Furquan Shaikh (furquan@google.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/17090
commit 136b4accfdfb86487fc54747230f71e2da653c08 Author: Furquan Shaikh furquan@chromium.org Date: Fri Oct 21 16:37:41 2016 -0700
arch/x86/acpigen: Add support for _DSM method generation
Add acpigen_write_dsm that generates ACPI AML code for _DSM method. Caller should provide set of callbacks with callback[i] corresponding to function index i of DSM method. Local0 and Local1 should not be used in any of the callbacks.
BUG=chrome-os-partner:57846
Change-Id: Ie18cba080424488fe00cc626ea50aa92c1dbb199 Signed-off-by: Furquan Shaikh furquan@chromium.org --- src/arch/x86/acpigen.c | 60 +++++++++++++++++++++++++++++++++++++ src/arch/x86/include/arch/acpigen.h | 8 +++++ 2 files changed, 68 insertions(+)
diff --git a/src/arch/x86/acpigen.c b/src/arch/x86/acpigen.c index 35735b5..7600100 100644 --- a/src/arch/x86/acpigen.c +++ b/src/arch/x86/acpigen.c @@ -1046,6 +1046,66 @@ void acpigen_write_return_byte(uint8_t arg) acpigen_write_byte(arg); }
+/* + * Generate ACPI AML code for _DSM method. + * This function takes as input uuid for the device, set of callbacks and + * argument to pass into the callbacks. Callbacks should ensure that Local0 and + * Local1 are left untouched. Use of Local2-Local7 is permitted in callbacks. + */ +void acpigen_write_dsm(const char *uuid, void (*callbacks[])(void *), + size_t count, void *arg) +{ + size_t i; + + /* Method (_DSM, 4, Serialized) */ + acpigen_write_method_serialized("_DSM", 0x4); + + /* ToBuffer (Arg0, Local0) */ + acpigen_write_to_buffer(ARG0_OP, LOCAL0_OP); + + /* If (LEqual (Local0, ToUUID(uuid))) */ + acpigen_write_if(); + acpigen_emit_byte(LEQUAL_OP); + acpigen_emit_byte(LOCAL0_OP); + acpigen_write_uuid(uuid); + + /* ToInteger (Arg2, Local1) */ + acpigen_write_to_integer(ARG2_OP, LOCAL1_OP); + acpigen_write_debug_op(LOCAL1_OP); + + for (i = 0; i < count; i++) { + /* If (Lequal (Local1, i)) */ + acpigen_write_if_lequal(LOCAL1_OP, i); + + /* Callback to write if handler. */ + if (callbacks[i]) + callbacks[i](arg); + + acpigen_pop_len(); /* If */ + + /* Else */ + acpigen_write_else(); + } + + /* Default case: Return (Buffer (One) { 0x0 }) */ + acpigen_write_return_singleton_buffer(0x0); + + /* Pop lengths for all the else clauses. */ + for (i = 0; i < count; i++) + acpigen_pop_len(); + + acpigen_pop_len(); /* If (LEqual (Local0, ToUUID(uuid))) */ + + /* Else */ + acpigen_write_else(); + + /* Return (Buffer (One) { 0x0 }) */ + acpigen_write_return_singleton_buffer(0x0); + + acpigen_pop_len(); /* Else */ + acpigen_pop_len(); /* Method _DSM */ +} + /* Soc-implemented functions -- weak definitions. */ int __attribute__((weak)) acpigen_soc_read_rx_gpio(unsigned int gpio_num) { diff --git a/src/arch/x86/include/arch/acpigen.h b/src/arch/x86/include/arch/acpigen.h index dd83db8..7c15a31 100644 --- a/src/arch/x86/include/arch/acpigen.h +++ b/src/arch/x86/include/arch/acpigen.h @@ -167,6 +167,14 @@ void acpigen_write_byte_buffer(uint8_t *arr, uint8_t size); void acpigen_write_return_byte_buffer(uint8_t *arr, uint8_t size); void acpigen_write_return_singleton_buffer(uint8_t arg); void acpigen_write_return_byte(uint8_t arg); +/* + * Generate ACPI AML code for _DSM method. + * This function takes as input uuid for the device, set of callbacks and + * argument to pass into the callbacks. Callbacks should ensure that Local0 and + * Local1 are left untouched. Use of Local2-Local7 is permitted in callbacks. + */ +void acpigen_write_dsm(const char *uuid, void (*callbacks[])(void *), + size_t count, void *arg);
int get_cst_entries(acpi_cstate_t **);
