Patrick Georgi has submitted this change and it was merged. ( https://review.coreboot.org/c/coreboot/+/29955 )
Change subject: qcs405: Add GPIO API ......................................................................
Introduce new and required GPIO APIs, using common pinmux definitions for GPIO configuration.
TEST=build & run
Change-Id: I85ce9007c545b44371c4704a0456774d0eff12a8 Signed-off-by: Sricharan R sricharan@codeaurora.org Signed-off-by: Nitheesh Sekar nsekar@codeaurora.org Reviewed-on: https://review.coreboot.org/c/coreboot/+/29955 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Patrick Georgi pgeorgi@google.com --- M src/soc/qualcomm/qcs405/Makefile.inc A src/soc/qualcomm/qcs405/gpio.c A src/soc/qualcomm/qcs405/include/soc/addressmap.h M src/soc/qualcomm/qcs405/include/soc/gpio.h 4 files changed, 400 insertions(+), 2 deletions(-)
diff --git a/src/soc/qualcomm/qcs405/Makefile.inc b/src/soc/qualcomm/qcs405/Makefile.inc index 2d1f842..c702264 100644 --- a/src/soc/qualcomm/qcs405/Makefile.inc +++ b/src/soc/qualcomm/qcs405/Makefile.inc @@ -6,21 +6,25 @@ bootblock-y += timer.c bootblock-y += spi.c bootblock-y += mmu.c +bootblock-y += gpio.c
################################################################################ verstage-y += timer.c verstage-y += spi.c +verstage-y += gpio.c
################################################################################ romstage-y += timer.c romstage-y += spi.c romstage-y += cbmem.c +romstage-y += gpio.c
################################################################################ ramstage-y += soc.c ramstage-y += timer.c ramstage-y += spi.c ramstage-y += cbmem.c +ramstage-y += gpio.c
diff --git a/src/soc/qualcomm/qcs405/gpio.c b/src/soc/qualcomm/qcs405/gpio.c new file mode 100644 index 0000000..db8b7a1 --- /dev/null +++ b/src/soc/qualcomm/qcs405/gpio.c @@ -0,0 +1,76 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2018-2019 Qualcomm Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <device/mmio.h> +#include <types.h> +#include <console/console.h> +#include <delay.h> +#include <timer.h> +#include <timestamp.h> + +#include <gpio.h> + +void gpio_configure(gpio_t gpio, uint32_t func, uint32_t pull, + uint32_t drive_str, uint32_t enable) +{ + uint32_t reg_val; + struct tlmm_gpio *regs = (void *)(uintptr_t)gpio.addr; + + reg_val = ((enable & GPIO_CFG_OE_BMSK) << GPIO_CFG_OE_SHFT) | + ((drive_str & GPIO_CFG_DRV_BMSK) << GPIO_CFG_DRV_SHFT) | + ((func & GPIO_CFG_FUNC_BMSK) << GPIO_CFG_FUNC_SHFT) | + ((pull & GPIO_CFG_PULL_BMSK) << GPIO_CFG_PULL_SHFT); + + write32(®s->cfg, reg_val); +} + +void gpio_set(gpio_t gpio, int value) +{ + struct tlmm_gpio *regs = (void *)(uintptr_t)gpio.addr; + write32(®s->in_out, (!!value) << GPIO_IO_OUT_SHFT); +} + +int gpio_get(gpio_t gpio) +{ + struct tlmm_gpio *regs = (void *)(uintptr_t)gpio.addr; + + return ((read32(®s->in_out) >> GPIO_IO_IN_SHFT) & + GPIO_IO_IN_BMSK); +} + +void gpio_input_pulldown(gpio_t gpio) +{ + gpio_configure(gpio, GPIO_FUNC_GPIO, + GPIO_PULL_DOWN, GPIO_2MA, GPIO_DISABLE); +} + +void gpio_input_pullup(gpio_t gpio) +{ + gpio_configure(gpio, GPIO_FUNC_GPIO, + GPIO_PULL_UP, GPIO_2MA, GPIO_DISABLE); +} + +void gpio_input(gpio_t gpio) +{ + gpio_configure(gpio, GPIO_FUNC_GPIO, + GPIO_NO_PULL, GPIO_2MA, GPIO_DISABLE); +} + +void gpio_output(gpio_t gpio, int value) +{ + gpio_set(gpio, value); + gpio_configure(gpio, GPIO_FUNC_GPIO, + GPIO_NO_PULL, GPIO_2MA, GPIO_ENABLE); +} diff --git a/src/soc/qualcomm/qcs405/include/soc/addressmap.h b/src/soc/qualcomm/qcs405/include/soc/addressmap.h new file mode 100644 index 0000000..c85341b --- /dev/null +++ b/src/soc/qualcomm/qcs405/include/soc/addressmap.h @@ -0,0 +1,26 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (c) 2018-2019 Qualcomm Technologies + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 and + * only version 2 as published by the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef __SOC_QUALCOMM_QCS405_ADDRESS_MAP_H__ +#define __SOC_QUALCOMM_QCS405_ADDRESS_MAP_H__ + +#include <stdint.h> + +#define QSPI_BASE 0x88DF000 +#define TLMM_EAST_TILE_BASE 0x7B00000 +#define TLMM_NORTH_TILE_BASE 0x1300000 +#define TLMM_SOUTH_TILE_BASE 0x1000000 + +#endif /* __SOC_QUALCOMM_QCS405_ADDRESS_MAP_H__ */ diff --git a/src/soc/qualcomm/qcs405/include/soc/gpio.h b/src/soc/qualcomm/qcs405/include/soc/gpio.h index e1ad453..fce4350 100644 --- a/src/soc/qualcomm/qcs405/include/soc/gpio.h +++ b/src/soc/qualcomm/qcs405/include/soc/gpio.h @@ -1,7 +1,7 @@ /* * This file is part of the coreboot project. * - * Copyright (C) 2018, The Linux Foundation. All rights reserved. + * Copyright (C) 2018-2019, The Linux Foundation. All rights reserved. * * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License version 2 and @@ -17,7 +17,299 @@ #define _SOC_QUALCOMM_QCS405_GPIO_H_
#include <types.h> +#include <soc/addressmap.h>
-typedef u32 gpio_t; +typedef struct { + u32 addr; +} gpio_t; + +#define TLMM_TILE_SIZE 0x00400000 +#define TLMM_GPIO_OFF_DELTA 0x00001000 +#define TLMM_GPIO_TILE_NUM 3 + +#define TLMM_GPIO_IN_OUT_OFF 0x4 +#define TLMM_GPIO_ID_STATUS_OFF 0x10 + +/* GPIO TLMM: Direction */ +#define GPIO_INPUT 0 +#define GPIO_OUTPUT 1 + +/* GPIO TLMM: Pullup/Pulldown */ +#define GPIO_NO_PULL 0 +#define GPIO_PULL_DOWN 1 +#define GPIO_KEEPER 2 +#define GPIO_PULL_UP 3 + +/* GPIO TLMM: Drive Strength */ +#define GPIO_2MA 0 +#define