zanxi chen has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/57460 )
Change subject: mb/google/trogdor: Panel support for wormdingler ......................................................................
Add mipi panel support for wormdingler - setup gpio - add the following panel for wormdingler: INX P110ZZD BOE TV110C9M - use panel_id to distinguish which mipi panel to use.
BUG=b:195898400,b:198548221 BRANCH=none TEST=emerge-strongbad coreboot
Change-Id: Ib1a90e8e370fd20b17374c53c3970db249e96684 Signed-off-by: Zanxi Chen chenzanxi@huaqin.corp-partner.google.com --- M src/drivers/mipi/Kconfig M src/drivers/mipi/Makefile.inc A src/drivers/mipi/panel-BOE_TV110C9M.c A src/drivers/mipi/panel-INX_P110ZZD.c M src/mainboard/google/trogdor/Kconfig M src/mainboard/google/trogdor/board.h M src/mainboard/google/trogdor/mainboard.c 7 files changed, 765 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/60/57460/1
diff --git a/src/drivers/mipi/Kconfig b/src/drivers/mipi/Kconfig index 72105e4..7075669 100644 --- a/src/drivers/mipi/Kconfig +++ b/src/drivers/mipi/Kconfig @@ -38,3 +38,9 @@
config MIPI_PANEL_VIS_RM69299 bool + +config MIPI_PANEL_INX_P110ZZD + bool + +config MIPI_PANEL_BOE_TV110C9M + bool diff --git a/src/drivers/mipi/Makefile.inc b/src/drivers/mipi/Makefile.inc index d58e838..706f0e4 100644 --- a/src/drivers/mipi/Makefile.inc +++ b/src/drivers/mipi/Makefile.inc @@ -22,6 +22,10 @@
panel-params-$(CONFIG_MIPI_PANEL_VIS_RM69299) += panel-VIS_RM69299
+panel-params-$(CONFIG_MIPI_PANEL_INX_P110ZZD) += panel-INX_P110ZZD + +panel-params-$(CONFIG_MIPI_PANEL_BOE_TV110C9M) += panel-BOE_TV110C9M + $(foreach params,$(panel-params-y), \ $(eval cbfs-files-y += $(params)) \ $(eval $(params)-file := $(params).c:struct) \ diff --git a/src/drivers/mipi/panel-BOE_TV110C9M.c b/src/drivers/mipi/panel-BOE_TV110C9M.c new file mode 100644 index 0000000..5785e92 --- /dev/null +++ b/src/drivers/mipi/panel-BOE_TV110C9M.c @@ -0,0 +1,373 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#include <mipi/panel.h> + +struct panel_serializable_data BOE_TV110C9M = { + .edid = { + .ascii_string = "TV110C9M", + .manufacturer_name = "BOE", + .panel_bits_per_color = 8, + .panel_bits_per_pixel = 24, + .mode = { + .pixel_clock = 162383, + .lvds_dual_channel = 0, + .refresh = 60, + .ha = 1200, .hbl = 24, .hso = 12, .hspw = 2, + .va = 2000, .vbl = 176, .vso = 26, .vspw = 1, + .phsync = '-', .pvsync = '-', + .x_mm = 143, .y_mm = 238, + }, + }, + .orientation = LB_FB_ORIENTATION_LEFT_UP, + .init = { + PANEL_DCS(0xFF, 0x20), + PANEL_DCS(0xFB, 0x01), + PANEL_DCS(0x05, 0xD9), + PANEL_DCS(0x07, 0x78), + PANEL_DCS(0x08, 0x5A), + PANEL_DCS(0x0D, 0x63), + PANEL_DCS(0x95, 0xEB), + PANEL_DCS(0x96, 0xEB), + PANEL_DCS(0x30, 0x11), + PANEL_DCS(0x6D, 0x66), + PANEL_DCS(0x75, 0xA2), + PANEL_DCS(0x77, 0x3B), + PANEL_DCS(0xB0, 0x00, 0x08, 0x00, 0x23, 0x00, 0x4D, 0x00, 0x6D, 0x00, 0x89, 0x00, 0xA1, 0x00, 0xB6, 0x00, 0xC9), + PANEL_DCS(0xB1, 0x00, 0xDA, 0x01, 0x13, 0x01, 0x3C, 0x01, 0x7E, 0x01, 0xAB, 0x01, 0xF7, 0x02, 0x2F, 0x02, 0x31), + PANEL_DCS(0xB2, 