Shreesh Chhabbi has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/42483 )
Change subject: mainboard/volteer: Enable SaGv ......................................................................
Change-Id: I1bce3b9f837fb19ba5a20ae31750a73474a86788 Signed-off-by: Shreesh Chhabbi shreesh.chhabbi@intel.com --- M src/mainboard/google/volteer/variants/baseboard/devicetree.cb 1 file changed, 1 insertion(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/83/42483/1
diff --git a/src/mainboard/google/volteer/variants/baseboard/devicetree.cb b/src/mainboard/google/volteer/variants/baseboard/devicetree.cb index 8cd926c..6dbc415 100644 --- a/src/mainboard/google/volteer/variants/baseboard/devicetree.cb +++ b/src/mainboard/google/volteer/variants/baseboard/devicetree.cb @@ -36,7 +36,7 @@ register "pmc_gpe0_dw2" = "GPP_E"
# FSP configuration - register "SaGv" = "SaGv_Disabled" + register "SaGv" = "SaGv_Enabled" register "SmbusEnable" = "0"
register "usb2_ports[0]" = "USB2_PORT_MID(OC_SKIP)" # Type-A Port A0
Shreesh Chhabbi has uploaded a new patch set (#2). ( https://review.coreboot.org/c/coreboot/+/42483 )
BUG=b/159198381 TEST=Flashed image on Volteer Proto 2 SKU 2 and booted to Chrome OS
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/83/42483/2
Shreesh Chhabbi has uploaded a new patch set (#3) to the change originally created by Shreesh Chhabbi. ( https://review.coreboot.org/c/coreboot/+/42483 )
BUG=b:159198381 TEST=Flashed image on Volteer Proto 2 SKU 2 and booted to Chrome OS
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/83/42483/3
Shreesh Chhabbi has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/42483 )
Patch Set 3: Code-Review+1
Duncan Laurie has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/42483 )
Patch Set 3:
I saw hangs during training when I tried this last time, but hopefully with the flex ratio change it will work better. I'd feel better if Alex tried it on his devices first...
Patch Set 3:
Patch Set 3:
Sure Duncan. I verified 2 cold boots on one of the SKU 2 boards.
Hello build bot (Jenkins), Furquan Shaikh, Wonkyu Kim, Caveh Jalali, Ravishankar Sarawadi, Duncan Laurie, Alex Levin, Raj Astekar, Srinidhi N Kaushik, Shreesh Chhabbi,
Change subject: mainboard/volteer: Enable SaGv for volteer2, delbin & voxel ......................................................................
SaGv needs to be enabled for only QS. On ES2, we are seeing system instability.
Change-Id: I1bce3b9f837fb19ba5a20ae31750a73474a86788 Signed-off-by: Shreesh Chhabbi shreesh.chhabbi@intel.com --- M src/mainboard/google/volteer/variants/delbin/overridetree.cb M src/mainboard/google/volteer/variants/volteer2/overridetree.cb M src/mainboard/google/volteer/variants/voxel/overridetree.cb 3 files changed, 3 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/83/42483/5
BUG=b:159198381 TEST=Tested for boot. Power and performance tests were run with volteer2 with qs setup. System showed stability. Testing on delbin is pending.
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/83/42483/6
Wonkyu Kim has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/42483 )
Patch Set 6: Code-Review+1
Furquan Shaikh has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/42483 )
Patch Set 6:
https://review.coreboot.org/c/coreboot/+/42483/6/src/mainboard/google/voltee... File src/mainboard/google/volteer/variants/delbin/overridetree.cb:
https://review.coreboot.org/c/coreboot/+/42483/6/src/mainboard/google/voltee... PS6, Line 2: register "SaGv" = "SaGv_Enabled" Just a thought: It might be better to set register "SaGv" = "SaGv_Enabled" in baseboard/devicetree.cb and add register "SaGv" = "SaGv_Disabled" in variants/*/overridetree.cb for all variants that are not yet ready to enable this.
When a variant is ready to enable this param, they just need to drop register "SaGv" = "SaGv_Disabled" from their overridetree.cb. Eventually, all overridetree.cb files would be free of this setting and only baseboard/devicetree.cb would have the enabling.
Patch Set 7:
Just a thought: It might be better to set register "SaGv" = "SaGv_Enabled" in baseboard/devicetree. […]
Ack
Change-Id: I1bce3b9f837fb19ba5a20ae31750a73474a86788 Signed-off-by: Shreesh Chhabbi shreesh.chhabbi@intel.com --- M src/mainboard/google/volteer/variants/baseboard/devicetree.cb M src/mainboard/google/volteer/variants/delbin/overridetree.cb M src/mainboard/google/volteer/variants/halvor/overridetree.cb M src/mainboard/google/volteer/variants/malefor/overridetree.cb M src/mainboard/google/volteer/variants/terrador/overridetree.cb M src/mainboard/google/volteer/variants/trondo/overridetree.cb M src/mainboard/google/volteer/variants/volteer/overridetree.cb A src/mainboard/intel/tglrvp/spd/Samsung-K4UBE3D4AA-MGCL.spd-old.hex 8 files changed, 41 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/83/42483/8
Change-Id: I1bce3b9f837fb19ba5a20ae31750a73474a86788 Signed-off-by: Shreesh Chhabbi shreesh.chhabbi@intel.com --- M src/mainboard/google/volteer/variants/baseboard/devicetree.cb M src/mainboard/google/volteer/variants/delbin/overridetree.cb M src/mainboard/google/volteer/variants/halvor/overridetree.cb M src/mainboard/google/volteer/variants/malefor/overridetree.cb M src/mainboard/google/volteer/variants/terrador/overridetree.cb M src/mainboard/google/volteer/variants/trondo/overridetree.cb M src/mainboard/google/volteer/variants/volteer/overridetree.cb 7 files changed, 9 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/83/42483/9
Caveh Jalali has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/42483 )
Patch Set 9: Code-Review+2
BUG=b:159198381 TEST=Tested for boot. Power and performance tests were run with volteer2 with qs setup. System showed stability. Tested for boot stability on on delbin.