GPIO_4MA 1 +#define GPIO_6MA 2 +#define GPIO_8MA 3 +#define GPIO_10MA 4 +#define GPIO_12MA 5 +#define GPIO_14MA 6 +#define GPIO_16MA 7 + +/* GPIO TLMM: Status */ +#define GPIO_DISABLE 0 +#define GPIO_ENABLE 1 + +/* GPIO TLMM: Mask */ +#define GPIO_CFG_PULL_BMSK 0x3 +#define GPIO_CFG_FUNC_BMSK 0xF +#define GPIO_CFG_DRV_BMSK 0x7 +#define GPIO_CFG_OE_BMSK 0x1 + +/* GPIO TLMM: Shift */ +#define GPIO_CFG_PULL_SHFT 0 +#define GPIO_CFG_FUNC_SHFT 2 +#define GPIO_CFG_DRV_SHFT 6 +#define GPIO_CFG_OE_SHFT 9 + +/* GPIO IO: Mask */ +#define GPIO_IO_IN_BMSK 0x1 +#define GPIO_IO_OUT_BMSK 0x1 + +/* GPIO IO: Shift */ +#define GPIO_IO_IN_SHFT 0 +#define GPIO_IO_OUT_SHFT 1 + +/* GPIO ID STATUS: Mask */ +#define GPIO_ID_STATUS_BMSK 0x1 + +/* GPIO MAX Valid # */ +#define GPIO_NUM_MAX 149 + +#define GPIO_FUNC_GPIO 0 + +#define GPIO(num) ((gpio_t){.addr = GPIO##num##_ADDR}) + +#define PIN(index, tlmm, func1, func2, func3, func4, func5, func6, func7) \ +GPIO##index##_ADDR = TLMM_##tlmm##_TILE_BASE + index * TLMM_GPIO_OFF_DELTA, \ +GPIO##index##_FUNC_##func1 = 1, \ +GPIO##index##_FUNC_##func2 = 2, \ +GPIO##index##_FUNC_##func3 = 3, \ +GPIO##index##_FUNC_##func4 = 4, \ +GPIO##index##_FUNC_##func5 = 5, \ +GPIO##index##_FUNC_##func6 = 6, \ +GPIO##index##_FUNC_##func7 = 7 + +enum { + PIN(0, SOUTH, RES_1, RES_2, RES_3, RES_4, RES_5, RES_6, RES_7), + PIN(1, SOUTH, RES_1, RES_2, RES_3, RES_4, RES_5, RES_6, RES_7), + PIN(2, SOUTH, RES_1, RES_2, RES_3, RES_4, RES_5, RES_6, RES_7), + PIN(3, SOUTH, RES_1, RES_2, RES_3, RES_4, RES_5, RES_6, RES_7), + PIN(4, SOUTH, RES_1, RES_2, RES_3, RES_4, RES_5, RES_6, RES_7), + PIN(5, SOUTH, RES_1, RES_2, RES_3, RES_4, RES_5, RES_6, RES_7), + PIN(6, SOUTH, RES_1, RES_2, RES_3, RES_4, RES_5, RES_6, RES_7), + PIN(7, SOUTH, RES_1, RES_2, RES_3, RES_4, RES_5, RES_6, RES_7), + PIN(8, SOUTH, RES_1, RES_2, RES_3, RES_4, RES_5, RES_6, RES_7), + PIN(9, SOUTH, RES_1, RES_2, RES_3, RES_4, RES_5, RES_6, RES_7), + PIN(10, SOUTH, RES_1, RES_2, RES_3, RES_4, RES_5, RES_6, RES_7), + PIN(11, SOUTH, RES_1, RES_2, RES_3, RES_4, RES_5, RES_6, RES_7), + PIN(12, SOUTH, RES_1, RES_2, RES_3, RES_4, RES_5, RES_6, RES_7), + PIN(13, SOUTH, RES_1, RES_2, RES_3, RES_4, RES_5, RES_6, RES_7), + PIN(14, SOUTH, RES_1, RES_2, RES_3, RES_4, RES_5, RES_6, RES_7), + PIN(15, SOUTH, RES_1, RES_2, RES_3, RES_4, RES_5, RES_6, RES_7), + PIN(16, SOUTH, RES_1, RES_2, RES_3, RES_4, RES_5, RES_6, RES_7), + PIN(17, NORTH, BLSP_UART_TX_A, BLSP_SPI_MOSI, RES_3, RES_4, RES_5, + RES_6, RES_7), + PIN(18, NORTH, BLSP_UART_RX_A, BLSP_SPI_MISO, RES_3, RES_4, RES_5, + RES_6, RES_7), + PIN(19, NORTH, BLSP_UART_CTS_N, AUD_CDC_INT2, RES_3, BLSP_SPI_CS_N, + RES_5, RES_6, RES_7), + PIN(