HAOUAS Elyes has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/38787 )
Change subject: crossgcc: Upgrade GDB to version 9.1 ......................................................................
Change-Id: I30dae356ec3b373ac036c7eced7d6e89ddd08246 Signed-off-by: Elyes HAOUAS ehaouas@noos.fr --- M util/crossgcc/buildgcc D util/crossgcc/patches/gdb-8.3.1_no-doc.patch R util/crossgcc/patches/gdb-9.1_amd64.patch A util/crossgcc/patches/gdb-9.1_no-doc.patch R util/crossgcc/patches/gdb-9.1_pythonhome.patch D util/crossgcc/sum/gdb-8.3.1.tar.xz.cksum A util/crossgcc/sum/gdb-9.1.tar.xz.cksum 7 files changed, 13 insertions(+), 14 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/87/38787/1
diff --git a/util/crossgcc/buildgcc b/util/crossgcc/buildgcc index 9920799..9fe14d0 100755 --- a/util/crossgcc/buildgcc +++ b/util/crossgcc/buildgcc @@ -53,7 +53,7 @@ GCC_VERSION=9.2.0 GCC_AUTOCONF_VERSION=2.69 BINUTILS_VERSION=2.33.1 -GDB_VERSION=8.3.1 +GDB_VERSION=9.1 IASL_VERSION=20200110 PYTHON_VERSION=3.8.1 EXPAT_VERSION=2.2.9 diff --git a/util/crossgcc/patches/gdb-8.3.1_no-doc.patch b/util/crossgcc/patches/gdb-8.3.1_no-doc.patch deleted file mode 100644 index 80dd349..0000000 --- a/util/crossgcc/patches/gdb-8.3.1_no-doc.patch +++ /dev/null @@ -1,12 +0,0 @@ -diff -urN gdb-8.0.orig/gdb/Makefile.in gdb-8.0/gdb/Makefile.in ---- gdb-8.2.1.orig/gdb/Makefile.in 2019-01-04 12:58:10.227572419 +0100 -+++ gdb-8.2.1/gdb/Makefile.in 2019-01-04 12:59:00.539134274 +0100 -@@ -1568,7 +1568,7 @@ - - TSOBS = inflow.o - --SUBDIRS = doc @subdirs@ data-directory $(GNULIB_BUILDDIR) -+SUBDIRS = @subdirs@ data-directory $(GNULIB_BUILDDIR) - CLEANDIRS = $(SUBDIRS) - - # List of subdirectories in the build tree that must exist. diff --git a/util/crossgcc/patches/gdb-8.3.1_amd64.patch b/util/crossgcc/patches/gdb-9.1_amd64.patch similarity index 100% rename from util/crossgcc/patches/gdb-8.3.1_amd64.patch rename to util/crossgcc/patches/gdb-9.1_amd64.patch diff --git a/util/crossgcc/patches/gdb-9.1_no-doc.patch b/util/crossgcc/patches/gdb-9.1_no-doc.patch new file mode 100644 index 0000000..59ca998 --- /dev/null +++ b/util/crossgcc/patches/gdb-9.1_no-doc.patch @@ -0,0 +1,11 @@ +--- gdb-9.1.orig/gdb/Makefile.in 2020-02-08 13:50:14.000000000 +0100 ++++ gdb-9.1/gdb/Makefile.in 2020-02-08 20:11:17.201244042 +0100 +@@ -1606,7 +1606,7 @@ + $(SUBDIR_TARGET_OBS) \ + $(SUBDIR_GCC_COMPILE_OBS) + +-SUBDIRS = doc @subdirs@ data-directory ++SUBDIRS = @subdirs@ data-directory + CLEANDIRS = $(SUBDIRS) + + # List of subdirectories in the build tree that must exist. diff --git a/util/crossgcc/patches/gdb-8.3.1_pythonhome.patch b/util/crossgcc/patches/gdb-9.1_pythonhome.patch similarity index 100% rename from util/crossgcc/patches/gdb-8.3.1_pythonhome.patch rename to util/crossgcc/patches/gdb-9.1_pythonhome.patch diff --git