EricR Lai has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/48944 )
Change subject: soc/amd/picasso: Add GRXS and GTXS method ......................................................................
Add GRXS and GTXS into gpiolib. We can align with Intel ACPI method for the better usage. This benefit acpi.c to be more clear, too.
BUG=b:176270381 BRANCH=zork TEST=Confirm the Goodix touchscreen functional.
Signed-off-by: Eric Lai ericr_lai@compal.corp-partner.google.com Change-Id: I1aa6a8f44f20577e679336889c849dd67cb99f2d --- M src/soc/amd/common/acpi/gpio_bank_lib.asl M src/soc/amd/picasso/acpi.c 2 files changed, 40 insertions(+), 40 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/44/48944/1
diff --git a/src/soc/amd/common/acpi/gpio_bank_lib.asl b/src/soc/amd/common/acpi/gpio_bank_lib.asl index eb13ab9..b142be5 100644 --- a/src/soc/amd/common/acpi/gpio_bank_lib.asl +++ b/src/soc/amd/common/acpi/gpio_bank_lib.asl @@ -2,6 +2,8 @@
#include <soc/iomap.h>
+#define GPIO_INPUT_SHIFT 16 +#define GPIO_INPUT_VALUE (1 << GPIO_INPUT_SHIFT) #define GPIO_OUTPUT_SHIFT 22 #define GPIO_OUTPUT_VALUE (1 << GPIO_OUTPUT_SHIFT)
@@ -148,3 +150,35 @@ } VAL0 &= ~GPIO_OUTPUT_VALUE } + +/* + * Get GPIO Rx Value + * Arg0 - GPIO Number + */ +Method (GRXS, 1, Serialized) +{ + OperationRegion (PREG, SystemMemory, GPAD (Arg0), 4) + Field (PREG, AnyAcc, NoLock, Preserve) + { + VAL0, 32 + } + Local0 = (GPIO_INPUT_VALUE & VAL0) >> GPIO_INPUT_SHIFT + + Return (Local0) +} + +/* + * Get GPIO Tx Value + * Arg0 - GPIO Number + */ +Method (GTXS, 1, Serialized) +{ + OperationRegion (PREG, SystemMemory, GPAD (Arg0), 4) + Field (PREG, AnyAcc, NoLock, Preserve) + { + VAL0, 32 + } + Local0 = (GPIO_OUTPUT_VALUE & VAL0) >> GPIO_OUTPUT_SHIFT + + Return (Local0) +} diff --git a/src/soc/amd/picasso/acpi.c b/src/soc/amd/picasso/acpi.c index 63ba26c..ef0d6e2 100644 --- a/src/soc/amd/picasso/acpi.c +++ b/src/soc/amd/picasso/acpi.c @@ -431,57 +431,23 @@ } }
-static void acpigen_soc_get_gpio_in_local5(uintptr_t addr) +static int acpigen_soc_get_gpio_state(const char *op, unsigned int gpio_num) { - /* - * Store (_SB.GPR2 (addr), Local5) - * _SB.GPR2 is used to read control byte 2 from control register. - * / It is defined in gpio_lib.asl. - */ + /* Store (op (gpio_num), Local0) */ acpigen_write_store(); - acpigen_emit_namestring("\_SB.GPR2"); - acpigen_write_integer(addr); - acpigen_emit_byte(LOCAL5_OP); -} - -static int acpigen_soc_get_gpio_val(unsigned int gpio_num, uint32_t mask) -{ - if (gpio_num >= SOC_GPIO_TOTAL_PINS) { - printk(BIOS_WARNING, "Warning: Pin %d should be smaller than" - " %d\n", gpio_num, SOC_GPIO_TOTAL_PINS); - return -1; - } - uintptr_t addr = gpio_get_address(gpio_num); - - acpigen_soc_get_gpio_in_local5(addr); - - /* If (And (Local5, mask)) */ - acpigen_write_if_and(LOCAL5_OP, mask); - - /* Store (One, Local0) */ - acpigen_write_store_ops(ONE_OP, LOCAL0_OP); - - acpigen_pop_len(); /* If */ - - /* Else */ - acpigen_write_else(); - - /* Store (Zero, Local0) */ - acpigen_write_store_ops(ZERO_OP, LOCAL0_OP); - - acpigen_pop_len(); /* Else */ - + acpigen_soc_gpio_op(op, gpio_num); + acpigen_emit_byte(LOCAL0_OP); return 0; }
