Attention is currently required from: Tim Wawrzynczak, Ravindra, Sridhar Siricilla, Krishna P Bhat D, Patrick Rudolph, Ravindra N. Hello build bot (Jenkins), Tim Wawrzynczak, Sridhar Siricilla, Krishna P Bhat D, Patrick Rudolph, Ravindra N,
https://review.coreboot.org/c/coreboot/+/59895
Change subject: soc/intel/cse: config to enable oem key manifest ......................................................................
CB change will enable the CSE region sub-partition OEMP, where the OEMP binary will be stitched.
BUG=b:207820413 TEST: Boot to kernel and check for the ipu authentication is successful localhost ~ # dmesg | grep -i ipu [ 9.206568] intel-ipu6 intel-ipu: IPU in secure mode [ 9.218917] intel-ipu6 intel-ipu: IPC reset done [ 9.226160] intel-ipu6 intel-ipu: cpd file name: intel/ipu6ep_fw.bin [ 9.265134] intel-ipu6 intel-ipu: FW version: 20201224 [ 9.298977] intel-ipu6 intel-ipu: Sending BOOT_LOAD to CSE [ 9.314555] intel-ipu6 intel-ipu: Sending AUTHENTICATE_RUN to CSE [ 9.390078] intel-ipu6 intel-ipu: CSE authenticate_run done [ 9.396530] intel-ipu6 intel-ipu: IPU driver version 1.0
Cq-Depend: chromium:3291463 config.baseboard.brya: config to support oem key manifest | https://chromium-review.googlesource.com/c/chromiumos/overlays/chromiumos-ov... Signed-off-by: Ravindra N ravindra@intel.corp-partner.google.com Change-Id: I3620adb2898efc002104e0ba8b2afd219c31f230 --- M src/soc/intel/alderlake/Makefile.inc M src/soc/intel/common/block/cse/Kconfig 2 files changed, 5 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/95/59895/4
