Attention is currently required from: Arthur Heymans, Felix Singer, Tim Wawrzynczak, Sridhar Siricilla, Angel Pons, Lean Sheng Tan, Werner Zeh, Patrick Rudolph, EricR Lai.
Subrata Banik has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/60405 )
Change subject: soc/intel/common/block/notify: Implement coreboot notify native driver
Patch Set 21:
Commit Message:
https://review.coreboot.org/c/coreboot/+/60405/comment/2ebe1a03_afd495e2
PS19, Line 7: soc/intel/common/block/notify: Implement coreboot notify native driver
Thanks for views.. my worry part is, if you switch off the FSP Notify code, and enables coreboot native code in this regard, then we might end-up loose changes if SOC team adds in the FSP notify API though the changes are optional. My concern is with respect to maintenance.
Valid concern and we can have few strategies to ensure robustness
1. Refer to the SoC platform FAS security chapter and implement those recommended programming (ideally those are meant for OEM/ODM to implement, all IBVs do refer to the same document).
2. Intel can own this piece like what is being done YoY for Cache-as-RAM native code in `soc/intel/common/block/cpu/car`, eNEM as replacement for FSP-T for each SoC program. (on ADL it took several months to validate eNEM and enable finally) In the past we didn't pick FSP-T just to avoid extra enabling time for CAR/eNEM, right?
Please share your thoughts on this.
To view, visit
Gerrit-Project: coreboot
Gerrit-Branch: master
Gerrit-Change-Id: I70bde33f77026e8be165ff082defe3cab6686ec7
Gerrit-Change-Number: 60405
Gerrit-PatchSet: 21
Gerrit-Owner: Subrata Banik
subratabanik@google.com
Gerrit-Reviewer: Angel Pons
th3fanbus@gmail.com
Gerrit-Reviewer: EricR Lai
ericr_lai@compal.corp-partner.google.com
Gerrit-Reviewer: Felix Singer
felixsinger@posteo.net
Gerrit-Reviewer: Lean Sheng Tan
sheng.tan@9elements.com
Gerrit-Reviewer: Patrick Rudolph
siro@das-labor.org
Gerrit-Reviewer: Tim Wawrzynczak
twawrzynczak@chromium.org
Gerrit-Reviewer: Werner Zeh
werner.zeh@siemens.com
no-reply@coreboot.org
Gerrit-CC: Arthur Heymans
arthur.heymans@9elements.com
Gerrit-CC: Paul Menzel
paulepanter@mailbox.org
Gerrit-CC: Rizwan Qureshi
rizwan.qureshi@intel.com
Gerrit-CC: Sridhar Siricilla
sridhar.siricilla@intel.com
Gerrit-Attention: Arthur Heymans
Gerrit-Attention: Felix Singer
Gerrit-Attention: Tim Wawrzynczak
Gerrit-Attention: Sridhar Siricilla
Gerrit-Attention: Angel Pons
th3fanbus@gmail.com
Gerrit-Attention: Lean Sheng Tan
Gerrit-Attention: Werner Zeh
Gerrit-Attention: Patrick Rudolph
siro@das-labor.org
Gerrit-Attention: EricR Lai
Gerrit-Comment-Date: Wed, 02 Feb 2022 18:23:06 +0000
Gerrit-HasComments: Yes
Gerrit-Has-Labels: No
Comment-In-Reply-To: Arthur Heymans
Comment-In-Reply-To: Subrata Banik
Comment-In-Reply-To: Sridhar Siricilla
Comment-In-Reply-To: Angel Pons
th3fanbus@gmail.com
Comment-In-Reply-To: Lean Sheng Tan
Gerrit-MessageType: comment