a/util/crossgcc/sum/gdb-8.3.1.tar.xz.cksum b/util/crossgcc/sum/gdb-8.3.1.tar.xz.cksum deleted file mode 100644 index c362858..0000000 --- a/util/crossgcc/sum/gdb-8.3.1.tar.xz.cksum +++ /dev/null @@ -1 +0,0 @@ -d403ba208945bbf04f8130ea4853730cdf0c8fc7 tarballs/gdb-8.3.1.tar.xz diff --git a/util/crossgcc/sum/gdb-9.1.tar.xz.cksum b/util/crossgcc/sum/gdb-9.1.tar.xz.cksum new file mode 100644 index 0000000..b65b5e9 --- /dev/null +++ b/util/crossgcc/sum/gdb-9.1.tar.xz.cksum @@ -0,0 +1 @@ +a50e13e1eecea468ea28c4a23d8c5a84f4db25be tarballs/gdb-9.1.tar.xz
Paul Menzel has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/38787 )
Patch Set 1: Code-Review+1
HAOUAS Elyes has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/38787 )
Patch Set 3:
This change is ready for review.
Hello Paul Menzel, build bot (Jenkins), Martin Roth, Patrick Georgi,
Change subject: [WIP]crossgcc: Upgrade GDB to version 9.1 ......................................................................
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/87/38787/4
Hello build bot (Jenkins), Martin Roth, Patrick Georgi, Paul Menzel,
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/87/38787/6
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/87/38787/7
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/87/38787/8
Change subject: crossgcc: Upgrade GDB to version 9.2 ......................................................................
Change-Id: I30dae356ec3b373ac036c7eced7d6e89ddd08246 Signed-off-by: Elyes HAOUAS ehaouas@noos.fr --- M util/crossgcc/buildgcc D util/crossgcc/patches/gdb-8.3.1_no-doc.patch R util/crossgcc/patches/gdb-9.2_amd64.patch A util/crossgcc/patches/gdb-9.2_no-doc.patch R util/crossgcc/patches/gdb-9.2_pythonhome.patch D util/crossgcc/sum/gdb-8.3.1.tar.xz.cksum A util/crossgcc/sum/gdb-9.2.tar.xz.cksum 7 files changed, 13 insertions(+), 14 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/87/38787/11
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/87/38787/12
Patch Set 12:
ok, let try to solve the "Merge Conflict".
to look at the new patch set (#13).
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/87/38787/13
Nico Huber has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/38787 )
Patch Set 13: Code-Review+2
Nico Huber has submitted this change. ( https://review.coreboot.org/c/coreboot/+/38787 )
Change-Id: I30dae356ec3b373ac036c7eced7d6e89ddd08246 Signed-off-by: Elyes HAOUAS ehaouas@noos.fr Reviewed-on: https://review.coreboot.org/c/coreboot/+/38787 Reviewed-by: Nico Huber nico.h@gmx.de Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M util/crossgcc/buildgcc D util/crossgcc/patches/gdb-8.3.1_no-doc.patch R util/crossgcc/patches/gdb-9.2_amd64.patch A util/crossgcc/patches/gdb-9.2_no-doc.patch R util/crossgcc/patches/gdb-9.2_pythonhome.patch D util/crossgcc/sum/gdb-8.3.1.tar.xz.cksum A util/crossgcc/sum/gdb-9.2.tar.xz.cksum 7 files changed, 13 insertions(+), 14 deletions(-)