0x02, 0x67, 0x02, 0xA6, 0x02, 0xD1, 0x03, 0x08, 0x03, 0x2E, 0x03, 0x5B, 0x03, 0x6B, 0x03, 0x7B), + PANEL_DCS(0xB3, 0x03, 0x8E, 0x03, 0xA2, 0x03, 0xB7, 0x03, 0xE7, 0x03, 0xFD, 0x03, 0xFF), + PANEL_DCS(0xB4, 0x00, 0x08, 0x00, 0x23, 0x00, 0x4D, 0x00, 0x6D, 0x00, 0x89, 0x00, 0xA1, 0x00, 0xB6, 0x00, 0xC9), + PANEL_DCS(0xB5, 0x00, 0xDA, 0x01, 0x13, 0x01, 0x3C, 0x01, 0x7E, 0x01, 0xAB, 0x01, 0xF7, 0x02, 0x2F, 0x02, 0x31), + PANEL_DCS(0xB6, 0x02, 0x67, 0x02, 0xA6, 0x02, 0xD1, 0x03, 0x08, 0x03, 0x2E, 0x03, 0x5B, 0x03, 0x6B, 0x03, 0x7B), + PANEL_DCS(0xB7, 0x03, 0x8E, 0x03, 0xA2, 0x03, 0xB7, 0x03, 0xE7, 0x03, 0xFD, 0x03, 0xFF), + PANEL_DCS(0xB8, 0x00, 0x08, 0x00, 0x23, 0x00, 0x4D, 0x00, 0x6D, 0x00, 0x89, 0x00, 0xA1, 0x00, 0xB6, 0x00, 0xC9), + PANEL_DCS(0xB9, 0x00, 0xDA, 0x01, 0x13, 0x01, 0x3C, 0x01, 0x7E, 0x01, 0xAB, 0x01, 0xF7, 0x02, 0x2F, 0x02, 0x31), + PANEL_DCS(0xBA, 0x02, 0x67, 0x02, 0xA6, 0x02, 0xD1, 0x03, 0x08, 0x03, 0x2E, 0x03, 0x5B, 0x03, 0x6B, 0x03, 0x7B), + PANEL_DCS(0xBB, 0x03, 0x8E, 0x03, 0xA2, 0x03, 0xB7, 0x03, 0xE7, 0x03, 0xFD, 0x03, 0xFF), + PANEL_DCS(0xFF, 0x21), + PANEL_DCS(0xFB, 0x01), + PANEL_DCS(0xB0, 0x00, 0x00, 0x00, 0x1B, 0x00, 0x45, 0x00, 0x65, 0x00, 0x81, 0x00, 0x99, 0x00, 0xAE, 0x00, 0xC1), + PANEL_DCS(0xB1, 0x00, 0xD2, 0x01, 0x0B, 0x01, 0x34, 0x01, 0x76, 0x01, 0xA3, 0x01, 0xEF, 0x02, 0x27, 0x02, 0x29), + PANEL_DCS(0xB2, 0x02, 0x5F, 0x02, 0x9E, 0x02, 0xC9, 0x03, 0x00, 0x03, 0x26, 0x03, 0x53, 0x03, 0x63, 0x03, 0x73), + PANEL_DCS(0xB3, 0x03, 0x86, 0x03, 0x9A, 0x03, 0xAF, 0x03, 0xDF, 0x03, 0xF5, 0x03, 0xF7), + PANEL_DCS(0xB4, 0x00, 0x00, 0x00, 0x1B, 0x00, 0x45, 0x00, 0x65, 0x00, 0x81, 0x00, 0x99, 0x00, 0xAE, 0x00, 0xC1), + PANEL_DCS(0xB5, 0x00, 0xD2, 0x01, 0x0B, 0x01, 0x34, 0x01, 0x76, 0x01, 0xA3, 0x01, 0xEF, 0x02, 0x27, 0x02, 0x29), + PANEL_DCS(0xB6, 0x02, 0x5F, 0x02, 0x9E, 0x02, 0xC9, 0x03, 0x00, 0x03, 0x26, 0x03, 0x53, 0x03, 0x63, 0x03, 0x73), + PANEL_DCS(0xB7, 0x03, 0x86, 0x03, 0x9A, 0x03, 0xAF, 0x03, 0xDF, 0x03, 0xF5, 0x03, 0xF7), + PANEL_DCS(0xB8, 0x00, 0x00, 0x00, 0x1B, 0x00, 0x45, 0x00, 0x65, 0x00, 0x81, 0x00, 0x99, 0x00, 0xAE, 0x00, 0xC1), + PANEL_DCS(0xB9, 0x00, 0xD2, 0x01, 0x0B, 0x01, 0x34, 0x01, 0x76, 0x01, 0xA3, 0x01, 0xEF, 0x02, 0x27, 0x02, 0x29), + PANEL_DCS(0xBA, 0x02, 0x5F, 0x02, 0x9E, 0x02, 0xC9, 0x03, 0x00, 0x03, 0x26, 0x03, 0x53, 0x03, 0x63, 0x03, 0x73), + PANEL_DCS(0xBB, 0x03, 0x86, 0x03, 0x9A, 0x03, 0xAF, 0x03, 0xDF, 0x03, 0xF5, 0x03, 0xF7), + PANEL_DCS(0xFF, 0x24), + PANEL_DCS(0xFB, 0x01), + PANEL_DCS(0x00, 0x00), + PANEL_DCS(0x01, 0x00), + PANEL_DCS(0x02, 0x1C), + PANEL_DCS(0x03, 0x1C), + PANEL_DCS(0x04, 0x1D), + PANEL_DCS(0x05, 0x1D), + PANEL_DCS(0x06, 0x04), + PANEL_DCS(0x07, 0x04), + PANEL_DCS(0x08, 0x0F), + PANEL_DCS(0x09, 0x0F), + PANEL_DCS(0x0A, 0x0E), + PANEL_DCS(0x0B, 0x0E), + PANEL_DCS(0x0C, 0x0D), + PANEL_DCS(0x0D, 0x0D), + PANEL_DCS(0x0E, 0x0C), + PANEL_DCS(0x0F, 0x0C), + PANEL_DCS(0x10, 0x08), + PANEL_DCS(0x11, 0x08), + PANEL_DCS(0x12, 0x00), + PANEL_DCS(0x13, 0x00), + PANEL_DCS(0x14, 0x00), + PANEL_DCS(0x15, 0x00), + PANEL_DCS(0x16, 0x00), + PANEL_DCS(0x17, 