Attention is currently required from: Felix Held, Fred Reitberger, Jason Glenesk, Martin L Roth, Matt DeVillier.
Arthur Heymans has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/78328?usp=email )
Change subject: device/device.h: Drop multiple links ......................................................................
Multiple links are unused throughout the tree and make the code more confusing as an iteration over all busses is needed to get downstream devices. This also not done consistently e.g. the allocator does not care about multiple links on busses. A better way of dealing multiple links below a device is to feature dummy devices with each their respective bus.
This drops the sconfig capability to declare the same device multiple times which was previously used to declare multiple links.
Signed-off-by: Arthur Heymans arthur@aheymans.xyz Change-Id: Iab6fe269faef46ae77ed1ea425440cf5c7dbd49b --- M src/arch/x86/mpspec.c M src/device/device.c M src/device/device_util.c M src/device/pci_device.c M src/device/root_device.c M src/include/device/device.h M src/northbridge/amd/pi/00730F01/northbridge.c M src/soc/amd/common/block/acpi/ivrs.c M src/soc/amd/common/block/lpc/lpc.c M src/soc/amd/stoneyridge/northbridge.c M src/soc/intel/common/block/lpc/lpc.c M src/southbridge/amd/pi/hudson/lpc.c M util/sconfig/main.c M util/sconfig/sconfig.h M util/sconfig/sconfig.tab.c_shipped M util/sconfig/sconfig.y 16 files changed, 187 insertions(+), 388 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/28/78328/1
diff --git a/src/arch/x86/mpspec.c b/src/arch/x86/mpspec.c index 64712c7..3ecb42b 100644 --- a/src/arch/x86/mpspec.c +++ b/src/arch/x86/mpspec.c @@ -281,48 +281,46 @@ int srcbus; int slot;
- struct bus *link; unsigned char dstirq_x[4];
- for (link = dev->link_list; link; link = link->next) { + if (!dev->link_list) + return;
- child = link->children; - srcbus = link->secondary; + child = dev->link_list->children; + srcbus = dev->link_list->secondary;
- while (child) { - if (child->path.type != DEVICE_PATH_PCI) - goto next; + while (child) { + if (child->path.type != DEVICE_PATH_PCI) + goto next;
- slot = (child->path.pci.devfn >> 3); - /* round pins */ + slot = (child->path.pci.devfn >> 3); + /* round pins */ + for (i = 0; i < 4; i++) + dstirq_x[i] = dstirq[(i + slot) % 4]; + + if ((child->class >> 16) != PCI_BASE_CLASS_BRIDGE) { + /* pci device */ + printk(BIOS_DEBUG, "route irq: %s\n", + dev_path(child)); for (i = 0; i < 4; i++) - dstirq_x[i] = dstirq[(i + slot) % 4]; - - if ((child->class >> 16) != PCI_BASE_CLASS_BRIDGE) { - /* pci device */ - printk(BIOS_DEBUG, "route irq: %s\n", - dev_path(child)); - for (i = 0; i < 4; i++) - smp_write_intsrc(mc, irqtype, irqflag, - srcbus, (slot<<2)|i, dstapic, - dstirq_x[i]); - goto next; - } - - switch (child->class>>8) { - case PCI_CLASS_BRIDGE_PCI: - case PCI_CLASS_BRIDGE_PCMCIA: - case PCI_CLASS_BRIDGE_CARDBUS: - printk(BIOS_DEBUG, "route irq bridge: %s\n", - dev_path(child)); - smp_write_intsrc_pci_bridge(mc, irqtype, - irqflag, child, dstapic, dstirq_x); - } - -next: - child = child->sibling; + smp_write_intsrc(mc, irqtype, irqflag, + srcbus, (slot<<2)|i, dstapic, + dstirq_x[i]); + goto next; }
+ switch (child->class>>8) { + case PCI_CLASS_BRIDGE_PCI: + case PCI_CLASS_BRIDGE_PCMCIA: + case PCI_CLASS_BRIDGE_CARDBUS: + printk(BIOS_DEBUG, "route irq bridge: %s\n", + dev_path(child)); + smp_write_intsrc_pci_bridge(mc, irqtype, + irqflag, child, dstapic, dstirq_x); + } + +next: + child = child->sibling; } }
@@ -477,17 +475,16 @@ memset(buses, 0, sizeof(buses));
for (dev = all_devices; dev; dev = dev->next) { - struct bus *bus; - for (bus = dev->link_list; bus; bus = bus->next) { - if (bus->secondary > 255) { - printk(BIOS_ERR, - "A bus claims to have a bus ID > 255?!? Aborting"); - return; - } - buses[bus->secondary] = 1; - if (highest < bus->secondary) - highest = bus->secondary; + struct bus *bus = dev->link_list; + if (!bus) + continue; + if (bus->secondary > 255) { + printk(BIOS_ERR, "A bus claims to have a bus ID > 255?!? Aborting"); + return; } + buses[bus->secondary] = 1; + if (highest < bus->secondary) + highest = bus->secondary; } for (i = 0; i <= highest; i++) { if (buses[i]) { diff --git a/src/device/device.c b/src/device/device.c index a635e73..6bdbccf 100644 --- a/src/device/device.c +++ b/src/device/device.c @@ -152,13 +152,10 @@ { struct device *curdev;
