Attention is currently required from: Martin L Roth, Arthur Heymans.
Hello build bot (Jenkins), Martin L Roth,
https://review.coreboot.org/c/coreboot/+/74220
Change subject: util/lint/stable-017: Update full config pattern matching ......................................................................
CONFIG_ARCH gives false positives for CONFIG_USE_EXP_X86_64_SUPPORT so use a different string: 'CONFIG_MAINBOARD_DIR'.
Change-Id: Ie5d4fc4693bc303afb16884c53c9ca4d1778a5cb Signed-off-by: Arthur Heymans arthur@aheymans.xyz --- M util/lint/lint-stable-017-configs 1 file changed, 14 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/20/74220/2