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/83/42483/10
Patrick Georgi has submitted this change. ( https://review.coreboot.org/c/coreboot/+/42483 )
Change-Id: I1bce3b9f837fb19ba5a20ae31750a73474a86788 Signed-off-by: Shreesh Chhabbi shreesh.chhabbi@intel.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/42483 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Caveh Jalali caveh@chromium.org --- M src/mainboard/google/volteer/variants/baseboard/devicetree.cb M src/mainboard/google/volteer/variants/delbin/overridetree.cb M src/mainboard/google/volteer/variants/halvor/overridetree.cb M src/mainboard/google/volteer/variants/malefor/overridetree.cb M src/mainboard/google/volteer/variants/terrador/overridetree.cb M src/mainboard/google/volteer/variants/trondo/overridetree.cb M src/mainboard/google/volteer/variants/volteer/overridetree.cb 7 files changed, 9 insertions(+), 2 deletions(-)
Approvals: build bot (Jenkins): Verified Caveh Jalali: Looks good to me, approved
diff --git a/src/mainboard/google/volteer/variants/baseboard/devicetree.cb b/src/mainboard/google/volteer/variants/baseboard/devicetree.cb index 322389d..18bfcc4 100644 --- a/src/mainboard/google/volteer/variants/baseboard/devicetree.cb +++ b/src/mainboard/google/volteer/variants/baseboard/devicetree.cb @@ -47,7 +47,7 @@ register "HeciEnabled" = "1"
register "usb2_ports[0]" = "USB2_PORT_MID(OC_SKIP)" # Type-A Port A0 diff --git a/src/mainboard/google/volteer/variants/delbin/overridetree.cb b/src/mainboard/google/volteer/variants/delbin/overridetree.cb index 32204c5..9b5ae62 100644 --- a/src/mainboard/google/volteer/variants/delbin/overridetree.cb +++ b/src/mainboard/google/volteer/variants/delbin/overridetree.cb @@ -1,5 +1,4 @@ chip soc/intel/tigerlake - device domain 0 on end
diff --git a/src/mainboard/google/volteer/variants/halvor/overridetree.cb b/src/mainboard/google/volteer/variants/halvor/overridetree.cb index e53132a..12e059c 100644 --- a/src/mainboard/google/volteer/variants/halvor/overridetree.cb +++ b/src/mainboard/google/volteer/variants/halvor/overridetree.cb @@ -15,6 +15,8 @@ register "usb3_ports[2]" = "USB3_PORT_DEFAULT(OC2)" # Type-A / Type-C Port 2 register "usb3_ports[3]" = "USB3_PORT_EMPTY" # Type-A / Type-C Not Used
+ register "SaGv" = "SaGv_Disabled" + device domain 0 on device pci 15.0 on chip drivers/i2c/generic diff --git a/src/mainboard/google/volteer/variants/malefor/overridetree.cb b/src/mainboard/google/volteer/variants/malefor/overridetree.cb index b2a658c..c84ed83 100644 --- a/src/mainboard/google/volteer/variants/malefor/overridetree.cb +++ b/src/mainboard/google/volteer/variants/malefor/overridetree.cb @@ -17,6 +17,8 @@ register "usb3_ports[2]" = "USB3_PORT_EMPTY" # Type-A / Type-C Not Used register "usb3_ports[3]" = "USB3_PORT_EMPTY" # Type-A / Type-C Not Used
+ register "SaGv" = "SaGv_Disabled" + # I2C Port Config register "SerialIoI2cMode" = "{ [PchSerialIoIndexI2C0] = PchSerialIoPci, diff --git a/src/mainboard/google/volteer/variants/terrador/overridetree.cb b/src/mainboard/google/volteer/variants/terrador/overridetree.cb index 871ec24..c1c386a 100644 --- a/src/mainboard/google/volteer/variants/terrador/overridetree.cb +++ b/src/mainboard/google/volteer/variants/terrador/overridetree.cb @@ -17,6 +17,8 @@ register "usb3_ports[2]" = "USB3_PORT_EMPTY" # Type-A / Type-C Not Used register "usb3_ports[3]" = "USB3_PORT_EMPTY" # Type-A / Type-C Not Used
+ register "SaGv" = "SaGv_Disabled" + device domain 0 on device pci 15.0 on chip drivers/i2c/generic diff --git a/src/mainboard/google/volteer/variants/trondo/overridetree.cb b/src/mainboard/google/volteer/variants/trondo/overridetree.cb index 4bff10d..0932b64 100644 --- a/src/mainboard/google/volteer/variants/trondo/overridetree.cb +++ b/src/mainboard/google/volteer/variants/trondo/overridetree.cb @@ -1,4 +1,5 @@ chip soc/intel/tigerlake + register "SaGv" = "SaGv_Disabled" device domain 0 on device pci 15.1 on chip drivers/i2c/hid diff --git a/src/mainboard/google/volteer/variants/volteer/overridetree.cb b/src/mainboard/google/volteer/variants/volteer/overridetree.cb index 404b257..0944765 100644 --- a/src/mainboard/google/volteer/variants/volteer/overridetree.cb +++ b/src/mainboard/google/volteer/variants/volteer/overridetree.cb @@ -1,4 +1,5 @@ chip soc/intel/tigerlake + register "SaGv" = "SaGv_Disabled" device domain 0 on device pci 15.0 on chip drivers/i2c/generic