- printk(BIOS_SPEW, "%s %s bus %d link: %d\n", dev_path(bus->dev), - __func__, bus->secondary, bus->link_num); + printk(BIOS_SPEW, "%s %s bus %d\n", dev_path(bus->dev), __func__, bus->secondary);
/* Walk through all devices and find which resources they need. */ for (curdev = bus->children; curdev; curdev = curdev->sibling) { - struct bus *link; - if (!curdev->enabled) continue;
@@ -172,12 +169,11 @@ curdev->ops->read_resources(curdev);
/* Read in the resources behind the current device's links. */ - for (link = curdev->link_list; link; link = link->next) - read_resources(link); + if (curdev->link_list) + read_resources(curdev->link_list); } post_log_clear(); - printk(BIOS_SPEW, "%s %s bus %d link: %d done\n", - dev_path(bus->dev), __func__, bus->secondary, bus->link_num); + printk(BIOS_SPEW, "%s %s bus %d done\n", dev_path(bus->dev), __func__, bus->secondary); }
struct device *vga_pri = NULL; @@ -266,8 +262,7 @@ { struct device *curdev;
- printk(BIOS_SPEW, "%s %s, bus %d link: %d\n", - dev_path(bus->dev), __func__, bus->secondary, bus->link_num); + printk(BIOS_SPEW, "%s %s, bus %d\n", dev_path(bus->dev), __func__, bus->secondary);
for (curdev = bus->children; curdev; curdev = curdev->sibling) { if (!curdev->enabled || !curdev->resource_list) @@ -282,8 +277,7 @@ curdev->ops->set_resources(curdev); } post_log_clear(); - printk(BIOS_SPEW, "%s %s, bus %d link: %d done\n", - dev_path(bus->dev), __func__, bus->secondary, bus->link_num); + printk(BIOS_SPEW, "%s %s, bus %d done\n", dev_path(bus->dev), __func__, bus->secondary); }
/** @@ -301,7 +295,6 @@ static void enable_resources(struct bus *link) { struct device *dev; - struct bus *c_link;
for (dev = link->children; dev; dev = dev->sibling) { if (dev->enabled && dev->ops && dev->ops->enable_resources) { @@ -311,8 +304,8 @@ }
for (dev = link->children; dev; dev = dev->sibling) { - for (c_link = dev->link_list; c_link; c_link = c_link->next) - enable_resources(c_link); + if (dev->link_list) + enable_resources(dev->link_list); } post_log_clear(); } @@ -359,16 +352,14 @@
do_scan_bus = 1; while (do_scan_bus) { - struct bus *link; + struct bus *link = busdev->link_list; busdev->ops->scan_bus(busdev); do_scan_bus = 0; - for (link = busdev->link_list; link; link = link->next) { - if (link->reset_needed) { - if (reset_bus(link)) - do_scan_bus = 1; - else - busdev->bus->reset_needed = 1; - } + if (link && link->reset_needed) { + if (reset_bus(link)) + do_scan_bus = 1; + else + busdev->bus->reset_needed = 1; } }
@@ -488,13 +479,11 @@ */ void dev_enable(void) { - struct bus *link; - printk(BIOS_INFO, "Enabling resources...\n");
/* Now enable everything. */ - for (link = dev_root.link_list; link; link = link->next) - enable_resources(link); + if (dev_root.link_list) + enable_resources(dev_root.link_list);
printk(BIOS_INFO, "done.\n"); } @@ -518,8 +507,7 @@ long init_time;
if (dev->path.type == DEVICE_PATH_I2C) { - printk(BIOS_DEBUG, "smbus: %s[%d]->", - dev_path(dev->bus->dev), dev->bus->link_num); + printk(BIOS_DEBUG, "smbus: %s->", dev_path(dev->bus->dev)); }
printk(BIOS_DEBUG, "%s init\n", dev_path(dev)); @@ -537,7 +525,6 @@ static void init_link(struct bus *link) { struct device *dev; - struct bus *c_link;
for (dev = link->children; dev; dev = dev->sibling) { post_code(POSTCODE_BS_DEV_INIT); @@ -545,10 +532,9 @@ init_dev(dev); }
- for (dev = link->children; dev; dev = dev->sibling) { - for (c_link = dev->link_list; c_link; c_link = c_link->next) - init_link(c_link); - } + for (dev = link->children; dev; dev = dev->sibling) + if (dev->link_list) + init_link(dev->link_list); }
/** @@ -559,16 +545,14 @@ */ void dev_initialize(void) { - struct bus *link; - printk(BIOS_INFO, "Initializing devices...\n");
/* First call the mainboard init. */ init_dev(&dev_root);
/* Now initialize everything. */ - for (link = dev_root.link_list; link; link = link->next) - init_link(link); + if (dev_root.link_list) + init_link(dev_root.link_list); post_log_clear();
printk(BIOS_INFO, "Devices initialized\n"); @@ -598,15 +582,13 @@ static void final_link(struct bus *link) { struct device *dev; - struct bus *c_link;
for (dev = link->children; dev; dev = dev->sibling) final_dev(dev);