20, NORTH, BLSP_UART_RFR_N, RES_2, RES_3, BLSP_SPI_CLK, RES_5, + RES_6, RES_7), + PIN(21, SOUTH, M_VOC_EXT_VFR_REF_IRQ_2, RES_2, RES_3, RES_4, + RES_5, RES_6, RES_7), + PIN(22, NORTH, BLSP_UART_TX, BLSP_SPI_MOSI_A, ASDIV1, RES_4, + RES_5, RES_6, RES_7), + PIN(23, NORTH, BLSP_UART_RX, BLSP_SPI_MISO_A, ASDIV2, RES_4, + RES_5, RES_6, RES_7), + PIN(24, NORTH, BLSP_UART_CTS_N, BLSP_I2C_SDA, BLSP_SPI_CS_N_A, + RES_4, RES_5, RES_6, RES_7), + PIN(25, NORTH, BLSP_UART_RFR_N, BLSP_I2C_SCL, BLSP_SPI_CLK_A, + RES_4, RES_5, RES_6, RES_7), + PIN(26, EAST, RES_1, BLSP_UART_TX, BLSP_SPI_MOSI, RES_4, RES_5, + RES_6, RES_7), + PIN(27, EAST, RES_1, BLSP_UART_RX, BLSP_SPI_MISO, RES_4, RES_5, + RES_6, RES_7), + PIN(28, EAST, RES_1, BLSP_UART_CTS_N, RES_3, BLSP_SPI_CS_N, RES_5, + RES_6, RES_7), + PIN(29, EAST, RES_1, BLSP_UART_RFR_N, RES_3, BLSP_SPI_CLK, RES_5, + RES_6, RES_7), + PIN(30, NORTH, RES_1, BLSP_UART_TX, RES_3, RES_4, RES_5, RES_6, + RES_7), + PIN(31, NORTH, RES_1, BLSP_UART_RX, RES_3, RES_4, RES_5, RES_6, + RES_7), + PIN(32, NORTH, RES_1, BLSP_UART_CTS_N, BLSP_I2C_SDA, RES_4, RES_5, + RES_6, RES_7), + PIN(33, NORTH, RES_1, BLSP_UART_RFR_N, BLSP_I2C_SCL, RES_4, RES_5, + RES_6, RES_7), + PIN(34, SOUTH, RES_1, RES_2, RES_3, RES_4, RES_5, RES_6, RES_7), + PIN(35, SOUTH, PCIE_CLK_REQ, RES_2, RES_3, RES_4, RES_5, RES_6, + RES_7), + PIN(36, NORTH, RES_1, RES_2, RES_3, RES_4, RES_5, RES_6, RES_7), + PIN(37, NORTH, NFC_IRQ, BLSP_SPI_MOSI, RES_3, RES_4, RES_5, RES_6, + RES_7), + PIN(38, NORTH, RES_1, BLSP_SPI_MISO, AUDIO_TS_IN, RES_4, RES_5, + RES_6, RES_7), + PIN(39, EAST, RES_1, RES_2, BLSP_UART_TX_B, RES_4, RES_5, RES_6, + RES_7), + PIN(40, EAST, RES_1, RES_2, BLSP_UART_RX_B, RES_4, RES_5, RES_6, + RES_7), + PIN(41, EAST, RES_1, BLSP_I2C_SDA_B, RES_3, RES_4, RES_5, RES_6, + RES_7), + PIN(42, EAST, RES_1, BLSP_I2C_SCL_B, RES_3, RES_4, RES_5, RES_6, + RES_7), + PIN(43, EAST, RES_1, PWM_LED11, RES_3, RES_4, RES_5, RES_6, RES_7), + PIN(44, EAST, RES_1, PWM_LED12, BLSP_SPI_CS1_N, RES_4, RES_5, + RES_6, RES_7), + PIN(45, EAST, RES_1, PWM_LED13, BLSP_SPI_CS2_N, RES_4, RES_5, + RES_6, RES_7), + PIN(46, EAST, RES_1, PWM_LED14, BLSP_SPI_CS3_N, RES_4, RES_5, + RES_6, RES_7), + PIN(47, EAST, RES_1, PWM_LED15, BLSP_SPI_MOSI_B, RES_4, RES_5, + RES_6, RES_7), + PIN(48, EAST, RES_1, PWM_LED16, BLSP_SPI_MISO_B, RES_4, RES_5, + RES_6, RES_7), + PIN(49, EAST, RES_1, PWM_LED17, BLSP_SPI_CS_N_B, RES_4, RES_5, + RES_6, RES_7), + PIN(50, EAST, RES_1, PWM_LED18, BLSP_SPI_CLK_B, RES_4, RES_5, + RES_6, RES_7), + PIN(51, EAST, RES_1, PWM_LED19, EXT_MCLK1_B, RES_4, RES_5, RES_6, + RES_7), + PIN(52, EAST, RES_1, PWM_LED20, RES_3, I2S_3_SCK_B, RES_5, RES_6, + RES_7), + PIN(53