0x00), + PANEL_DCS(0x18, 0x1C), + PANEL_DCS(0x19, 0x1C), + PANEL_DCS(0x1A, 0x1D), + PANEL_DCS(0x1B, 0x1D), + PANEL_DCS(0x1C, 0x04), + PANEL_DCS(0x1D, 0x04), + PANEL_DCS(0x1E, 0x0F), + PANEL_DCS(0x1F, 0x0F), + PANEL_DCS(0x20, 0x0E), + PANEL_DCS(0x21, 0x0E), + PANEL_DCS(0x22, 0x0D), + PANEL_DCS(0x23, 0x0D), + PANEL_DCS(0x24, 0x0C), + PANEL_DCS(0x25, 0x0C), + PANEL_DCS(0x26, 0x08), + PANEL_DCS(0x27, 0x08), + PANEL_DCS(0x28, 0x00), + PANEL_DCS(0x29, 0x00), + PANEL_DCS(0x2A, 0x00), + PANEL_DCS(0x2B, 0x00), + PANEL_DCS(0x2D, 0x20), + PANEL_DCS(0x2F, 0x0A), + PANEL_DCS(0x30, 0x44), + PANEL_DCS(0x33, 0x0C), + PANEL_DCS(0x34, 0x32), + PANEL_DCS(0x37, 0x44), + PANEL_DCS(0x38, 0x40), + PANEL_DCS(0x39, 0x00), + PANEL_DCS(0x3A, 0x9A), + PANEL_DCS(0x3B, 0xA0), + PANEL_DCS(0x3D, 0x42), + PANEL_DCS(0x3F, 0x06), + PANEL_DCS(0x43, 0x06), + PANEL_DCS(0x47, 0x66), + PANEL_DCS(0x4A, 0x9A), + PANEL_DCS(0x4B, 0xA0), + PANEL_DCS(0x4C, 0x91), + PANEL_DCS(0x4D, 0x21), + PANEL_DCS(0x4E, 0x43), + PANEL_DCS(0x51, 0x12), + PANEL_DCS(0x52, 0x34), + PANEL_DCS(0x55, 0x82, 0x02), + PANEL_DCS(0x56, 0x04), + PANEL_DCS(0x58, 0x21), + PANEL_DCS(0x59, 0x30), + PANEL_DCS(0x5A, 0xBA), //9A + PANEL_DCS(0x5B, 0xA0), + PANEL_DCS(0x5E, 0x00, 0x06), + PANEL_DCS(0x5F, 0x00), + PANEL_DCS(0x65, 0x82), + PANEL_DCS(0x7E, 0x20), + PANEL_DCS(0x7F, 0x3C), + PANEL_DCS(0x82, 0x04), + PANEL_DCS(0x97, 0xC0), + PANEL_DCS(0xB6, 0x05, 0x00, 0x05, 0x00, 0x00, 0x00, 0x00, 0x00, 0x05, 0x05, 0x00, 0x00), + PANEL_DCS(0x92, 0xC4), + PANEL_DCS(0x93, 0x1A), + PANEL_DCS(0x94, 0x5F), + PANEL_DCS(0xD7, 0x55), + PANEL_DCS(0xDA, 0x0A), + PANEL_DCS(0xDE, 0x08), + PANEL_DCS(0xDB, 0x05), + PANEL_DCS(0xDC, 0xC4), + PANEL_DCS(0xDD, 0x22), + PANEL_DCS(0xDF, 0x05), + PANEL_DCS(0xE0, 0xC4), + PANEL_DCS(0xE1, 0x05), + PANEL_DCS(0xE2, 0xC4), + PANEL_DCS(0xE3, 0x05), + PANEL_DCS(0xE4, 0xC4), + PANEL_DCS(0xE5, 0x05), + PANEL_DCS(0xE6, 0xC4), + PANEL_DCS(0x5C, 0x88), + PANEL_DCS(0x5D, 0x08), + PANEL_DCS(0x8D, 0x88), + PANEL_DCS(0x8E, 0x08), + PANEL_DCS(0xB5, 0x90), + PANEL_DCS(0xFF, 0x25), + PANEL_DCS(0xFB, 0x01), + PANEL_DCS(0x05, 0x00), + PANEL_DCS(0x19, 0x07), + PANEL_DCS(0x1F, 0xBA),//9A + PANEL_DCS(0x20, 0xA0), + PANEL_DCS(0x26, 0xBA),//9A + PANEL_DCS(0x27, 0xA0), + PANEL_DCS(0x33, 0xBA),//9A + PANEL_DCS(0x34, 0xA0), + PANEL_DCS(0x3F, 0xE0), + PANEL_DCS(0x40, 0x00), + PANEL_DCS(0x44, 0x00), + PANEL_DCS(0x45, 0x40), + PANEL_DCS(0x48, 0xBA),//9A + PANEL_DCS(0x49, 0xA0), + PANEL_DCS(0x5B, 0x00), + PANEL_DCS(0x5C, 0x00), + PANEL_DCS(0x5D, 0x00), + PANEL_DCS(0x5E, 0xD0), + PANEL_DCS(0x61, 0xBA),//9A + PANEL_DCS(0x62, 0xA0), + PANEL_DCS(0xF1, 0x10), + PANEL_DCS(0xFF, 0x2A), + PANEL_DCS(0xFB, 0x01), + PANEL_DCS(0x64, 0x16), + PANEL_DCS(0x67, 0x16), + PANEL_DCS(0x6A, 0x16), + PANEL_DCS(0x70, 0x30), + PANEL_DCS(0xA2, 0xF3), + PANEL_DCS(0xA3, 0xFF), + PANEL_DCS(0xA4, 0xFF), + PANEL_DCS(0xA5, 0xFF), + PANEL_DCS(0xD6, 0x08), + PANEL_DCS(0xFF, 0x26), + PANEL_DCS(0xFB, 0x01), + PANEL_DCS(0x00, 0xA1), + PANEL_DCS(0x0A, 0xF2), + PANEL_DCS(0x04, 0x28), + PANEL_DCS(0x06, 0x30), + PANEL_DCS(0x0C, 