- for (dev = link->children; dev; dev = dev->sibling) { - for (c_link = dev->link_list; c_link; c_link = c_link->next) - final_link(c_link); - } + for (dev = link->children; dev; dev = dev->sibling) + if (dev->link_list) + final_link(dev->link_list); } /** * Finalize all devices in the global device tree. @@ -616,16 +598,13 @@ */ void dev_finalize(void) { - struct bus *link; - printk(BIOS_INFO, "Finalize devices...\n");
/* First call the mainboard finalize. */ final_dev(&dev_root);
/* Now finalize everything. */ - for (link = dev_root.link_list; link; link = link->next) - final_link(link); + final_link(dev_root.link_list);
printk(BIOS_INFO, "Devices finalized\n"); } diff --git a/src/device/device_util.c b/src/device/device_util.c index b37d1d9..a0824bd 100644 --- a/src/device/device_util.c +++ b/src/device/device_util.c @@ -248,14 +248,6 @@ return "unknown"; }
-const char *bus_path(struct bus *bus) -{ - static char buffer[BUS_PATH_MAX]; - snprintf(buffer, sizeof(buffer), - "%s,%d", dev_path(bus->dev), bus->link_num); - return buffer; -} - /** * Allocate 64 more resources to the free list. * @@ -553,15 +545,7 @@
/* If it is a subtractive resource recurse. */ if (res->flags & IORESOURCE_SUBTRACTIVE) { - struct bus *subbus; - for (subbus = curdev->link_list; subbus; - subbus = subbus->next) - if (subbus->link_num - == IOINDEX_SUBTRACTIVE_LINK(res->index)) - break; - if (!subbus) /* Why can subbus be NULL? */ - break; - search_bus_resources(subbus, type_mask, type, + search_bus_resources(curdev->link_list, type_mask, type, search, gp); continue; } @@ -617,9 +601,8 @@ struct device *child;
for (child = bus->children; child; child = child->sibling) { - struct bus *link; - for (link = child->link_list; link; link = link->next) - disable_children(link); + if (child->link_list) + disable_children(child->link_list); dev_set_enabled(child, 0); } } @@ -630,7 +613,6 @@ */ bool dev_is_active_bridge(struct device *dev) { - struct bus *link; struct device *child;
if (!dev || !dev->enabled) @@ -639,71 +621,20 @@ if (!dev->link_list || !dev->link_list->children) return 0;
- for (link = dev->link_list; link; link = link->next) { - for (child = link->children; child; child = child->sibling) { - if (child->path.type == DEVICE_PATH_NONE) - continue; - - if (child->enabled) - return 1; - } + for (child = dev->link_list->children; child; child = child->sibling) { + if (child->path.type == DEVICE_PATH_NONE) + continue; + if (child->enabled) + return 1; }
return 0; }
-/** - * Ensure the device has a minimum number of bus links. - * - * @param dev The device to add links to. - * @param total_links The minimum number of links to have. - */ -void add_more_links(struct device *dev, unsigned int total_links) -{ - struct bus *link, *last = NULL; - int link_num = -1; - - for (link = dev->link_list; link; link = link->next) { - if (link_num < link->link_num) - link_num = link->link_num; - last = link; - } - - if (last) { - int links = total_links - (link_num + 1); - if (links > 0) { - link = malloc(links * sizeof(*link)); - if (!link) - die("Couldn't allocate more links!\n"); - memset(link, 0, links * sizeof(*link)); - last->next = link; - } else { - /* No more links to add */ - return; - } - } else { - link = malloc(total_links * sizeof(*link)); - if (!link) - die("Couldn't allocate more links!\n"); - memset(link, 0, total_links * sizeof(*link)); - dev->link_list = link; - } - - for (link_num = link_num + 1; link_num < total_links; link_num++) { - link->link_num = link_num; - link->dev = dev; - link->next = link + 1; - last = link; - link = link->next; - } - last->next = NULL; -} - static void resource_tree(const struct device *root, int debug_level, int depth) { int i = 0; struct device *child; - struct bus *link; struct resource *res; char indent[30]; /* If your tree has more levels, it's wrong. */
@@ -725,10 +656,11 @@ res->index); }
- for (link = root->link_list; link; link = link->next) { - for (child = link->children; child; child = child->sibling) - resource_tree(child, debug_level, depth + 1); - } + if (!root->link_list) + return; + + for (child = root->link_list->children; child; child = child->sibling) + resource_tree(child, debug_level, depth + 1); }
void print_resource_tree(const struct device *root, int debug_level, @@ -753,7 +685,6 @@ char depth_str[20]; int i; struct device *sibling; - struct bus *link;
