Chen Wisley has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/43284 )
Change subject: mb/google/hatch: Set SA slow slew rate to 1/2 for jinlon/dratini ......................................................................
Applied CL (cb:38212) to reduce acoustic noise, and observed that screen flicked on vt2 on some devices after idle a perior of time. Remove SSR (1/8) setting for SA to default SSR 1/2, issue disappeared, and didn't affect noise much.
BUG=none TEST=build dratini, observe that screen flick issue disapppered
Change-Id: I9e81c2f15dd6babfa360eee213fc4ab6310c7455 --- M src/mainboard/google/hatch/variants/dratini/overridetree.cb M src/mainboard/google/hatch/variants/jinlon/overridetree.cb 2 files changed, 0 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/84/43284/1
diff --git a/src/mainboard/google/hatch/variants/dratini/overridetree.cb b/src/mainboard/google/hatch/variants/dratini/overridetree.cb index 0bada7d..2bfcc26 100644 --- a/src/mainboard/google/hatch/variants/dratini/overridetree.cb +++ b/src/mainboard/google/hatch/variants/dratini/overridetree.cb @@ -23,7 +23,6 @@ register "AcousticNoiseMitigation" = "1" register "SlowSlewRateForIa" = "2" register "SlowSlewRateForGt" = "2" - register "SlowSlewRateForSa" = "2" register "FastPkgCRampDisableIa" = "1" register "FastPkgCRampDisableGt" = "1" register "FastPkgCRampDisableSa" = "1" diff --git a/src/mainboard/google/hatch/variants/jinlon/overridetree.cb b/src/mainboard/google/hatch/variants/jinlon/overridetree.cb index a3bb782..fc3bb85 100644 --- a/src/mainboard/google/hatch/variants/jinlon/overridetree.cb +++ b/src/mainboard/google/hatch/variants/jinlon/overridetree.cb @@ -23,7 +23,6 @@ register "AcousticNoiseMitigation" = "1" register "SlowSlewRateForIa" = "2" register "SlowSlewRateForGt" = "2" - register "SlowSlewRateForSa" = "2" register "FastPkgCRampDisableIa" = "1" register "FastPkgCRampDisableGt" = "1" register "FastPkgCRampDisableSa" = "1"
Hello build bot (Jenkins),
Change-Id: I9e81c2f15dd6babfa360eee213fc4ab6310c7455 Signed-off-by: Wisley Chen wisley.chen@quantatw.com --- M src/mainboard/google/hatch/variants/dratini/overridetree.cb M src/mainboard/google/hatch/variants/jinlon/overridetree.cb 2 files changed, 0 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/84/43284/2
Applied CL (cb:38212) to reduce acoustic noise, and observed that screen flicked on vt2 on some devices after idle a period of time. Remove SSR (1/8) setting for SA to default SSR 1/2, issue disappeared, and didn't affect noise much.
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/84/43284/3
Applied CL (cb:38212) to reduce acoustic noise, and observed that screen flicked on vt2 on some devices after idle a period of time. Remove SSR (1/8) setting for SA to default SSR (1/2), issue disappeared, and didn't affect noise much.
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/84/43284/4
Chen Wisley has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43284 )
Patch Set 5:
This change is ready for review.
Paul Menzel has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43284 )
Patch Set 5:
https://review.coreboot.org/c/coreboot/+/43284/5//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/43284/5//COMMIT_MSG@9 PS5, Line 9: cb:38212 Please capitalize CB, so Gerrit marks it up.
Please also use git short hashes with the summary, as that is how git can be used.
Hello build bot (Jenkins), Philip Chen, Tim Wawrzynczak, Paul Fagerburg,
Applied CL (CB:38212, commit eae254e) to reduce acoustic noise, and observed that screen flicked on vt2 on some devices after idle a period of time. Remove SSR (1/8) setting for SA to default SSR (1/2), issue disappeared, and didn't affect noise much.
BUG=b:160754994 TEST=build dratini, observe that screen flick issue disapppered
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/84/43284/6
Patch Set 6:
Please capitalize CB, so Gerrit marks it up. […]
Done, thanks
Paul Fagerburg has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43284 )
Patch Set 6:
https://review.coreboot.org/c/coreboot/+/43284/6//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/43284/6//COMMIT_MSG@9 PS6, Line 9: Applied CL (CB:38212, commit eae254e) to reduce acoustic noise, and observed that screen Please word-wrap the commit message so that lines are no more than 72 characters long. I would also suggest putting the description of "what" first - "remove SSR (1/8) setting ..." - and then following it with a "why" - because CB:38212 (commit eae254e) caused screen flickering on VT2 on some devices ...
Remove SSR (1/8) setting for SA to default SSR (1/2), screen flicking issue disappeared, and didn't affect acoustic noise much.
Because CB:38212 (commit eae254e) caused screen flickering on VT2 on some devices after idle a period of time.
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/84/43284/7
Patch Set 7: Code-Review+1
Patch Set 7:
Hi Tim/Philip/Paul,
Could you help to review? if have no concern, please help give CR+2.
Thanks
Patch Set 7:
ping
https://review.coreboot.org/c/coreboot/+/43284/7//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/43284/7//COMMIT_MSG@12 PS7, Line 12: Because CB:38212 (commit eae254e) caused screen flickering on VT2 on : some devices after idle a period of time. Please put the problem description as the first paragraph.
Hello build bot (Jenkins), Philip Chen, Paul Menzel, Tim Wawrzynczak, Paul Fagerburg, Paul Fagerburg,
Screen flickered on VT2 on some devices after idle a period of time.
Because CB:38212 (commit eae254e) caused this issue.
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/84/43284/8
Patch Set 8: Code-Review+2
Patch Set 8:
Done
Patch Set 8:
Please word-wrap the commit message so that lines are no more than 72 characters long. […]
Done
Patrick Georgi has submitted this change. ( https://review.coreboot.org/c/coreboot/+/43284 )
Change-Id: I9e81c2f15dd6babfa360eee213fc4ab6310c7455 Signed-off-by: Wisley Chen wisley.chen@quantatw.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/43284 Reviewed-by: Paul Fagerburg pfagerburg@chromium.org Reviewed-by: Paul Menzel paulepanter@users.sourceforge.net Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/mainboard/google/hatch/variants/dratini/overridetree.cb M src/mainboard/google/hatch/variants/jinlon/overridetree.cb 2 files changed, 0 insertions(+), 2 deletions(-)
Approvals: build bot (Jenkins): Verified Paul Menzel: Looks good to me, but someone else must approve Paul Fagerburg: Looks good to me, approved
