Attention is currently required from: Arthur Heymans, Cliff Huang, David Milosevic, Lance Zhao, Martin L Roth, Maximilian Brune, Patrick Rudolph, Tim Wawrzynczak.
Hello Arthur Heymans, Cliff Huang, Lance Zhao, Maximilian Brune, Tim Wawrzynczak, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/78071?usp=email
to look at the new patch set (#17).
Change subject: acpi: Add PPTT support ......................................................................
This patch adds code to generate Processor Properties Topology Tables (PPTT) compliant to the ACPI 6.4 specification.
- The 'acpi_get_pptt_topology' hook is mandatory once ACPI_PPTT is selected. Its purpose is to return a pointer to a topology tree, which describes the relationship between CPUs and caches. The hook can be provided by, for example, mainboard code.
Background: We are currently working on mainboard code for qemu-sbsa and Neoverse N2. Both require a valid PPTT table. Patch was tested against the qemu-sbsa board.
Change-Id: Ia119e1ba15756704668116bdbc655190ec94ff10 Signed-off-by: David Milosevic David.Milosevic@9elements.com --- M src/acpi/Kconfig M src/acpi/Makefile.inc M src/acpi/acpi.c A src/acpi/acpi_pptt.c M src/include/acpi/acpi.h 5 files changed, 312 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/71/78071/17