Approvals: build bot (Jenkins): Verified Nico Huber: Looks good to me, approved
diff --git a/util/crossgcc/buildgcc b/util/crossgcc/buildgcc index 180ac1a..2e5b2d0 100755 --- a/util/crossgcc/buildgcc +++ b/util/crossgcc/buildgcc @@ -39,7 +39,7 @@ GCC_VERSION=8.3.0 GCC_AUTOCONF_VERSION=2.69 BINUTILS_VERSION=2.33.1 -GDB_VERSION=8.3.1 +GDB_VERSION=9.2 IASL_VERSION=20200110 PYTHON_VERSION=3.8.1 EXPAT_VERSION=2.2.9 diff --git a/util/crossgcc/patches/gdb-8.3.1_no-doc.patch b/util/crossgcc/patches/gdb-8.3.1_no-doc.patch deleted file mode 100644 index 80dd349..0000000 --- a/util/crossgcc/patches/gdb-8.3.1_no-doc.patch +++ /dev/null @@ -1,12 +0,0 @@ -diff -urN gdb-8.0.orig/gdb/Makefile.in gdb-8.0/gdb/Makefile.in ---- gdb-8.2.1.orig/gdb/Makefile.in 2019-01-04 12:58:10.227572419 +0100 -+++ gdb-8.2.1/gdb/Makefile.in 2019-01-04 12:59:00.539134274 +0100 -@@ -1568,7 +1568,7 @@ - - TSOBS = inflow.o - --SUBDIRS = doc @subdirs@ data-directory $(GNULIB_BUILDDIR) -+SUBDIRS = @subdirs@ data-directory $(GNULIB_BUILDDIR) - CLEANDIRS = $(SUBDIRS) - - # List of subdirectories in the build tree that must exist. diff --git a/util/crossgcc/patches/gdb-8.3.1_amd64.patch b/util/crossgcc/patches/gdb-9.2_amd64.patch similarity index 100% rename from util/crossgcc/patches/gdb-8.3.1_amd64.patch rename to util/crossgcc/patches/gdb-9.2_amd64.patch diff --git a/util/crossgcc/patches/gdb-9.2_no-doc.patch b/util/crossgcc/patches/gdb-9.2_no-doc.patch new file mode 100644 index 0000000..59ca998 --- /dev/null +++ b/util/crossgcc/patches/gdb-9.2_no-doc.patch @@ -0,0 +1,11 @@ +--- gdb-9.1.orig/gdb/Makefile.in 2020-02-08 13:50:14.000000000 +0100 ++++ gdb-9.1/gdb/Makefile.in 2020-02-08 20:11:17.201244042 +0100 +@@ -1606,7 +1606,7 @@ + $(SUBDIR_TARGET_OBS) \ + $(SUBDIR_GCC_COMPILE_OBS) + +-SUBDIRS = doc @subdirs@ data-directory ++SUBDIRS = @subdirs@ data-directory + CLEANDIRS = $(SUBDIRS) + + # List of subdirectories in the build tree that must exist. diff --git a/util/crossgcc/patches/gdb-8.3.1_pythonhome.patch b/util/crossgcc/patches/gdb-9.2_pythonhome.patch similarity index 100% rename from util/crossgcc/patches/gdb-8.3.1_pythonhome.patch rename to util/crossgcc/patches/gdb-9.2_pythonhome.patch diff --git a/util/crossgcc/sum/gdb-8.3.1.tar.xz.cksum b/util/crossgcc/sum/gdb-8.3.1.tar.xz.cksum deleted file mode 100644 index c362858..0000000 --- a/util/crossgcc/sum/gdb-8.3.1.tar.xz.cksum +++ /dev/null @@ -1 +0,0 @@ -d403ba208945bbf04f8130ea4853730cdf0c8fc7 tarballs/gdb-8.3.1.tar.xz diff --git a/util/crossgcc/sum/gdb-9.2.tar.xz.cksum b/util/crossgcc/sum/gdb-9.2.tar.xz.cksum new file mode 100644 index 0000000..8bbc448 --- /dev/null +++ b/util/crossgcc/sum/gdb-9.2.tar.xz.cksum @@ -0,0 +1 @@ +356ee474a24bfb2f133894730916557dfea9da2e tarballs/gdb-9.2.tar.xz