0x13), + PANEL_DCS(0x0D, 0x0A), + PANEL_DCS(0x0F, 0x0A), + PANEL_DCS(0x11, 0x00), + PANEL_DCS(0x12, 0x50), + PANEL_DCS(0x13, 0x51), + PANEL_DCS(0x14, 0x65), + PANEL_DCS(0x15, 0x00), + PANEL_DCS(0x16, 0x10), + PANEL_DCS(0x17, 0xA0), + PANEL_DCS(0x18, 0x86), + PANEL_DCS(0x19, 0x11), + PANEL_DCS(0x1A, 0x7B), + PANEL_DCS(0x1B, 0x10), + PANEL_DCS(0x1C, 0xBB), + PANEL_DCS(0x22, 0x00), + PANEL_DCS(0x23, 0x00), + PANEL_DCS(0x2A, 0x11), + PANEL_DCS(0x2B, 0x7B), + PANEL_DCS(0x1D, 0x00), + PANEL_DCS(0x1E, 0xC3), + PANEL_DCS(0x1F, 0xC3), + PANEL_DCS(0x24, 0x00), + PANEL_DCS(0x25, 0xC3), + PANEL_DCS(0x2F, 0x05), + PANEL_DCS(0x30, 0xC3), + PANEL_DCS(0x31, 0x00), + PANEL_DCS(0x32, 0xC3), + PANEL_DCS(0x39, 0x00), + PANEL_DCS(0x3A, 0xC3), + PANEL_DCS(0x20, 0x01), + PANEL_DCS(0x33, 0x11), + PANEL_DCS(0x34, 0x78), + PANEL_DCS(0x35, 0x16), + PANEL_DCS(0xC8, 0x04), + PANEL_DCS(0xC9, 0x82), + PANEL_DCS(0xCA, 0x4E), + PANEL_DCS(0xCB, 0x00), + PANEL_DCS(0xA9, 0x4C), + PANEL_DCS(0xAA, 0x47), + PANEL_DCS(0xFF, 0x27), + PANEL_DCS(0xFB, 0x01), + PANEL_DCS(0x56, 0x06), + PANEL_DCS(0x58, 0x80), + PANEL_DCS(0x59, 0x53), + PANEL_DCS(0x5A, 0x00), + PANEL_DCS(0x5B, 0x14), + PANEL_DCS(0x5C, 0x00), + PANEL_DCS(0x5D, 0x01), + PANEL_DCS(0x5E, 0x20), + PANEL_DCS(0x5F, 0x10), + PANEL_DCS(0x60, 0x00), + PANEL_DCS(0x61, 0x1D), + PANEL_DCS(0x62, 0x00), + PANEL_DCS(0x63, 0x01), + PANEL_DCS(0x64, 0x24), + PANEL_DCS(0x65, 0x1C), + PANEL_DCS(0x66, 0x00), + PANEL_DCS(0x67, 0x01), + PANEL_DCS(0x68, 0x25), + PANEL_DCS(0x00, 0x00), + PANEL_DCS(0x78, 0x00), + PANEL_DCS(0xC3, 0x00), + PANEL_DCS(0xD1, 0x24), + PANEL_DCS(0xD2, 0x30), + PANEL_DCS(0xFF, 0x2A), + PANEL_DCS(0xFB, 0x01), + PANEL_DCS(0x22, 0x2F), + PANEL_DCS(0x23, 0x08), + PANEL_DCS(0x24, 0x00), + PANEL_DCS(0x25, 0xC3), + PANEL_DCS(0x26, 0xF8), + PANEL_DCS(0x27, 0x00), + PANEL_DCS(0x28, 0x1A), + PANEL_DCS(0x29, 0x00), + PANEL_DCS(0x2A, 0x1A), + PANEL_DCS(0x2B, 0x00), + PANEL_DCS(0x2D, 0x1A), + PANEL_DCS(0xFF, 0x23), + PANEL_DCS(0xFB, 0x01), + PANEL_DCS(0x00, 0x80), + PANEL_DCS(0x07, 0x00), + PANEL_DCS(0xFF, 0x24), + PANEL_DCS(0xFB, 0x01), + PANEL_DCS(0x3A, 0x5D), + PANEL_DCS(0x3B, 0x60), + PANEL_DCS(0x4A, 0x5D), + PANEL_DCS(0x4B, 0x60), + PANEL_DCS(0x5A, 0x70), + PANEL_DCS(0x5B, 0x60), + PANEL_DCS(0x91, 0x44), + PANEL_DCS(0x92, 0x75), + PANEL_DCS(0xDB, 0x05), + PANEL_DCS(0xDC, 0x75), + PANEL_DCS(0xDD, 0x22), + PANEL_DCS(0xDF, 0x05), + PANEL_DCS(0xE0, 0x75), + PANEL_DCS(0xE1, 0x05), + PANEL_DCS(0xE2, 0x75), + PANEL_DCS(0xE3, 0x05), + PANEL_DCS(0xE4, 0x75), + PANEL_DCS(0xE5, 0x05), + PANEL_DCS(0xE6, 0x75), + PANEL_DCS(0x5C, 0x00), + PANEL_DCS(0x5D, 0x00), + PANEL_DCS(0x8D, 0x00), + PANEL_DCS(0x8E, 0x00), + PANEL_DCS(0xFF, 0x25), + PANEL_DCS(0xFB, 0x01), + PANEL_DCS(0x1F, 0x70), + PANEL_DCS(0x20, 0x60), + PANEL_DCS(0x26, 0x70), + PANEL_DCS(0x27, 0x60), + PANEL_DCS(0x33, 0x70), + PANEL_DCS(0x34, 0x60), + PANEL_DCS(0x48, 0x70), + PANEL_DCS(0x49, 0x60), + PANEL_DCS(0x5B, 0x00), + PANEL_DCS(0x61, 0x70), + PANEL_DCS(0x62, 0x60), + PANEL_DCS(0xFF, 0x26), + PANEL_DCS(0xFB, 0x01), + PANEL_DCS(0x02, 0x31), + PANEL_DCS(0x19, 