channel devices.
BUG=b:123062346, b:122959294 BRANCH=None TEST=Boot into current boards and ensure that we have 2 channels as expected Also, verify that GPP_F2 is set to 0.
Change-Id: I89d022793580be603a93d0b177d73ce968529b5c Signed-off-by: Shelley Chen shchen@google.com --- M src/mainboard/google/hatch/romstage.c M src/mainboard/google/hatch/variants/baseboard/gpio.c M src/mainboard/google/hatch/variants/baseboard/include/baseboard/variants.h M src/mainboard/google/hatch/variants/baseboard/memory.c 4 files changed, 47 insertions(+), 26 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/58/31358/1
diff --git a/src/mainboard/google/hatch/romstage.c b/src/mainboard/google/hatch/romstage.c index 401f41f..b2db7ee 100644 --- a/src/mainboard/google/hatch/romstage.c +++ b/src/mainboard/google/hatch/romstage.c @@ -19,11 +19,14 @@
void mainboard_memory_init_params(FSPM_UPD *memupd) { + struct cnl_mb_cfg memcfg; + const struct spd_info spd = { .spd_by_index = true, .spd_spec.spd_index = variant_memory_sku(), };
+ variant_memory_params(&memcfg); cannonlake_memcfg_init(&memupd->FspmConfig, - variant_memory_params(), &spd); + &memcfg, &spd); } diff --git a/src/mainboard/google/hatch/variants/baseboard/gpio.c b/src/mainboard/google/hatch/variants/baseboard/gpio.c index f8d5d7d..b87cfa8 100644 --- a/src/mainboard/google/hatch/variants/baseboard/gpio.c +++ b/src/mainboard/google/hatch/variants/baseboard/gpio.c @@ -115,6 +115,8 @@ PAD_CFG_NF(GPP_F0, NONE, DEEP, NF1), /* WWAN_RESET_1V8_ODL */ PAD_CFG_GPO(GPP_F1, 1, DEEP), + /* MEM_CH_SEL */ + PAD_CFG_GPI(GPP_F2, DN_20K, PLTRST), /* UART_WWANTX_WLANRX_COEX1 */ PAD_CFG_NF(GPP_F8, NONE, DEEP, NF1), /* UART_WWANRX_WLANTX_COEX2 */ @@ -185,6 +187,8 @@ PAD_CFG_GPI_APIC(GPP_C21, NONE, DEEP, LEVEL, INVERT), /* WLAN_PE_RST# */ PAD_CFG_GPO(GPP_C23, 1, DEEP), + /* MEM_CH_SEL */ + PAD_CFG_GPI(GPP_F2, DN_20K, PLTRST), };
const struct pad_config *__weak variant_early_gpio_table(size_t *num) diff --git a/src/mainboard/google/hatch/variants/baseboard/include/baseboard/variants.h b/src/mainboard/google/hatch/variants/baseboard/include/baseboard/variants.h index 038ec6e..aa7c67d 100644 --- a/src/mainboard/google/hatch/variants/baseboard/include/baseboard/variants.h +++ b/src/mainboard/google/hatch/variants/baseboard/include/baseboard/variants.h @@ -16,6 +16,7 @@ #ifndef BASEBOARD_VARIANTS_H #define BASEBOARD_VARIANTS_H
+#include <soc/cnl_memcfg_init.h> #include <soc/gpio.h> #include <stdint.h> #include <vendorcode/google/chromeos/chromeos.h> @@ -29,7 +30,7 @@ int variant_memory_sku(void);
/* Return board specific memory configuration */ -const struct cnl_mb_cfg *variant_memory_params(void); +void variant_memory_params(struct cnl_mb_cfg *bcfg);
/* Return ChromeOS gpio table and fill in number of entries. */ const struct cros_gpio *variant_cros_gpios(size_t *num); diff --git a/src/mainboard/google/hatch/variants/baseboard/memory.c b/src/mainboard/google/hatch/variants/baseboard/memory.c index 80f3ba4..977573d 100644 --- a/src/mainboard/google/hatch/variants/baseboard/memory.c +++ b/src/mainboard/google/hatch/variants/baseboard/memory.c @@ -18,33 +18,46 @@ #include <gpio.h> #include <soc/cnl_memcfg_init.h>
-static const struct cnl_mb_cfg baseboard_memcfg = { - /* - * The dqs_map arrays map the ddr4 pins to the SoC pins - * for both channels. - * - * the index = pin number on ddr4 part - * the value = pin number on SoC - */ - .dqs_map[DDR_CH0] = { 0, 1, 4, 5, 2, 3, 6, 7 }, - .dqs_map[DDR_CH1] = { 0, 1, 4, 5, 2, 3, 6, 7 }, - - /* Baseboard uses 120, 81 and 100 rcomp resistors */ - .rcomp_resistor = { 120, 81, 100 }, - - /* Baseboard Rcomp target values */ - .rcomp_targets = { 100, 40, 20, 20, 26 }, - - /* Set CaVref config to 2 */ - .vref_ca_config = 2, - - /* Enable Early Command Training */ - .ect = 1, +/* + * The dqs_map arrays map the ddr4 pins to the SoC pins + * for both channels. + * + * the index = pin number on ddr4 part + * the value = pin number on SoC + */ +static const uint8_t dqs_map_ddr4[][8] = { + { 0, 1, 4, 5, 2, 3, 6, 7 }, + { 0, 1, 4, 5, 2, 3, 6, 7 } }; +/* Baseboard uses 120, 81 and 100 rcomp resistors */ +const static uint16_t rcomp_resistor_ddr4[] = { 120, 81, 100 }; +/* Baseboard Rcomp target values */ +const static uint16_t rcomp_targets_ddr4[] = { 100, 40, 20, 20, 26 };