, EAST, RES_1, PWM_LED21, I2S_3_WS_B, RES_4, RES_5, RES_6, + RES_7), + PIN(54, EAST, RES_1, I2S_3_DATA0_B, RES_3, RES_4, RES_5, RES_6, + RES_7), + PIN(55, EAST, RES_1, I2S_3_DATA1_B, RES_3, RES_4, RES_5, RES_6, + RES_7), + PIN(56, EAST, RES_1, RES_2, I2S_3_DATA2_B, RES_4, RES_5, RES_6, + RES_7), + PIN(57, EAST, RES_1, RES_2, I2S_3_DATA3_B, RES_4, RES_5, RES_6, + RES_7), + PIN(58, EAST, RGB_DATA_B, RES_2, RES_3, RES_4, RES_5, RES_6, + RES_7), + PIN(59, EAST, RGB_DATA_B, RES_2, RES_3, RES_4, RES_5, RES_6, + RES_7), + PIN(60, NORTH, RES_1, RES_2, RES_3, RES_4, RES_5, RES_6, RES_7), + PIN(61, NORTH, RGMII_INT, RES_2, RES_3, RES_4, RES_5, RES_6, + RES_7), + PIN(62, NORTH, RES_1, RES_2, RES_3, RES_4, RES_5, RES_6, RES_7), + PIN(63, NORTH, RGMII_CK_TX, RES_2, RES_3, RES_4, RES_5, RES_6, + RES_7), + PIN(64, NORTH, RGMII_TX_3, RES_2, RES_3, RES_4, RES_5, RES_6, + RES_7), + PIN(65, NORTH, RGMII_TX_2, RES_2, RES_3, RES_4, RES_5, RES_6, + RES_7), + PIN(66, NORTH, RGMII_TX_1, RES_2, RES_3, RES_4, RES_5, RES_6, + RES_7), + PIN(67, NORTH, RGMII_TX_0, RES_2, RES_3, RES_4, RES_5, RES_6, + RES_7), + PIN(68, NORTH, RGMII_CTL_TX, RES_2, RES_3, RES_4, RES_5, RES_6, + RES_7), + PIN(69, NORTH, RGMII_CK_RX, RES_2, RES_3, RES_4, RES_5, RES_6, + RES_7), + PIN(70, NORTH, RGMII_RX_3, RES_2, RES_3, RES_4, RES_5, RES_6, + RES_7), + PIN(71, NORTH, RGMII_RX_2, RES_2, RES_3, RES_4, RES_5, RES_6, + RES_7), + PIN(72, NORTH, RGMII_RX_1, RES_2, RES_3, RES_4, RES_5, RES_6, + RES_7), + PIN(73, NORTH, RGMII_RX_0, RES_2, RES_3, RES_4, RES_5, RES_6, + RES_7), + PIN(74, NORTH, RGMII_CTL_RX, RES_2, RES_3, RES_4, RES_5, RES_6, + RES_7), + PIN(75, NORTH, RGMII_MDIO, RES_2, RES_3, RES_4, RES_5, RES_6, + RES_7), + PIN(76, NORTH, RGMII_MDC, RES_2, RES_3, RES_4, RES_5, RES_6, + RES_7), + PIN(77, NORTH, IR_IN, RES_2, RES_3, RES_4, RES_5, RES_6, RES_7), + PIN(78, EAST, RGB_DATA_G, RES_2, RES_3, RES_4, RES_5, RES_6, + RES_7), + PIN(79, EAST, RGB_DATA_G, RES_2, RES_3, RES_4, RES_5, RES_6, + RES_7), + PIN(80, EAST, RGB_DATA_R, RES_2, RES_3, RES_4, RES_5, RES_6, + RES_7), + PIN(81, EAST, RGB_DATA_R, RES_2, RES_3, RES_4, RES_5, RES_6, + RES_7), + PIN(82, NORTH, BLSP_UART_TX, BLSP_SPI_MOSI, SD_WRITE_PROTECT, + RES_4, RES_5, RES_6, RES_7), + PIN(83, NORTH, BLSP_UART_RX, BLSP_SPI_MISO, RES_3, RES_4, RES_5, + RES_6, RES_7), + PIN(84, NORTH, BLSP_UART_CTS_N, BLSP_I2C_SDA, BLSP_SPI_CS_N, + RES_4, RES_5, RES_6, RES_7), + PIN(85, NORTH, BLSP_UART_RFR_N, BLSP_I2C_SCL, BLSP_SPI_CLK, RES_4, + RES_5, RES_6, RES_7), + PIN(86, EAST, RES_1, MCLK_IN1, RES_3, RES_4, RES_5, RES_6, RES_7), + PIN(87, EAST, I2S_1_SCK, DSD_CLK_A, RES_3, RES_4, RES_5, RES_6, + RES_7), + PIN(88, EAST, I2S_1_WS, I2S_1_DATA0_DSD