for (i = 0; i < depth; i++) depth_str[i] = ' '; @@ -762,11 +693,11 @@ printk(debug_level, "%s%s: enabled %d\n", depth_str, dev_path(dev), dev->enabled);
- for (link = dev->link_list; link; link = link->next) { - for (sibling = link->children; sibling; - sibling = sibling->sibling) - show_devs_tree(sibling, debug_level, depth + 1); - } + if (!dev->link_list) + return; + + for (sibling = dev->link_list->children; sibling; sibling = sibling->sibling) + show_devs_tree(sibling, debug_level, depth + 1); }
void show_all_devs_tree(int debug_level, const char *msg) diff --git a/src/device/pci_device.c b/src/device/pci_device.c index 295e518..dcf4ce3 100644 --- a/src/device/pci_device.c +++ b/src/device/pci_device.c @@ -754,16 +754,13 @@ void pci_dev_set_resources(struct device *dev) { struct resource *res; - struct bus *bus; u8 line;
for (res = dev->resource_list; res; res = res->next) pci_set_resource(dev, res);
- for (bus = dev->link_list; bus; bus = bus->next) { - if (bus->children) - assign_resources(bus); - } + if (dev->link_list && dev->link_list->children) + assign_resources(dev->link_list);
/* Set a default latency timer. */ pci_write_config8(dev, PCI_LATENCY_TIMER, 0x40); diff --git a/src/device/root_device.c b/src/device/root_device.c index d8edbd5..cf5ffb7 100644 --- a/src/device/root_device.c +++ b/src/device/root_device.c @@ -38,31 +38,24 @@ void enable_static_devices(struct device *bus) { struct device *child; - struct bus *link;
- for (link = bus->link_list; link; link = link->next) { - for (child = link->children; child; child = child->sibling) { - enable_static_device(child); - } - } + for (child = bus->link_list->children; child; child = child->sibling) + enable_static_device(child); }
void scan_generic_bus(struct device *bus) { struct device *child; - struct bus *link; static int bus_max = 0;
printk(BIOS_SPEW, "%s for %s\n", __func__, dev_path(bus));
- for (link = bus->link_list; link; link = link->next) { + if (bus->link_list) { + bus->link_list->secondary = ++bus_max;
- link->secondary = ++bus_max; - - for (child = link->children; child; child = child->sibling) { + for (child = bus->link_list->children; child; child = child->sibling) { enable_static_device(child); - printk(BIOS_DEBUG, "bus: %s[%d]->", dev_path(child->bus->dev), - child->bus->link_num); + printk(BIOS_DEBUG, "bus: %s->", dev_path(child->bus->dev)); } }
@@ -82,18 +75,16 @@ * given by the mainboard's `devicetree.cb`. * * First, all direct descendants of the given device are - * enabled. Then, downstream buses are scanned. + * enabled. Then, link_list buses are scanned. */ void scan_static_bus(struct device *bus) { - struct bus *link; - printk(BIOS_SPEW, "%s for %s\n", __func__, dev_path(bus));
enable_static_devices(bus);
- for (link = bus->link_list; link; link = link->next) - scan_bridges(link); + if (bus->link_list) + scan_bridges(bus->link_list);
printk(BIOS_SPEW, "%s for %s done\n", __func__, dev_path(bus)); } diff --git a/src/include/device/device.h b/src/include/device/device.h index 1aa03d0..5d7d06d 100644 --- a/src/include/device/device.h +++ b/src/include/device/device.h @@ -4,11 +4,13 @@
#define DEVICE_H
-#include <device/resource.h> +#include <console/console.h> #include <device/path.h> #include <device/pci_type.h> +#include <device/resource.h> #include <smbios.h> #include <static.h> +#include <stdlib.h> #include <types.h>
struct fw_config; @@ -80,10 +82,8 @@ struct bus { DEVTREE_CONST struct device *dev; /* This bridge device */ DEVTREE_CONST struct device *children; /* devices behind this bridge */ - DEVTREE_CONST struct bus *next; /* The next bridge on this device */ unsigned int bridge_ctrl; /* Bridge control register */ uint16_t bridge_cmd; /* Bridge command register */ - unsigned char link_num; /* The index of this link */ uint16_t secondary; /* secondary bus number */ uint16_t subordinate; /* subordinate bus number */ uint16_t max_subordinate; /* max subordinate bus number */ @@ -189,11 +189,9 @@ const char *dev_name(const struct device *dev); const char *dev_path(const struct device *dev); u32 dev_path_encode(const struct device *dev); -const char *bus_path(struct bus *bus); void dev_set_enabled(struct device *dev, int enable); void disable_children(struct bus *bus); bool dev_is_active_bridge(struct device *dev); -void add_more_links(struct device *dev, unsigned int total_links); bool is_dev_enabled(const struct device *const dev); bool is_devfn_enabled(unsigned int devfn); bool is_cpu(const struct device *cpu); @@ -237,8 +235,12 @@ * alloc_find_dev calls in init_bsp and allocate_cpu_devices will be able to add a * LAPIC device for the BSP and the APs on this link/bus. */ - if (!dev->link_list) - add_more_links(dev, 1); + if (!dev->link_list) { + struct bus *bus = calloc(1, sizeof(struct bus)); + if (!bus) + die("Couldn't allocate downstream bus!\n"); + dev->link_list = bus; + }