-const struct cnl_mb_cfg *__weak variant_memory_params(void) +void __weak variant_memory_params(struct cnl_mb_cfg *bcfg) { - return &baseboard_memcfg; + int i; + + for (i = 0; i < sizeof(dqs_map_ddr4[DDR_CH0])/sizeof(uint8_t); i++) { + bcfg->dqs_map[DDR_CH0][i] = dqs_map_ddr4[DDR_CH0][i]; + bcfg->dqs_map[DDR_CH1][i] = dqs_map_ddr4[DDR_CH1][i]; + } + + for (i = 0; i < sizeof(rcomp_resistor_ddr4)/sizeof(uint16_t); i++) + bcfg->rcomp_resistor[i] = rcomp_resistor_ddr4[i]; + + for (i = 0; i < sizeof(rcomp_targets_ddr4)/sizeof(uint16_t); i++) + bcfg->rcomp_targets[i] = rcomp_targets_ddr4[i]; + + bcfg->vref_ca_config = 2; + bcfg->ect = 1; + + /* + * GPP_F2 is the MEM_CH_SEL gpio, which is set to 1 for single + * channel skus and 0 for dual channel skus. + */ + if (gpio_get(GPP_F2) == 1) + bcfg->single_channel = 1; }
int __weak variant_memory_sku(void)
Shelley Chen has uploaded a new patch set (#2). ( https://review.coreboot.org/c/coreboot/+/31358 )
MEM_CH_SEL is used to indicate whether we are on a single or dual channel device, where MEM_CH_SEL = 1 for single channel skus and MEM_CH_SEL = 0 for dual channel skus. Initialize single_channel field (from GPP_F2), which will in turn initialize MemorySpdPrt pointers in cannonlake soc code. In the first build, we did not use GPP_F2, so we need to add an internal pulldown as those early devices were all dual channel devices.
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/58/31358/2
Furquan Shaikh has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/31358 )
Patch Set 3:
https://review.coreboot.org/#/c/31358/3/src/mainboard/google/hatch/variants/... File src/mainboard/google/hatch/variants/baseboard/memory.c:
https://review.coreboot.org/#/c/31358/3/src/mainboard/google/hatch/variants/... PS3, Line 22: : : : : : : : : : : : : : : : : : : : : Why were these values moved out? They would remain the same irrespective of single or dual channel, right?
Shelley Chen has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/31358 )
Patch Set 3:
Why were these values moved out? They would remain the same irrespective of single or dual channel, […]
yeah, this was not straightforward. I had to take the const struct out so that I could add the single_channel field, which resulted in a compiler error with illegal global variable basebaord_memcfg.
Patch Set 3:
yeah, this was not straightforward. […]
But why not just have:
static struct cnl_mb_cfg baseboard_memcfg = {
here and then:
const struct cnl_mb_cfg *__weak variant_memory_params(void) { if (gpio_get(GPP_F2) == 1) baseboard_memcfg.single_channel = 1;
return &baseboard_memcfg; }
Patch Set 3:
But why not just have: […]
Making the struct non-const results in the error that I mentioned before:
Forbidden global variables in romstage: CC firmware/2lib/2crc8.o ffffff30 d _GLOBAL_OFFSET_TABLE_ ffffff00 d baseboard_memcfg CC firmware/lib20/packed_key.o make: *** [src/arch/x86/Makefile.inc:249: build-hatch/cbfs/fallback/romstage.debug] Error 1
Patch Set 3:
(3 comments)
https://review.coreboot.org/#/c/31358/3/src/mainboard/google/hatch/romstage.... File src/mainboard/google/hatch/romstage.c:
https://review.coreboot.org/#/c/31358/3/src/mainboard/google/hatch/romstage.... PS3, Line 22: struct static
https://review.coreboot.org/#/c/31358/3/src/mainboard/google/hatch/romstage.... PS3, Line 24: const static
Making the struct non-const results in the error that I mentioned before: […]
Aah yes!