0x0A), + PANEL_DCS(0x1A, 0x7F), + PANEL_DCS(0x1B, 0x0A), + PANEL_DCS(0x1C, 0x0C), + PANEL_DCS(0x2A, 0x0A), + PANEL_DCS(0x2B, 0x7F), + PANEL_DCS(0x1E, 0x75), + PANEL_DCS(0x1F, 0x75), + PANEL_DCS(0x25, 0x75), + PANEL_DCS(0x30, 0x75), + PANEL_DCS(0x31, 0x05), + PANEL_DCS(0x32, 0x8D), + PANEL_DCS(0x3A, 0x75), + PANEL_DCS(0xFF, 0x2A), + PANEL_DCS(0xFB, 0x01), + PANEL_DCS(0x25, 0x75), + PANEL_DCS(0xFF, 0xE0), + PANEL_DCS(0xFB, 0x01), + PANEL_DCS(0x14, 0x60), + PANEL_DCS(0x16, 0xC0), + PANEL_DCS(0xFF, 0xF0), + PANEL_DCS(0xFB, 0x01), + PANEL_DCS(0x3A, 0x08), + PANEL_DCS(0xFF, 0x10), + PANEL_DCS(0xFB, 0x01), + PANEL_DCS(0xB9, 0x01), + PANEL_DCS(0xFF, 0x20), + PANEL_DCS(0xFB, 0x01), + PANEL_DCS(0x18, 0x40), + PANEL_DCS(0xFF, 0x24), + PANEL_DCS(0xC2, 0x06), + PANEL_DCS(0xFF, 0x10), + PANEL_DCS(0xFB, 0x01), + PANEL_DCS(0xB9, 0x02), + PANEL_DCS(0x3B, 0x03, 0x5F, 0x1A, 0x04, 0x04), + PANEL_DCS(0x35, 0x00), + PANEL_DCS(0x51, 0x00, 0xFF), + PANEL_DCS(0x53, 0x24), + PANEL_DCS(0x55, 0x00), + PANEL_DCS(0xBB, 0x13), + PANEL_DCS(0x11), + PANEL_DELAY(200), + PANEL_DCS(0x29), + PANEL_DELAY(100), + PANEL_END, + }, +}; diff --git a/src/drivers/mipi/panel-INX_P110ZZD.c b/src/drivers/mipi/panel-INX_P110ZZD.c new file mode 100644 index 0000000..5869e71 --- /dev/null +++ b/src/drivers/mipi/panel-INX_P110ZZD.c @@ -0,0 +1,365 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#include <mipi/panel.h> + +struct panel_serializable_data INX_P110ZZD = { + .edid = { + .ascii_string = "P110ZZD", + .manufacturer_name = "INX", + .panel_bits_per_color = 8, + .panel_bits_per_pixel = 24, + .mode = { + .pixel_clock = 162383, + .lvds_dual_channel = 0, + .refresh = 60, + .ha = 1200, .hbl = 24, .hso = 12, .hspw = 2, + .va = 2000, .vbl = 176, .vso = 26, .vspw = 1, + .phsync = '-', .pvsync = '-', + .x_mm = 143, .y_mm = 238, + }, + }, + .orientation = LB_FB_ORIENTATION_LEFT_UP, + .init = { + PANEL_DCS(0xFF, 0x26), + PANEL_DCS(0xA7, 0x03), + PANEL_DCS(0xFF, 0x20), + PANEL_DELAY(100), + PANEL_DCS(0xFB, 0x01), + PANEL_DCS(0x05, 0xD1), + PANEL_DCS(0x0D, 0x63), + PANEL_DCS(0x07, 0x8C), + PANEL_DCS(0x08, 0x4B), + PANEL_DCS(0x0E, 0x91), + PANEL_DCS(0x0F, 0x69), + PANEL_DCS(0x95, 0xF5), + PANEL_DCS(0x96, 0xF5), + PANEL_DCS(0x9D, 0x14), + PANEL_DCS(0x9E, 0x14), + PANEL_DCS(0x6D, 0x33), + PANEL_DCS(0x69, 0x98), + PANEL_DCS(0x75, 0xA2), + PANEL_DCS(0x77, 0xB3), + PANEL_DCS(0xFF, 0x24), + PANEL_DELAY(100), + PANEL_DCS(0xFB, 0x01), + PANEL_DCS(0x91, 0x44), + PANEL_DCS(0x92, 0x7A), + PANEL_DCS(0x93, 0x1A), + PANEL_DCS(0x94, 0x40), + PANEL_DCS(0x9A, 0x08), + PANEL_DCS(0x60, 0x96), + PANEL_DCS(0x61, 0xD0), + PANEL_DCS(0x63, 0x70), + PANEL_DCS(0xC2, 0xC6), + PANEL_DCS(0x9B, 0x0F), + PANEL_DCS(0x9A, 0x08), + PANEL_DCS(0xA5, 0x00), + PANEL_DCS(0xA6, 0x41), + PANEL_DCS(0x00, 0x03), + PANEL_DCS(0x01, 0x03), + PANEL_DCS(0x02, 0x03), + PANEL_DCS(0x03, 0x03), + PANEL_DCS(0x04, 0x03), + PANEL_DCS(0x05, 0x03), + PANEL_DCS(0x06, 0x22), + PANEL_DCS(0x07, 0x06), + PANEL_DCS(0x08, 0x00), + PANEL_DCS(0x09, 0x1D), + PANEL_DCS(0x0A, 0x1C), + PANEL_DCS(0x0B, 0x13), + PANEL_DCS(0x0C, 