int acpigen_soc_read_rx_gpio(unsigned int gpio_num) { - return acpigen_soc_get_gpio_val(gpio_num, GPIO_PIN_IN); + return acpigen_soc_get_gpio_state("\_SB.GRXS", gpio_num); }
int acpigen_soc_get_tx_gpio(unsigned int gpio_num) { - return acpigen_soc_get_gpio_val(gpio_num, GPIO_PIN_OUT); + return acpigen_soc_get_gpio_state("\_SB.GTXS", gpio_num); }
static int acpigen_soc_gpio_op(const char *op, unsigned int gpio_num)
Hello build bot (Jenkins), Jason Glenesk, Marshall Dawson, Felix Held,
Signed-off-by: Eric Lai ericr_lai@compal.corp-partner.google.com Change-Id: I1aa6a8f44f20577e679336889c849dd67cb99f2d --- M src/soc/amd/common/acpi/gpio_bank_lib.asl M src/soc/amd/picasso/acpi.c 2 files changed, 53 insertions(+), 53 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/44/48944/2
EricR Lai has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/48944 )
Patch Set 2:
@AMD, please help review this, I want we can use this in cezanne for guybrush project :)
Hello build bot (Jenkins), Jason Glenesk, Furquan Shaikh, Marshall Dawson, Mathew King, Tim Wawrzynczak, Kyösti Mälkki, chris wang, Felix Held,
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/44/48944/3
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/44/48944/4
Tim Wawrzynczak has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/48944 )
Patch Set 4: Code-Review+1
Felix Held has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/48944 )
Patch Set 4:
https://review.coreboot.org/c/coreboot/+/48944/4/src/soc/amd/picasso/acpi.c File src/soc/amd/picasso/acpi.c:
https://review.coreboot.org/c/coreboot/+/48944/4/src/soc/amd/picasso/acpi.c@... PS4, Line 444: { keep the check for the upper bound of gpio_num in here?
Patch Set 5:
Done
Signed-off-by: Eric Lai ericr_lai@compal.corp-partner.google.com Change-Id: I1aa6a8f44f20577e679336889c849dd67cb99f2d --- M src/soc/amd/common/acpi/gpio_bank_lib.asl M src/soc/amd/picasso/acpi.c 2 files changed, 58 insertions(+), 53 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/44/48944/6
Patch Set 6: Code-Review+2
Paul Menzel has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/48944 )
Patch Set 6:
(2 comments)
https://review.coreboot.org/c/coreboot/+/48944/6//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/48944/6//COMMIT_MSG@9 PS6, Line 9: Intel ACPI method If they are the same, could they be shared?
https://review.coreboot.org/c/coreboot/+/48944/6//COMMIT_MSG@10 PS6, Line 10: benefit benefits
Add GRXS and GTXS into gpiolib. We can align with Intel ACPI method for the better usage. This benefits acpi.c to be more clear, too.
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/44/48944/7
Patch Set 8:
benefits
Done
Patch Set 8:
No.
Furquan Shaikh has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/48944 )
Patch Set 8: Code-Review+2
https://review.coreboot.org/c/coreboot/+/48944/8/src/soc/amd/common/acpi/gpi... File src/soc/amd/common/acpi/gpio_bank_lib.asl:
https://review.coreboot.org/c/coreboot/+/48944/8/src/soc/amd/common/acpi/gpi... PS8, Line 5: #define GPIO_INPUT_SHIFT 16 : #define GPIO_INPUT_VALUE (1 << GPIO_INPUT_SHIFT) Same comment as previous CL.
Patch Set 8:
We can do clean up by move some define out of gpiobank. But should decide by AMD team.
