Attention is currently required from: Martin Roth, Julius Werner, Arthur Heymans, Yu-Ping Wu. Arthur Heymans has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/59132 )
Change subject: Makefile.inc: Generate master header and pointer as C structs ......................................................................
Patch Set 6:
(6 comments)
File src/arch/x86/header_pointer.c:
https://review.coreboot.org/c/coreboot/+/59132/comment/72f2fab5_905315c2 PS6, Line 7: __attribute__((used, __section__(".header_pointer"))) const uint32_t header_pointer =
Wouldn't it be simpler to just merge this with the src/lib version and wrap the section attribute […]
Done
File src/lib/cbfs_master_header.c:
https://review.coreboot.org/c/coreboot/+/59132/comment/52463f9e_46f4309c PS6, Line 10: FMAP_SECTION_FLASH_SIZE
I believe this needs to be […]
Done
https://review.coreboot.org/c/coreboot/+/59132/comment/61b0beab_9294b54c PS6, Line 11: .bootblocksize = cpu_to_be32(4),
This should probably have a comment about why this is 4... […]
Done
https://review.coreboot.org/c/coreboot/+/59132/comment/0d128e69_09ddfbbc PS6, Line 12: .align = cpu_to_be32(64),
You should be able to use the CBFS_ALIGNMENT constant here.
Done
https://review.coreboot.org/c/coreboot/+/59132/comment/55c16aac_b7c5caec PS6, Line 13: FMAP_SECTION_FLASH_START
Isn't this just 0? Rather than assuming that all FMAPs are named "FLASH", I think it's easier to j […]
Done
File src/lib/master_header_pointer.c:
https://review.coreboot.org/c/coreboot/+/59132/comment/86b9c4be_234eeeb9 PS6, Line 7: __attribute((used))
I don't think you need this? We've never needed it for other structs... […]
Done