0x12), + PANEL_DCS(0x0D, 0x11), + PANEL_DCS(0x0E, 0x10), + PANEL_DCS(0x0F, 0x0F), + PANEL_DCS(0x10, 0x0E), + PANEL_DCS(0x11, 0x0D), + PANEL_DCS(0x12, 0x0C), + PANEL_DCS(0x13, 0x04), + PANEL_DCS(0x14, 0x03), + PANEL_DCS(0x15, 0x03), + PANEL_DCS(0x16, 0x03), + PANEL_DCS(0x17, 0x03), + PANEL_DCS(0x18, 0x03), + PANEL_DCS(0x19, 0x03), + PANEL_DCS(0x1A, 0x03), + PANEL_DCS(0x1B, 0x03), + PANEL_DCS(0x1C, 0x22), + PANEL_DCS(0x1D, 0x06), + PANEL_DCS(0x1E, 0x00), + PANEL_DCS(0x1F, 0x1D), + PANEL_DCS(0x20, 0x1C), + PANEL_DCS(0x21, 0x13), + PANEL_DCS(0x22, 0x12), + PANEL_DCS(0x23, 0x11), + PANEL_DCS(0x24, 0x10), + PANEL_DCS(0x25, 0x0F), + PANEL_DCS(0x26, 0x0E), + PANEL_DCS(0x27, 0x0D), + PANEL_DCS(0x28, 0x0C), + PANEL_DCS(0x29, 0x04), + PANEL_DCS(0x2A, 0x03), + PANEL_DCS(0x2B, 0x03), + PANEL_DCS(0x2F, 0x06), + PANEL_DCS(0x30, 0x32), + PANEL_DCS(0x31, 0x43), + PANEL_DCS(0x33, 0x06), + PANEL_DCS(0x34, 0x32), + PANEL_DCS(0x35, 0x43), + PANEL_DCS(0x37, 0x44), + PANEL_DCS(0x38, 0x40), + PANEL_DCS(0x39, 0x00), + PANEL_DCS(0x3A, 0x01), + PANEL_DCS(0x3B, 0x48), + PANEL_DCS(0x3D, 0x93), + PANEL_DCS(0xAB, 0x44), + PANEL_DCS(0xAC, 0x40), + PANEL_DCS(0x4D, 0x21), + PANEL_DCS(0x4E, 0x43), + PANEL_DCS(0x4F, 0x65), + PANEL_DCS(0x50, 0x87), + PANEL_DCS(0x51, 0x78), + PANEL_DCS(0x52, 0x56), + PANEL_DCS(0x53, 0x34), + PANEL_DCS(0x54, 0x21), + PANEL_DCS(0x55, 0x83), + PANEL_DCS(0x56, 0x08), + PANEL_DCS(0x58, 0x21), + PANEL_DCS(0x59, 0x40), + PANEL_DCS(0x5A, 0x09), + PANEL_DCS(0x5B, 0x48), + PANEL_DCS(0x5E, 0x00, 0x10), + PANEL_DCS(0x5F, 0x00), + PANEL_DCS(0x7A, 0x00), + PANEL_DCS(0x7B, 0x00), + PANEL_DCS(0x7C, 0x00), + PANEL_DCS(0x7D, 0x00), + PANEL_DCS(0x7E, 0x20), + PANEL_DCS(0x7F, 0x3C), + PANEL_DCS(0x80, 0x00), + PANEL_DCS(0x81, 0x00), + PANEL_DCS(0x82, 0x08), + PANEL_DCS(0x97, 0x02), + PANEL_DCS(0xC5, 0x10), + PANEL_DCS(0xD7, 0x55), + PANEL_DCS(0xD8, 0x55), + PANEL_DCS(0xD9, 0x23), + PANEL_DCS(0xDA, 0x05), + PANEL_DCS(0xDB, 0x01), + PANEL_DCS(0xDC, 0x7A), + PANEL_DCS(0xDD, 0x55), + PANEL_DCS(0xDE, 0x27), + PANEL_DCS(0xDF, 0x01), + PANEL_DCS(0xE0, 0x7A), + PANEL_DCS(0xE1, 0x01), + PANEL_DCS(0xE2, 0x7A), + PANEL_DCS(0xE3, 0x01), + PANEL_DCS(0xE4, 0x7A), + PANEL_DCS(0xE5, 0x01), + PANEL_DCS(0xE6, 0x7A), + PANEL_DCS(0xE7, 0x00), + PANEL_DCS(0xE8, 0x00), + PANEL_DCS(0xE9, 0x01), + PANEL_DCS(0xEA, 0x7A), + PANEL_DCS(0xEB, 0x01), + PANEL_DCS(0xEE, 0x7A), + PANEL_DCS(0xEF, 0x01), + PANEL_DCS(0xF0, 0x7A), + PANEL_DCS(0xFF, 0x25), + PANEL_DCS(0xFB, 0x01), + PANEL_DCS(0x05, 0x00), + PANEL_DCS(0xF1, 0x10), + PANEL_DCS(0x1E, 0x00), + PANEL_DCS(0x1F, 0x09), + PANEL_DCS(0x20, 0x46), + PANEL_DCS(0x25, 0x00), + PANEL_DCS(0x26, 0x09), + PANEL_DCS(0x27, 0x46), + PANEL_DCS(0x3F, 0x80), + PANEL_DCS(0x40, 0x00), + PANEL_DCS(0x43, 0x00), + PANEL_DCS(0x44, 0x09), + PANEL_DCS(0x45, 0x46), + PANEL_DCS(0x48, 0x09), + PANEL_DCS(0x49, 0x46), + PANEL_DCS(0x5B, 0x80), + PANEL_DCS(0x5C, 0x00), + PANEL_DCS(0x5D, 0x01), + PANEL_DCS(0x5E, 0x46), + PANEL_DCS(0x61, 0x01), + PANEL_DCS(0x62, 0x46), + PANEL_DCS(0x68, 0x10), + PANEL_DCS(0x13, 0x02), + PANEL_DCS(0x14, 