We can probably do:
void __weak variant_memory_params(struct cnl_mb_cfg *bcfg) { memcpy(bcfg, &baseboard_memcfg, sizeof(baseboard_memcfg)); if (gpio_get(GPP_F2)) bcfg.single_channel = 1; }
That way you don't have to split the above structure and do individual copies.
Hello Aaron Durbin, Aamir Bohra, Duncan Laurie, Rizwan Qureshi, build bot (Jenkins), Furquan Shaikh,
Change-Id: I89d022793580be603a93d0b177d73ce968529b5c Signed-off-by: Shelley Chen shchen@google.com --- M src/mainboard/google/hatch/romstage.c M src/mainboard/google/hatch/variants/baseboard/gpio.c M src/mainboard/google/hatch/variants/baseboard/include/baseboard/variants.h M src/mainboard/google/hatch/variants/baseboard/memory.c 4 files changed, 19 insertions(+), 4 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/58/31358/4
Patch Set 4: Code-Review+2
https://review.coreboot.org/#/c/31358/4//COMMIT_MSG Commit Message:
https://review.coreboot.org/#/c/31358/4//COMMIT_MSG@12 PS4, Line 12: MemorySpdPrt MemorySpdPtr
MEM_CH_SEL is used to indicate whether we are on a single or dual channel device, where MEM_CH_SEL = 1 for single channel skus and MEM_CH_SEL = 0 for dual channel skus. Initialize single_channel field (from GPP_F2), which will in turn initialize MemorySpdPtr pointers in cannonlake soc code. In the first build, we did not use GPP_F2, so we need to add an internal pulldown as those early devices were all dual channel devices.
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/58/31358/5
Patch Set 5: Code-Review+2
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/58/31358/6
Change-Id: I89d022793580be603a93d0b177d73ce968529b5c Signed-off-by: Shelley Chen shchen@google.com --- M src/mainboard/google/hatch/romstage.c M src/mainboard/google/hatch/variants/baseboard/gpio.c M src/mainboard/google/hatch/variants/baseboard/include/baseboard/variants.h M src/mainboard/google/hatch/variants/baseboard/memory.c 4 files changed, 29 insertions(+), 4 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/58/31358/7
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/58/31358/9
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/58/31358/12
Patch Set 12:
https://review.coreboot.org/#/c/31358/12/src/mainboard/google/hatch/variants... File src/mainboard/google/hatch/variants/baseboard/gpio.c:
https://review.coreboot.org/#/c/31358/12/src/mainboard/google/hatch/variants... PS12, Line 119: PAD_CFG_GPI(GPP_F2, DN_20K, PLTRST), Actually, I am unsure about the state of GPP_F2 on hatch_whl. Maybe we should push this change later when adding new variant?
Patch Set 14:
Actually, I am unsure about the state of GPP_F2 on hatch_whl. […]
Ok, we can add this in cml.
Change-Id: I89d022793580be603a93d0b177d73ce968529b5c Signed-off-by: Shelley Chen shchen@google.com --- M src/mainboard/google/hatch/romstage.c M src/mainboard/google/hatch/variants/baseboard/gpio.c M src/mainboard/google/hatch/variants/baseboard/include/baseboard/variants.h M src/mainboard/google/hatch/variants/baseboard/memory.c 4 files changed, 27 insertions(+), 6 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/58/31358/15
Patch Set 15:
(3 comments)
Don't you also need to update this: https://review.coreboot.org/cgit/coreboot.git/tree/src/mainboard/google/hatc...
https://review.coreboot.org/#/c/31358/15/src/mainboard/google/hatch/variants... File src/mainboard/google/hatch/variants/baseboard/gpio.c:
https://review.coreboot.org/#/c/31358/15/src/mainboard/google/hatch/variants... PS15, Line 284: DN_20K Why is the pull-down required?
https://review.coreboot.org/#/c/31358/15/src/mainboard/google/hatch/variants... PS15, Line 432: DN_20K same here
https://review.coreboot.org/#/c/31358/15/src/mainboard/google/hatch/variants... File src/mainboard/google/hatch/variants/baseboard/memory.c:
https://review.coreboot.org/#/c/31358/15/src/mainboard/google/hatch/variants... PS15, Line 22: baseboard_memcfg Do these params apply to both hatch and hatch_whl?
Patch Set 18:
Patch Set 15:
(3 comments)
I was going to update this in another CL (mainly because this was enabling the MEM_CH_SEL gpio).