0, RES_3, RES_4, RES_5, + RES_6, RES_7), + PIN(89, EAST, I2S_1_DATA0, I2S_1_DATA1_DSD1, RES_3, RES_4, RES_5, + RES_6, RES_7), + PIN(90, EAST, I2S_1_DATA1, I2S_1_DATA2_DSD2, RES_3, RES_4, RES_5, + RES_6, RES_7), + PIN(91, EAST, I2S_1_DATA2, I2S_1_DATA3_DSD3, RES_3, RES_4, RES_5, + RES_6, RES_7), + PIN(92, EAST, I2S_1_DATA3, I2S_1_DATA4_DSD4, RES_3, RES_4, RES_5, + RES_6, RES_7), + PIN(93, EAST, I2S_1_DATA4, PWM_LED22, I2S_1_DATA5_DSD5, RES_4, + RES_5, RES_6, RES_7), + PIN(94, EAST, I2S_1_DATA5, PWM_LED23, I2S_1_DATA6_MIR, RES_4, + RES_5, RES_6, RES_7), + PIN(95, EAST, RES_1, PWM_LED1, I2S_1_DATA7_MIR, RES_4, RES_5, + RES_6, RES_7), + PIN(96, EAST, RES_1, PWM_LED2, RES_3, RES_4, RES_5, RES_6, RES_7), + PIN(97, EAST, RES_1, RES_2, RES_3, RES_4, RES_5, RES_6, RES_7), + PIN(98, EAST, RES_1, RES_2, RES_3, RES_4, RES_5, RES_6, RES_7), + PIN(99, EAST, RES_1, RES_2, RES_3, RES_4, RES_5, RES_6, RES_7), + PIN(100, EAST, RES_1, RES_2, RES_3, RES_4, RES_5, RES_6, RES_7), + PIN(101, EAST, RES_1, RES_2, RES_3, RES_4, RES_5, RES_6, RES_7), + PIN(102, EAST, RES_1, RES_2, RES_3, RES_4, RES_5, RES_6, RES_7), + PIN(103, EAST, RES_1, MCLK_IN2, RES_3, RES_4, RES_5, RES_6, RES_7), + PIN(104, EAST, I2S_3_SCK_A, RES_2, RES_3, RES_4, RES_5, RES_6, + RES_7), + PIN(105, EAST, I2S_3_WS_A, RES_2, RES_3, RES_4, RES_5, RES_6, + RES_7), + PIN(106, EAST, I2S_3_DATA0_A, RES_2, HDMI_HOT_PLUG_MIR, RES_4, + RES_5, RES_6, RES_7), + PIN(107, EAST, I2S_3_DATA1_A, RES_2, RES_3, RES_4, RES_5, RES_6, + RES_7), + PIN(108, EAST, I2S_3_DATA2_A, RES_2, RES_3, PWM_LED3, RES_5, + RES_6, RES_7), + PIN(109, EAST, I2S_3_DATA3_A, RES_2, PWM_LED4, RES_4, RES_5, + RES_6, RES_7), + PIN(110, EAST, RES_1, RES_2, DSD_CLK_B, PWM_LED5, RES_5, RES_6, + RES_7), + PIN(111, EAST, RES_1, I2S_4_DATA0_DSD0, PWM_LED6, RES_4, RES_5, + RES_6, RES_7), + PIN(112, EAST, RES_1, I2S_4_DATA1_DSD1, PWM_LED7, RES_4, RES_5, + RES_6, RES_7), + PIN(113, EAST, RES_1, I2S_4_DATA2_DSD2, PWM_LED8, RES_4, RES_5, + RES_6, RES_7), + PIN(114, EAST, RES_1, I2S_4_DATA3_DSD3, PWM_LED24, RES_4, RES_5, + RES_6, RES_7), + PIN(115, EAST, RES_1, I2S_4_DATA4_DSD4, RES_3, RES_4, RES_5, + RES_6, RES_7), + PIN(116, EAST, I2S_4_DATA5_DSD5, SPKR_DAC0, RES_3, RES_4, RES_5, + RES_6, RES_7), + PIN(117, NORTH, BLSP_I2C_SDA, BLSP_SPI_CS_N, PWM_LED9, RES_4, + RES_5, RES_6, RES_7), + PIN(118, NORTH, BLSP_I2C_SCL, BLSP_SPI_CLK, PWM_LED10, RES_4, + RES_5, RES_6, RES_7), + PIN(119, EAST, RES_1, RES_2, RES_3, RES_4, RES_5, RES_6, RES_7), +}; + +struct tlmm_gpio { + uint32_t cfg; + uint32_t in_out; +}; + +void gpio_configure(gpio_t gpio, uint32_t func, uint32_t pull, + uint32_t drive_str, uint32_t enable);
#endif // _SOC_QUALCOMM_QCS405_GPIO_H_
