Attention is currently required from: Furquan Shaikh, Dtrain Hsu, Henry Sun, Tim Wawrzynczak. Hello build bot (Jenkins), Furquan Shaikh, Henry Sun, Tim Wawrzynczak, Karthik Ramasubramanian,
https://review.coreboot.org/c/coreboot/+/54057
Change subject: mb/google/dedede/var/cret: Enable/disable LTE function based on FW_CONFIG ......................................................................
Enable/disable LTE function based on LTE bit of FW_CONFIG. The LTE function settings are included GPIO settings, USB port settings and power off sequence.
BUG=b:187797408 BRANCH=dedede TEST=Build and test the change on cret.
Signed-off-by: Dtrain Hsu dtrain_hsu@compal.corp-partner.google.com Change-Id: Ib926e99aaf9df433a7cff71180ee55431d69f718 --- M src/mainboard/google/dedede/variants/baseboard/devicetree.cb M src/mainboard/google/dedede/variants/cret/gpio.c M src/mainboard/google/dedede/variants/cret/overridetree.cb 3 files changed, 25 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/57/54057/4