0xF2), + PANEL_DCS(0xFF, 0x26), + PANEL_DCS(0xFB, 0x01), + PANEL_DCS(0x00, 0xA1), + PANEL_DCS(0x02, 0x31), + PANEL_DCS(0x0A, 0xF2), + PANEL_DCS(0x04, 0x28), + PANEL_DCS(0x06, 0x20), + PANEL_DCS(0x0C, 0x13), + PANEL_DCS(0x0D, 0x0A), + PANEL_DCS(0x0F, 0x0A), + PANEL_DCS(0x11, 0x00), + PANEL_DCS(0x12, 0x50), + PANEL_DCS(0x13, 0x51), + PANEL_DCS(0x14, 0x65), + PANEL_DCS(0x15, 0x00), + PANEL_DCS(0x16, 0x10), + PANEL_DCS(0x17, 0xA0), + PANEL_DCS(0x18, 0x86), + PANEL_DCS(0x22, 0x00), + PANEL_DCS(0x23, 0x00), + PANEL_DCS(0x19, 0x30), + PANEL_DCS(0x1A, 0x00), + PANEL_DCS(0x1B, 0x09), + PANEL_DCS(0x1C, 0xC0), + PANEL_DCS(0x2A, 0x30), + PANEL_DCS(0x2B, 0x00), + PANEL_DCS(0x20, 0x00), + PANEL_DCS(0x1D, 0x00), + PANEL_DCS(0x1E, 0x78), + PANEL_DCS(0x1F, 0x78), + PANEL_DCS(0x2F, 0x03), + PANEL_DCS(0x30, 0x78), + PANEL_DCS(0x33, 0x78), + PANEL_DCS(0x34, 0x66), + PANEL_DCS(0x35, 0x11), + PANEL_DCS(0x39, 0x10), + PANEL_DCS(0x3A, 0x78), + PANEL_DCS(0x3B, 0x06), + PANEL_DCS(0xC8, 0x04), + PANEL_DCS(0xC9, 0x84), + PANEL_DCS(0xCA, 0x4E), + PANEL_DCS(0xCB, 0x00), + PANEL_DCS(0xA9, 0x50), + PANEL_DCS(0xAA, 0x4F), + PANEL_DCS(0xAB, 0x4D), + PANEL_DCS(0xAC, 0x4A), + PANEL_DCS(0xAD, 0x48), + PANEL_DCS(0xAE, 0x46), + PANEL_DCS(0xFF, 0x27), + PANEL_DCS(0xFB, 0x01), + PANEL_DCS(0xC0, 0x18), + PANEL_DCS(0xC1, 0x00), + PANEL_DCS(0xC2, 0x00), + PANEL_DCS(0x56, 0x06), + PANEL_DCS(0x58, 0x80), + PANEL_DCS(0x59, 0x53), + PANEL_DCS(0x5A, 0x00), + PANEL_DCS(0x5B, 0x14), + PANEL_DCS(0x5C, 0x00), + PANEL_DCS(0x5D, 0x00), + PANEL_DCS(0x5E, 0x20), + PANEL_DCS(0x5F, 0x10), + PANEL_DCS(0x60, 0x00), + PANEL_DCS(0x61, 0x1C), + PANEL_DCS(0x62, 0x00), + PANEL_DCS(0x63, 0x01), + PANEL_DCS(0x64, 0x24), + PANEL_DCS(0x65, 0x1B), + PANEL_DCS(0x66, 0x00), + PANEL_DCS(0x67, 0x01), + PANEL_DCS(0x68, 0x25), + PANEL_DCS(0x98, 0x01), + PANEL_DCS(0xB4, 0x03), + PANEL_DCS(0x9B, 0xBD), + PANEL_DCS(0xA0, 0x90), + PANEL_DCS(0xAB, 0x1B), + PANEL_DCS(0xBC, 0x0C), + PANEL_DCS(0xBD, 0x28), + PANEL_DCS(0xFF, 0x2A), + PANEL_DCS(0xFB, 0x01), + PANEL_DCS(0x22, 0x2F), + PANEL_DCS(0x23, 0x08), + PANEL_DCS(0x24, 0x00), + PANEL_DCS(0x25, 0x79), + PANEL_DCS(0x26, 0xF8), + PANEL_DCS(0x27, 0x00), + PANEL_DCS(0x28, 0x1A), + PANEL_DCS(0x29, 0x00), + PANEL_DCS(0x2A, 0x1A), + PANEL_DCS(0x2B, 0x00), + PANEL_DCS(0x2D, 0x1A), + PANEL_DCS(0x64, 0x96), + PANEL_DCS(0x65, 0x00), + PANEL_DCS(0x66, 0x00), + PANEL_DCS(0x6A, 0x96), + PANEL_DCS(0x6B, 0x00), + PANEL_DCS(0x6C, 0x00), + PANEL_DCS(0x70, 0x92), + PANEL_DCS(0x71, 0x00), + PANEL_DCS(0x72, 0x00), + PANEL_DCS(0xA2, 0x33), + PANEL_DCS(0xA3, 0x30), + PANEL_DCS(0xA4, 0xC0), + PANEL_DCS(0xE8, 0x00), + PANEL_DCS(0x97, 0x3C), + PANEL_DCS(0x98, 0x02), + PANEL_DCS(0x99, 0x95), + PANEL_DCS(0x9A, 0x06), + PANEL_DCS(0x9B, 0x00), + PANEL_DCS(0x9C, 0x0B), + PANEL_DCS(0x9D, 0x0A), + PANEL_DCS(0x9E, 0x90), + PANEL_DCS(0xFF, 0x27), + PANEL_DCS(0xFB, 0x01), + PANEL_DCS(0xD0, 0x13), + PANEL_DCS(0xD1, 0x54), + PANEL_DCS(0xD2, 0x30), + PANEL_DCS(0xDE, 0x43), + PANEL_DCS(0xDF, 0x02), + PANEL_DCS(0xFF, 0xF0), + PANEL_DCS(0xFB, 0x01), + PANEL_DCS(0x3A, 0x08), + PANEL_DCS(0xFF, 