Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/80297?usp=email )
1 is the latest approved patch-set. No files were changed between the latest approved patch-set and the submitted one. )Change subject: soc/amd/phoenix/fch: only init ACPI IO ports in FSP case ......................................................................
Since openSIL configures the APCI IO port addresses, coreboot should not overwrite them.
Signed-off-by: Felix Held felix-coreboot@felixheld.de Change-Id: If10e5a9f52ab313ad1afebd7f9e722994d48b0a7 Reviewed-on: https://review.coreboot.org/c/coreboot/+/80297 Reviewed-by: Matt DeVillier matt.devillier@amd.corp-partner.google.com Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/soc/amd/phoenix/fch.c 1 file changed, 6 insertions(+), 4 deletions(-)
Approvals: Matt DeVillier: Looks good to me, approved build bot (Jenkins): Verified
diff --git a/src/soc/amd/phoenix/fch.c b/src/soc/amd/phoenix/fch.c index e9bc80a..1e03cda 100644 --- a/src/soc/amd/phoenix/fch.c +++ b/src/soc/amd/phoenix/fch.c @@ -89,10 +89,12 @@ * ACPI tables are generated. Enable these ports indiscriminately. */
- pm_write16(PM_EVT_BLK, ACPI_PM_EVT_BLK); - pm_write16(PM1_CNT_BLK, ACPI_PM1_CNT_BLK); - pm_write16(PM_TMR_BLK, ACPI_PM_TMR_BLK); - pm_write16(PM_GPE0_BLK, ACPI_GPE0_BLK); + if (CONFIG(PLATFORM_USES_FSP2_0)) { + pm_write16(PM_EVT_BLK, ACPI_PM_EVT_BLK); + pm_write16(PM1_CNT_BLK, ACPI_PM1_CNT_BLK); + pm_write16(PM_TMR_BLK, ACPI_PM_TMR_BLK); + pm_write16(PM_GPE0_BLK, ACPI_GPE0_BLK); + }
if (CONFIG(HAVE_SMI_HANDLER)) { /* APMC - SMI Command Port */