mp_init_cpus(dev->link_list); } diff --git a/src/northbridge/amd/pi/00730F01/northbridge.c b/src/northbridge/amd/pi/00730F01/northbridge.c index bafe5a5..f471a00 100644 --- a/src/northbridge/amd/pi/00730F01/northbridge.c +++ b/src/northbridge/amd/pi/00730F01/northbridge.c @@ -173,29 +173,14 @@
static void create_vga_resource(struct device *dev, unsigned int nodeid) { - struct bus *link; unsigned int sblink;
sblink = (pci_read_config32(get_mc_dev(), 0x64) >> 8) & 7; // don't forget sublink1
- /* find out which link the VGA card is connected, - * we only deal with the 'first' vga card */ - for (link = dev->link_list; link; link = link->next) { - if (link->bridge_ctrl & PCI_BRIDGE_CTL_VGA) { -#if CONFIG(MULTIPLE_VGA_ADAPTERS) - extern struct device *vga_pri; // the primary vga device, defined in device.c - printk(BIOS_DEBUG, "VGA: vga_pri bus num = %d bus range [%d,%d]\n", vga_pri->bus->secondary, - link->secondary, link->subordinate); - /* We need to make sure the vga_pri is under the link */ - if ((vga_pri->bus->secondary >= link->secondary) && - (vga_pri->bus->secondary <= link->subordinate)) -#endif - break; - } - } + if (!dev->link_list) + return;
- /* no VGA card installed */ - if (link == NULL) + if (!(dev->link_list->bridge_ctrl & PCI_BRIDGE_CTL_VGA)) return;
printk(BIOS_DEBUG, "VGA: %s (aka node %d) link %d has VGA device\n", dev_path(dev), nodeid, sblink); @@ -363,7 +348,6 @@ unsigned long *current, uint16_t *ivhd_length) { struct device *sibling; - struct bus *link;
if (!root_level) { root_level = malloc(sizeof(int8_t)); @@ -382,11 +366,11 @@ } }
- for (link = dev->link_list; link; link = link->next) - for (sibling = link->children; sibling; sibling = - sibling->sibling) + if (dev->link_list) { + for (sibling = dev->link_list->children; sibling; sibling = sibling->sibling) add_ivhd_device_entries(dev, sibling, depth + 1, depth, root_level, current, ivhd_length); + }
free(root_level); } diff --git a/src/soc/amd/common/block/acpi/ivrs.c b/src/soc/amd/common/block/acpi/ivrs.c index 814f514..03e1fae 100644 --- a/src/soc/amd/common/block/acpi/ivrs.c +++ b/src/soc/amd/common/block/acpi/ivrs.c @@ -142,7 +142,6 @@ unsigned long *current, uint16_t nb_bus) { struct device *sibling; - struct bus *link;
if (!root_level) return; @@ -157,11 +156,11 @@ ivrs_add_device_or_bridge(parent, dev, current); }
- for (link = dev->link_list; link; link = link->next) - for (sibling = link->children; sibling; sibling = - sibling->sibling) - add_ivhd_device_entries(dev, sibling, depth + 1, depth, root_level, - current, nb_bus); + if (!dev->link_list) + return; + for (sibling = dev->link_list->children; sibling; sibling = sibling->sibling) + add_ivhd_device_entries(dev, sibling, depth + 1, depth, root_level, current, + nb_bus); }
static unsigned long acpi_ivhd_misc(unsigned long current, struct device *dev) diff --git a/src/soc/amd/common/block/lpc/lpc.c b/src/soc/amd/common/block/lpc/lpc.c index 96b9a2c..ca881a2 100644 --- a/src/soc/amd/common/block/lpc/lpc.c +++ b/src/soc/amd/common/block/lpc/lpc.c @@ -279,20 +279,20 @@
static void lpc_enable_children_resources(struct device *dev) { - struct bus *link; struct device *child;
- for (link = dev->link_list; link; link = link->next) { - for (child = link->children; child; child = child->sibling) { - if (!child->enabled) - continue; - if (child->path.type != DEVICE_PATH_PNP) - continue; - if (CONFIG(SOC_AMD_COMMON_BLOCK_USE_ESPI)) - configure_child_espi_windows(child); - else - configure_child_lpc_windows(dev, child); - } + if (!dev->link_list) + return; + + for (child = dev->link_list->children; child; child = child->sibling) { + if (!child->enabled) + continue; + if (child->path.type != DEVICE_PATH_PNP) + continue; + if (CONFIG(SOC_AMD_COMMON_BLOCK_USE_ESPI)) + configure_child_espi_windows(child); + else + configure_child_lpc_windows(dev, child); } }