0xD0), + PANEL_DCS(0xFB, 0x01), + PANEL_DCS(0x02, 0x77), + PANEL_DCS(0x09, 0xBF), + PANEL_DCS(0x00, 0x22), + PANEL_DCS(0x2F, 0x22), + PANEL_DCS(0xFF, 0x23), + PANEL_DCS(0xFB, 0x01), + PANEL_DCS(0x00, 0x80), + PANEL_DCS(0x07, 0x00), + PANEL_DCS(0xFF, 0x20), + PANEL_DCS(0xFB, 0x01), + PANEL_DCS(0x30, 0x00), + PANEL_DCS(0xFF, 0x25), + PANEL_DCS(0xFB, 0x01), + PANEL_DCS(0x17, 0xCF), + PANEL_DCS(0x19, 0x1F), + PANEL_DCS(0x1B, 0x5B), + PANEL_DCS(0x1D, 0x00), + PANEL_DCS(0xFF, 0x10), + PANEL_DCS(0xB0, 0x01), + PANEL_DCS(0xFF, 0x10), + PANEL_DELAY(10), + PANEL_DCS(0xB9, 0x01), + PANEL_DCS(0xFF, 0x20), + PANEL_DELAY(10), + PANEL_DCS(0x18, 0x40), + PANEL_DCS(0xFF, 0x10), + PANEL_DELAY(10), + PANEL_DCS(0xB9, 0x02), + PANEL_DCS(0xFF, 0x10), + PANEL_DELAY(100), + PANEL_DCS(0xFB, 0x01), + PANEL_DCS(0xBB, 0x13), + PANEL_DCS(0xFF, 0x13), + PANEL_DCS(0x3B, 0x03, 0x96, 0x1A, 0x04, 0x04), + PANEL_DCS(0x35, 0x00), + PANEL_DCS(0xFF, 0x24), + PANEL_DCS(0xC2, 0x06), + PANEL_DCS(0xFF, 0x10), + PANEL_DCS(0xFB, 0x01), + PANEL_DCS(0x51, 0x00, 0xFF), + PANEL_DCS(0x53, 0x24), + PANEL_DCS(0x55, 0x00), + PANEL_DCS(0x11), + PANEL_DELAY(200), + PANEL_DCS(0x29), + PANEL_DELAY(100), + PANEL_END, + }, +}; diff --git a/src/mainboard/google/trogdor/Kconfig b/src/mainboard/google/trogdor/Kconfig index 88e72dc..344f378 100644 --- a/src/mainboard/google/trogdor/Kconfig +++ b/src/mainboard/google/trogdor/Kconfig @@ -17,6 +17,8 @@ default y if BOARD_GOOGLE_MRBLAND select MIPI_PANEL_AUO_B101UAN08_3 if BOARD_GOOGLE_MRBLAND select MIPI_PANEL_BOE_TV101WUM_N53 if BOARD_GOOGLE_MRBLAND + select MIPI_PANEL_INX_P110ZZD if BOARD_GOOGLE_WORMDINGLER + select MIPI_PANEL_BOE_TV110C9M if BOARD_GOOGLE_WORMDINGLER default n
config TROGDOR_HAS_FINGERPRINT diff --git a/src/mainboard/google/trogdor/board.h b/src/mainboard/google/trogdor/board.h index 172ed90..e1fb9b6 100644 --- a/src/mainboard/google/trogdor/board.h +++ b/src/mainboard/google/trogdor/board.h @@ -15,8 +15,8 @@ #define GPIO_AMP_ENABLE GPIO(23)
/* Display specific GPIOS */ -#define GPIO_BACKLIGHT_ENABLE ((CONFIG(BOARD_GOOGLE_MRBLAND)) ? \ - GPIO(85) : GPIO(12)) +#define GPIO_BACKLIGHT_ENABLE ((CONFIG(BOARD_GOOGLE_MRBLAND) || \ + CONFIG(BOARD_GOOGLE_WORMDINGLER)) ? GPIO(85) : GPIO(12)) #define GPIO_EDP_BRIDGE_ENABLE (CONFIG(TROGDOR_REV0) ? GPIO(14) : GPIO(104)) #define GPIO_EN_PP3300_DX_EDP (CONFIG(TROGDOR_REV0) ? GPIO(106) : \ (CONFIG(BOARD_GOOGLE_TROGDOR) && board_id() == 1 ? GPIO(30) : \ diff --git a/src/mainboard/google/trogdor/mainboard.c b/src/mainboard/google/trogdor/mainboard.c index 7bf95fd..a31dbad 100644 --- a/src/mainboard/google/trogdor/mainboard.c +++ b/src/mainboard/google/trogdor/mainboard.c @@ -118,6 +118,19 @@ } }
+ if (CONFIG(BOARD_GOOGLE_WORMDINGLER)) { + switch (panel_id) { + case 2: + cbfs_filename = "panel-INX_P110ZZD"; + break; + case 3: + cbfs_filename = "panel-BOE_TV110C9M"; + break; + default: + return NULL; + } + } + struct panel_serializable_data *panel = cbfs_map(cbfs_filename, NULL); if (!panel) { printk(BIOS_ERR, "Could not find panel data for %s!\n", cbfs_filename);
