Attention is currently required from: Subrata Banik, Paul Menzel, Sridhar Siricilla, Kane Chen. Hello build bot (Jenkins), Subrata Banik, Tim Wawrzynczak, Kane Chen,
https://review.coreboot.org/c/coreboot/+/63169
Change subject: soc/intel/common: Update CSE sub partition update ......................................................................
The patch adds support in the CSE Sub partition update procedure to use GET_BOOT_PARTITION_INFO HECI command output to create the region device for CSE RO and CSE RW. The GET_BOOT_PARTITION_INFO HECI command provides CSE's RO and RW boot partition information.
Existing code relies on FMD file to get the CSE's boot partition's (CSE RO and CSE RW) start and size details. This change make independent of FMD file declaration with respect to CSE RO and CSE RW.
TEST=Build and verify the CSE RO and CSE RW region device information through code instrumentation. Also, did boot test on Kano system.
Signed-off-by: Sridhar Siricilla sridhar.siricilla@intel.com Change-Id: Ie9a83b77ab44ea6ffe5bb20673e109a89a148629 --- M src/soc/intel/common/block/cse/cse_lite.c 1 file changed, 33 insertions(+), 6 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/69/63169/6