diff --git a/src/soc/amd/stoneyridge/northbridge.c b/src/soc/amd/stoneyridge/northbridge.c index 081bc1f..66ebd2a 100644 --- a/src/soc/amd/stoneyridge/northbridge.c +++ b/src/soc/amd/stoneyridge/northbridge.c @@ -125,16 +125,11 @@
static void create_vga_resource(struct device *dev) { - struct bus *link; - /* find out which link the VGA card is connected, * we only deal with the 'first' vga card */ - for (link = dev->link_list ; link ; link = link->next) - if (link->bridge_ctrl & PCI_BRIDGE_CTL_VGA) - break; - - /* no VGA card installed */ - if (link == NULL) + if (!dev->link_list) + return; + if (!(dev->link_list->bridge_ctrl & PCI_BRIDGE_CTL_VGA)) return;
printk(BIOS_DEBUG, "VGA: %s has VGA device\n", dev_path(dev)); @@ -144,7 +139,6 @@
static void set_resources(struct device *dev) { - struct bus *bus; struct resource *res;
/* do we need this? */ @@ -154,9 +148,8 @@ for (res = dev->resource_list ; res ; res = res->next) set_resource(dev, res, 0);
- for (bus = dev->link_list ; bus ; bus = bus->next) - if (bus->children) - assign_resources(bus); + if (dev->link_list && dev->link_list->children) + assign_resources(dev->link_list); }
static void northbridge_init(struct device *dev) diff --git a/src/soc/intel/common/block/lpc/lpc.c b/src/soc/intel/common/block/lpc/lpc.c index 0de3154..283a07e 100644 --- a/src/soc/intel/common/block/lpc/lpc.c +++ b/src/soc/intel/common/block/lpc/lpc.c @@ -100,13 +100,13 @@ */ static void pch_lpc_set_child_resources(struct device *dev) { - struct bus *link; struct device *child;
- for (link = dev->link_list; link; link = link->next) { - for (child = link->children; child; child = child->sibling) - pch_lpc_loop_resources(child); - } + if (!dev->link_list) + return; + + for (child = dev->link_list->children; child; child = child->sibling) + pch_lpc_loop_resources(child); }
static void pch_lpc_set_resources(struct device *dev) diff --git a/src/southbridge/amd/pi/hudson/lpc.c b/src/southbridge/amd/pi/hudson/lpc.c index 0a4e038..7246fe1 100644 --- a/src/southbridge/amd/pi/hudson/lpc.c +++ b/src/southbridge/amd/pi/hudson/lpc.c @@ -134,7 +134,6 @@ */ static void hudson_lpc_enable_childrens_resources(struct device *dev) { - struct bus *link; u32 reg, reg_x; int var_num = 0; u16 reg_var[3]; @@ -171,12 +170,10 @@ reg_var[1] = pci_read_config16(dev, 0x66); reg_var[0] = pci_read_config16(dev, 0x64);
- for (link = dev->link_list; link; link = link->next) { - struct device *child; - for (child = link->children; child; - child = child->sibling) { - if (child->enabled - && (child->path.type == DEVICE_PATH_PNP)) { + struct device *child; + if (dev->link_list) { + for (child = dev->link_list->children; child; child = child->sibling) { + if (child->enabled && (child->path.type == DEVICE_PATH_PNP)) { struct resource *res; for (res = child->resource_list; res; res = res->next) { u32 base, end; /* don't need long long */ @@ -187,7 +184,7 @@ end = resource_end(res); /* find a resource size */ printk(BIOS_DEBUG, "hudson lpc decode:%s, base=0x%08x, end=0x%08x\n", - dev_path(child), base, end); + dev_path(child), base, end); switch (base) { case 0x60: /* KB */ case 0x64: /* MS */ @@ -255,16 +252,16 @@ rsize = 0; /* try AGESA allocated region in region 0 */ if ((var_num > 0) && ((base >= reg_var[0]) && - ((base + res->size) <= (reg_var[0] + reg_size[0])))) + ((base + res->size) <= (reg_var[0] + reg_size[0])))) rsize = reg_size[0]; } /* check if region found and matches the enable */ if (res->size <= rsize) { reg |= set; reg_x |= set_x; - /* check if we can fit resource in variable range */ + /* check if we can fit resource in variable range */ } else if ((var_num < 3) && - ((res->size <= 16) || (res->size == 512))) { + ((res->size <= 16) || (res->size == 512))) { /* use variable ranges if pre-defined do not match */ switch (var_num) { case 0: @@ -285,10 +282,10 @@ break; } reg_var[var_num++] = - base & 0xffff; + base & 0xffff; } else { printk(BIOS_ERR, "cannot fit LPC decode region:%s, base=0x%08x, end=0x%08x\n", - dev_path(child), base, end); + dev_path(child), base, end); } } } diff --git a/util/sconfig/main.c b/util/sconfig/main.c index dd26e07..7befb1e 100644 --- a/util/sconfig/main.c +++ b/util/sconfig/main.c @@ -81,7 +81,6 @@ static struct chip_instance mainboard_instance;