Ack
Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/48944 )
Signed-off-by: Eric Lai ericr_lai@compal.corp-partner.google.com Change-Id: I1aa6a8f44f20577e679336889c849dd67cb99f2d Reviewed-on: https://review.coreboot.org/c/coreboot/+/48944 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Furquan Shaikh furquan@google.com Reviewed-by: Felix Held felix-coreboot@felixheld.de --- M src/soc/amd/common/acpi/gpio_bank_lib.asl M src/soc/amd/picasso/acpi.c 2 files changed, 58 insertions(+), 53 deletions(-)
Approvals: build bot (Jenkins): Verified Felix Held: Looks good to me, approved Furquan Shaikh: Looks good to me, approved
diff --git a/src/soc/amd/common/acpi/gpio_bank_lib.asl b/src/soc/amd/common/acpi/gpio_bank_lib.asl index f209f44..8640cc1 100644 --- a/src/soc/amd/common/acpi/gpio_bank_lib.asl +++ b/src/soc/amd/common/acpi/gpio_bank_lib.asl @@ -2,6 +2,8 @@
@@ -148,3 +150,35 @@ } VAL0 &= ~GPIO_OUTPUT_VALUE } + +/* + * Get GPIO Input Value + * Arg0 - GPIO Number + */ +Method (GRXS, 1, Serialized) +{ + OperationRegion (GPDW, SystemMemory, GPAD (Arg0), 4) + Field (GPDW, AnyAcc, NoLock, Preserve) + { + VAL0, 32 + } + Local0 = (GPIO_INPUT_VALUE & VAL0) >> GPIO_INPUT_SHIFT + + Return (Local0) +} + +/* + * Get GPIO Output Value + * Arg0 - GPIO Number + */ +Method (GTXS, 1, Serialized) +{ + OperationRegion (GPDW, SystemMemory, GPAD (Arg0), 4) + Field (GPDW, AnyAcc, NoLock, Preserve) + { + VAL0, 32 + } + Local0 = (GPIO_OUTPUT_VALUE & VAL0) >> GPIO_OUTPUT_SHIFT + + Return (Local0) +} diff --git a/src/soc/amd/picasso/acpi.c b/src/soc/amd/picasso/acpi.c index 445815a..b89974b 100644 --- a/src/soc/amd/picasso/acpi.c +++ b/src/soc/amd/picasso/acpi.c @@ -432,59 +432,6 @@ } }
-static void acpigen_soc_get_gpio_in_local5(uintptr_t addr) -{ - /* - * Store (_SB.GPR2 (addr), Local5) - * _SB.GPR2 is used to read control byte 2 from control register. - * / It is defined in gpio_lib.asl. - */ - acpigen_write_store(); - acpigen_emit_namestring("\_SB.GPR2"); - acpigen_write_integer(addr); - acpigen_emit_byte(LOCAL5_OP); -} - -static int acpigen_soc_get_gpio_val(unsigned int gpio_num, uint32_t mask) -{ - if (gpio_num >= SOC_GPIO_TOTAL_PINS) { - printk(BIOS_WARNING, "Warning: Pin %d should be smaller than" - " %d\n", gpio_num, SOC_GPIO_TOTAL_PINS); - return -1; - } - uintptr_t addr = gpio_get_address(gpio_num); - - acpigen_soc_get_gpio_in_local5(addr); - - /* If (And (Local5, mask)) */ - acpigen_write_if_and(LOCAL5_OP, mask); - - /* Store (One, Local0) */ - acpigen_write_store_ops(ONE_OP, LOCAL0_OP); - - acpigen_pop_len(); /* If */ - - /* Else */ - acpigen_write_else(); - - /* Store (Zero, Local0) */ - acpigen_write_store_ops(ZERO_OP, LOCAL0_OP); - - acpigen_pop_len(); /* Else */ - - return 0; -} - -int acpigen_soc_read_rx_gpio(unsigned int gpio_num) -{ - return acpigen_soc_get_gpio_val(gpio_num, GPIO_PIN_IN); -} - -int acpigen_soc_get_tx_gpio(unsigned int gpio_num) -{ - return acpigen_soc_get_gpio_val(gpio_num, GPIO_PIN_OUT); -} - static int acpigen_soc_gpio_op(const char *op, unsigned int gpio_num) { if (gpio_num >= SOC_GPIO_TOTAL_PINS) { @@ -498,6 +445,30 @@ return 0; }
+static int acpigen_soc_get_gpio_state(const char *op, unsigned int gpio_num) +{ + if (gpio_num >= SOC_GPIO_TOTAL_PINS) { + printk(BIOS_WARNING, "Warning: Pin %d should be smaller than" + " %d\n", gpio_num, SOC_GPIO_TOTAL_PINS); + return -1; + } + /* Store (op (gpio_num), Local0) */ + acpigen_write_store(); + acpigen_soc_gpio_op(op, gpio_num); + acpigen_emit_byte(LOCAL0_OP); + return 0; +} + +int acpigen_soc_read_rx_gpio(unsigned int gpio_num) +{ + return acpigen_soc_get_gpio_state("\_SB.GRXS", gpio_num); +} + +int acpigen_soc_get_tx_gpio(unsigned int gpio_num) +{ + return acpigen_soc_get_gpio_state("\_SB.GTXS", gpio_num); +} + int acpigen_soc_set_tx_gpio(unsigned int gpio_num) { return acpigen_soc_gpio_op("\_SB.STXS", gpio_num);
