Patrick Georgi has submitted this change and it was merged. ( https://review.coreboot.org/29456 )
Change subject: util/docker: Unify local build targets ......................................................................
Add a `docker-run-local` target that is used as a template for the local build targets (`docker-build-coreboot`, `docker-abuild`, and `docker-what-jenkins-does`).
Note this changes the user for `docker-what-jenkins-does` which has (ccache) issues if it's not `root`. Will be fixed in a follow-up.
Change-Id: I9088fb9211726cddc37b17ddf70170c2c382679e Signed-off-by: Nico Huber nico.h@gmx.de Reviewed-on: https://review.coreboot.org/29456 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Patrick Georgi pgeorgi@google.com --- M util/docker/Makefile 1 file changed, 12 insertions(+), 18 deletions(-)
diff --git a/util/docker/Makefile b/util/docker/Makefile index beb2a7e..32714fc 100644 --- a/util/docker/Makefile +++ b/util/docker/Makefile @@ -95,29 +95,23 @@ $(DOCKER) rmi $$($(DOCKER) images | grep -v "REPOSITORY" | tr -s ' ' | cut -f3 -d ' '); \ fi
-docker-build-coreboot: test-docker +docker-run-local: test-docker $(DOCKER) run -u root -it -v $(top):/home/coreboot/coreboot \ --user $(UID):$(GID) \ --rm coreboot/coreboot-sdk:$(COREBOOT_CONTAINER_VERSION) \ - /bin/bash -c "cd /home/coreboot/coreboot && \ - make clean && \ - make $(BUILD_CMD); \ - rm .xcompile" + /bin/bash -c "cd /home/coreboot/coreboot && $(DOCKER_RUN_LOCAL)"
-docker-abuild: test-docker - $(DOCKER) run -u root -it -v $(top):/home/coreboot/coreboot \ - --user $(UID):$(GID) \ - --rm coreboot/coreboot-sdk:$(COREBOOT_CONTAINER_VERSION) \ - /bin/bash -c "cd /home/coreboot/coreboot && \ - make clean && \ - util/abuild/abuild $(ABUILD_ARGS); \ - rm -f .xcompile" +docker-build-coreboot: docker-run-local +docker-build-coreboot: override DOCKER_RUN_LOCAL := \ + make clean && make $(BUILD_CMD); rm -f .xcompile
-docker-what-jenkins-does: test-docker - $(DOCKER) run -u root -it -v $(top):/home/coreboot/coreboot \ - --rm coreboot/coreboot-sdk:$(COREBOOT_CONTAINER_VERSION) \ - /bin/bash -c "cd /home/coreboot/coreboot && \ - make clean && make what-jenkins-does CPUS=$(CPUS)" +docker-abuild: docker-run-local +docker-abuild: override DOCKER_RUN_LOCAL := \ + make clean && util/abuild/abuild $(ABUILD_ARGS); rm -f .xcompile + +docker-what-jenkins-does: docker-run-local +docker-what-jenkins-does: override DOCKER_RUN_LOCAL := \ + make clean && make what-jenkins-does CPUS=$(CPUS)
docker-jenkins-server: test-docker @if [ ! -d "$(COREBOOT_JENKINS_CACHE_DIR)" ]; then \