static struct bus base_root_bus = { - .id = 0, .dev = &base_root_dev, };
@@ -95,7 +94,6 @@ };
static struct bus chipset_root_bus = { - .id = 0, .dev = &chipset_root_dev, };
@@ -109,7 +107,6 @@ };
static struct bus override_root_bus = { - .id = 0, .dev = &override_root_dev, };
@@ -723,30 +720,13 @@ bus->dev->ops_id = ops_id; }
-/* - * Allocate a new bus for the provided device. - * - If this is the first bus being allocated under this device, then its id - * is set to 0 and bus and last_bus are pointed to the newly allocated bus. - * - If this is not the first bus under this device, then its id is set to 1 - * plus the id of last bus and newly allocated bus is added to the list of - * buses under the device. last_bus is updated to point to the newly - * allocated bus. - */ +/* Allocate a new bus for the provided device. */ static void alloc_bus(struct device *dev) { struct bus *bus = S_ALLOC(sizeof(*bus));
bus->dev = dev; - - if (dev->last_bus == NULL) { - bus->id = 0; - dev->bus = bus; - } else { - bus->id = dev->last_bus->id + 1; - dev->last_bus->next_bus = bus; - } - - dev->last_bus = bus; + dev->bus = bus; }
/* @@ -814,14 +794,12 @@ if (parent->alias && !strcmp(parent->alias, alias)) return parent;
- const struct bus *bus; - for (bus = parent->bus; bus; bus = bus->next_bus) { - const struct device *child; - for (child = bus->children; child; child = child->sibling) { - const struct device *const ret = find_alias(child, alias); - if (ret) - return ret; - } + const struct bus *bus = parent->bus; + const struct device *child; + for (child = bus->children; child; child = child->sibling) { + const struct device *const ret = find_alias(child, alias); + if (ret) + return ret; }
return NULL; @@ -834,11 +812,11 @@ { struct device *new_d;
- /* If device is found under parent, no need to allocate new device. */ + /* We don't allow duplicate devices in devicetree. */ new_d = get_dev(parent, path_a, path_b, bustype, chip_instance); if (new_d) { - alloc_bus(new_d); - return new_d; + printf("ERROR: Duplicate device! %s\n", new_d->name); + exit(1); }
new_d = alloc_dev(parent); @@ -1084,11 +1062,8 @@ { struct bus *bus = dev->bus;
- while (bus) { - if (bus->children) - return 1; - bus = bus->next_bus; - } + if (bus && bus->children) + return 1;
return 0; } @@ -1098,7 +1073,7 @@ static int dev_id;
if (ptr == &base_root_dev) { - fprintf(fil, "STORAGE struct bus %s_links[];\n", + fprintf(fil, "STORAGE struct bus %s_bus;\n", ptr->name); return; } @@ -1120,7 +1095,7 @@ fprintf(fil, "STORAGE struct resource %s_res[];\n", ptr->name); if (dev_has_children(ptr)) - fprintf(fil, "STORAGE struct bus %s_links[];\n", + fprintf(fil, "STORAGE struct bus %s_bus;\n", ptr->name);
if (next) @@ -1192,35 +1167,18 @@ fprintf(fil, "\t };\n"); }
-static void emit_bus(FILE *fil, struct bus *bus) +static void emit_dev_bus(FILE *fil, struct device *ptr) { - fprintf(fil, "\t\t[%d] = {\n", bus->id); - fprintf(fil, "\t\t\t.link_num = %d,\n", bus->id); - fprintf(fil, "\t\t\t.dev = &%s,\n", bus->dev->name); - if (bus->children) - fprintf(fil, "\t\t\t.children = &%s,\n", bus->children->name); - - if (bus->next_bus) - fprintf(fil, "\t\t\t.next=&%s_links[%d],\n", bus->dev->name, - bus->id + 1); - else - fprintf(fil, "\t\t\t.next = NULL,\n"); - fprintf(fil, "\t\t},\n"); -} - -static void emit_dev_links(FILE *fil, struct device *ptr) -{ - fprintf(fil, "STORAGE struct bus %s_links[] = {\n", + fprintf(fil, "STORAGE struct bus %s_bus = {\n", ptr->name);
struct bus *bus = ptr->bus;
- while (bus) { - emit_bus(fil, bus); - bus = bus->next_bus; - } + fprintf(fil, "\t.dev = &%s,\n", bus->dev->name); + if (bus->children) + fprintf(fil, "\t.children = &%s,\n", bus->children->name);
- fprintf(fil, "\t};\n"); + fprintf(fil, "};\n"); }
static struct chip_instance *get_chip_instance(const struct device *dev) @@ -1268,8 +1226,7 @@ else fprintf(fil, "\t.ops = NULL,\n"); fprintf(fil, "#endif\n"); - fprintf(fil, "\t.bus = &%s_links[%d],\n", ptr->parent->dev->name, - ptr->parent->id); + fprintf(fil, "\t.bus = &%s_bus,\n", ptr->parent->dev->name); fprintf(fil, "\t.path = {"); fprintf(fil, ptr->path, ptr->path_a, ptr->path_b); fprintf(fil, "},\n"); @@ -1290,7 +1247,7 @@ ptr->name); } if (has_children) - fprintf(fil, "\t.link_list = &%s_links[0],\n", + fprintf(fil, "\t.link_list = &%s_bus,\n", ptr->name); else fprintf(fil, "\t.link_list = NULL,\n"); @@ -1319,7 +1276,7 @@ emit_resources(fil, ptr);