Patch Set 18:
This was originally done to accommodate earlier boards that had this line not connected.
Patch Set 18: Code-Review+2
Patrick Georgi has submitted this change and it was merged. ( https://review.coreboot.org/c/coreboot/+/31358 )
Change-Id: I89d022793580be603a93d0b177d73ce968529b5c Signed-off-by: Shelley Chen shchen@google.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/31358 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Furquan Shaikh furquan@google.com --- M src/mainboard/google/hatch/romstage.c M src/mainboard/google/hatch/variants/baseboard/gpio.c M src/mainboard/google/hatch/variants/baseboard/include/baseboard/variants.h M src/mainboard/google/hatch/variants/baseboard/memory.c 4 files changed, 27 insertions(+), 6 deletions(-)
diff --git a/src/mainboard/google/hatch/romstage.c b/src/mainboard/google/hatch/romstage.c index 429aa09..bdf951b 100644 --- a/src/mainboard/google/hatch/romstage.c +++ b/src/mainboard/google/hatch/romstage.c @@ -23,13 +23,16 @@
void mainboard_get_dram_part_num(const char **part_num, size_t *len) diff --git a/src/mainboard/google/hatch/variants/baseboard/gpio.c b/src/mainboard/google/hatch/variants/baseboard/gpio.c index 091f6b8..93e0af1 100644 --- a/src/mainboard/google/hatch/variants/baseboard/gpio.c +++ b/src/mainboard/google/hatch/variants/baseboard/gpio.c @@ -281,7 +281,7 @@ /* F1 : WWAN_RESET_1V8_ODL */ PAD_CFG_GPO(GPP_F1, 1, DEEP), /* F2 : MEM_CH_SEL */ - PAD_CFG_GPI(GPP_F2, NONE, PLTRST), + PAD_CFG_GPI(GPP_F2, DN_20K, PLTRST), /* F3 : GPP_F3 ==> NC */ PAD_NC(GPP_F3, NONE), /* F4 : CNV_BRI_DT */ @@ -429,7 +429,7 @@ /* C23 : WLAN_PE_RST# */ PAD_CFG_GPO(GPP_C23, 1, DEEP), /* F2 : MEM_CH_SEL */ - PAD_CFG_GPI(GPP_F2, NONE, PLTRST), + PAD_CFG_GPI(GPP_F2, DN_20K, PLTRST), /* F11 : PCH_MEM_STRAP2 */ PAD_CFG_GPI(GPP_F11, NONE, PLTRST), /* F20 : PCH_MEM_STRAP0 */ diff --git a/src/mainboard/google/hatch/variants/baseboard/include/baseboard/variants.h b/src/mainboard/google/hatch/variants/baseboard/include/baseboard/variants.h index 038ec6e..aa7c67d 100644 --- a/src/mainboard/google/hatch/variants/baseboard/include/baseboard/variants.h +++ b/src/mainboard/google/hatch/variants/baseboard/include/baseboard/variants.h @@ -16,6 +16,7 @@ #ifndef BASEBOARD_VARIANTS_H #define BASEBOARD_VARIANTS_H
/* Return ChromeOS gpio table and fill in number of entries. */ const struct cros_gpio *variant_cros_gpios(size_t *num); diff --git a/src/mainboard/google/hatch/variants/baseboard/memory.c b/src/mainboard/google/hatch/variants/baseboard/memory.c index 80f3ba4..6ca98e4 100644 --- a/src/mainboard/google/hatch/variants/baseboard/memory.c +++ b/src/mainboard/google/hatch/variants/baseboard/memory.c @@ -17,6 +17,7 @@ #include <baseboard/gpio.h> #include <gpio.h> #include <soc/cnl_memcfg_init.h> +#include <string.h>
static const struct cnl_mb_cfg baseboard_memcfg = { /* @@ -42,9 +43,25 @@ .ect = 1, };
-const struct cnl_mb_cfg *__weak variant_memory_params(void) +void __weak variant_memory_params(struct cnl_mb_cfg *bcfg) { - return &baseboard_memcfg; + memcpy(bcfg, &baseboard_memcfg, sizeof(baseboard_memcfg)); + /* + * GPP_F2 is the MEM_CH_SEL gpio, which is set to 1 for single + * channel skus and 0 for dual channel skus. + */ + if (gpio_get(GPP_F2) == 1) { + /* + * Single channel config: for Hatch, Channel 0 is + * always populated. + */ + bcfg->channel_empty[0] = 0; + bcfg->channel_empty[1] = 1; + } else { + /* Dual channel config: both channels populated. */ + bcfg->channel_empty[0] = 0; + bcfg->channel_empty[1] = 0; + } }
