Patrick Georgi (pgeorgi@google.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/18048
commit 171b3716b5a77efc9b403c06426279fcafb906a0 Author: Patrick Georgi pgeorgi@chromium.org Date: Sat Jan 7 09:28:43 2017 +0100
buildgcc: try curl if wget is not present
There are systems that come with curl but not wget (eg macOS) and they now have to install one less additional dependency.
Change-Id: Idc2ce892fbb6629aebfe1ae2a95dcef4d5d93aca Signed-off-by: Patrick Georgi pgeorgi@chromium.org --- util/crossgcc/buildgcc | 36 +++++++++++++++++++++--------------- 1 file changed, 21 insertions(+), 15 deletions(-)
diff --git a/util/crossgcc/buildgcc b/util/crossgcc/buildgcc index 0dfca26..1cefcd5 100755 --- a/util/crossgcc/buildgcc +++ b/util/crossgcc/buildgcc @@ -130,9 +130,9 @@ please_install() *) solution="using your OS packaging system" ;; esac
- printf "${RED}ERROR:${red} Missing tool: Please install '$1'. (eg $solution)${NC}\n" >&2 + printf "${RED}ERROR:${red} Missing tool: Please install '$1'. (eg $solution)${NC}\n" >&2 if [ -n "$2" ]; then - printf "${RED}ERROR:${red} or install '$2'.${NC}\n" >&2 + printf "${RED}ERROR:${red} or install '$2'.${NC}\n" >&2 fi }
@@ -282,15 +282,6 @@ compute_sum() { printf "(checksum created. ${RED}Note. Please upload sum/$1.cksum if the corresponding archive is upgraded.)${NC}" }
-download_showing_percentage() { - url=$1 - printf " ..${red} 0%%" - wget --no-check-certificate $url 2>&1 | while read line; do - echo $line | grep -o "[0-9]+%" | awk '{printf("\b\b\b\b%4s", $1)}' - done - printf "${NC}" -} - download() { package=$1 archive="$(eval echo $$package"_ARCHIVE")" @@ -299,7 +290,7 @@ download() { printf " * $FILE "
if test -f tarballs/$FILE && check_sum $FILE ; then - printf "(cached)" + echo "(cached)" else printf "(downloading from $archive)" rm -f tarballs/$FILE @@ -310,10 +301,9 @@ download() { fi
if [ ! -f tarballs/$FILE ]; then - printf "\n${RED}Failed to download $FILE.${NC}\n" + printf "${RED}Failed to download $FILE.${NC}\n" exit 1 fi - printf "\n" }
unpack_and_patch() { @@ -891,9 +881,25 @@ searchtool flex flex > /dev/null searchtool g++ "Free Software Foundation" nofail > /dev/null || \ searchtool clang "clang version" nofail > /dev/null || \ searchtool clang "LLVM" "" "g++" > /dev/null -searchtool wget > /dev/null searchtool bzip2 "bzip2," > /dev/null
+if searchtool wget "GNU" nofail > /dev/null; then + download_showing_percentage() { + url=$1 + printf " ..${red} 0%%" + wget $url 2>&1 | while read line; do + echo $line | grep -o "[0-9]+%" | awk '{printf("\b\b\b\b%4s", $1)}' + done + echo "${NC}" + } +elif searchtool curl "^curl " > /dev/null; then + download_showing_percentage() { + url=$1 + echo + curl -#OL $url + } +fi + check_for_library "-lz" "zlib (zlib1g-dev or zlib-devel)"
CC=cc