if (has_children) - emit_dev_links(fil, ptr); + emit_dev_bus(fil, ptr); }
static void expose_device_names(FILE *fil, FILE *head, struct device *ptr, struct device *next) @@ -1370,11 +1327,8 @@ { struct bus *bus = d->bus;
- while (bus) { - if (bus->children) - add_siblings_to_queue(bfs_q_head, bus->children); - bus = bus->next_bus; - } + if (bus && bus->children) + add_siblings_to_queue(bfs_q_head, bus->children); }
static void walk_device_tree(FILE *fil, FILE *head, struct device *ptr, @@ -1722,16 +1676,6 @@ * | | and value from override register. | * | | | * +-----------------------------------------------------------------+ - * | | | - * | bus | Recursively call override_devicetree on | - * | last_bus | each bus of override device. It is assumed | - * | | that bus with id X under base device | - * | | to bus with id X under override device. If | - * | | override device has more buses than base | - * | | device, then new buses are allocated under | - * | | base device. | - * | | | - * +-----------------------------------------------------------------+ */ static void update_device(struct device *base_dev, struct device *override_dev) { @@ -1841,29 +1785,20 @@ /* * Now that the device properties are all copied over, look at each bus * of the override device and run override_devicetree in a recursive - * manner. The assumption here is that first bus of override device - * corresponds to first bus of base device and so on. If base device has - * lesser buses than override tree, then new buses are allocated for it. + * manner. If base device has no bus but the override tree has, then a new + * buses is allocated for it. */ struct bus *override_bus = override_dev->bus; struct bus *base_bus = base_dev->bus;
- while (override_bus) { + /* + * If we have more buses in override tree device, then allocate + * a new bus for the base tree device as well. + */ + if (!base_bus) + alloc_bus(base_dev);
- /* - * If we have more buses in override tree device, then allocate - * a new bus for the base tree device as well. - */ - if (!base_bus) { - alloc_bus(base_dev); - base_bus = base_dev->last_bus; - } - - override_devicetree(base_dev->bus, override_dev->bus); - - override_bus = override_bus->next_bus; - base_bus = base_bus->next_bus; - } + override_devicetree(base_dev->bus, override_dev->bus); }
/* diff --git a/util/sconfig/sconfig.h b/util/sconfig/sconfig.h index cb8f7b3..fb49f9f 100644 --- a/util/sconfig/sconfig.h +++ b/util/sconfig/sconfig.h @@ -106,17 +106,11 @@
struct device; struct bus { - /* Instance/ID of the bus under the device. */ - int id; - /* Pointer to device to which this bus belongs. */ struct device *dev;
/* Pointer to list of children. */ struct device *children; - - /* Pointer to next bus for the device. */ - struct bus *next_bus; };
struct device { diff --git a/util/sconfig/sconfig.tab.c_shipped b/util/sconfig/sconfig.tab.c_shipped index cb60fb5..5b10922 100644 --- a/util/sconfig/sconfig.tab.c_shipped +++ b/util/sconfig/sconfig.tab.c_shipped @@ -1238,7 +1238,7 @@ case 26: /* @2: %empty */ { (yyval.dev) = new_device_raw(cur_parent, cur_chip_instance, (yyvsp[-3].number), (yyvsp[-2].string), (yyvsp[-1].string), (yyvsp[0].number)); - cur_parent = (yyval.dev)->last_bus; + cur_parent = (yyval.dev)->bus; } break;
@@ -1251,7 +1251,7 @@ case 28: /* @3: %empty */ { (yyval.dev) = new_device_reference(cur_parent, cur_chip_instance, (yyvsp[-1].string), (yyvsp[0].number)); - cur_parent = (yyval.dev)->last_bus; + cur_parent = (yyval.dev)->bus; } break;
diff --git a/util/sconfig/sconfig.y b/util/sconfig/sconfig.y index 17ab9a5..8ec103c 100644 --- a/util/sconfig/sconfig.y +++ b/util/sconfig/sconfig.y @@ -44,7 +44,7 @@
device: DEVICE BUS NUMBER /* == devnum */ alias status { $<dev>$ = new_device_raw(cur_parent, cur_chip_instance, $<number>2, $<string>3, $<string>4, $<number>5); - cur_parent = $<dev>$->last_bus; + cur_parent = $<dev>$->bus; } devicechildren END { cur_parent = $<dev>6->parent; @@ -52,7 +52,7 @@
device: DEVICE REFERENCE STRING status { $<dev>$ = new_device_reference(cur_parent, cur_chip_instance, $<string>3, $<number>4); - cur_parent = $<dev>$->last_bus; + cur_parent = $<dev>$->bus; } devicechildren END { cur_parent = $<dev>5->parent;
