Matt DeVillier has submitted this change. ( https://review.coreboot.org/c/coreboot/+/86991?usp=email )
Change subject: mb/intel/ptlrvp: Introduce PTL RVP External and Internal EC Configurations ......................................................................
This commit adds configurations for both external and internal EC versions of the PTL RVP board. The changes involve updates to the Kconfig files to select appropriate EC configurations based on the specific PTL RVP variant. By organizing these options, it ensures that the build system selects the right EC components and configurations, aligning with the specific needs of the board version in use.
The new configuration for external EC (`BOARD_INTEL_PTLRVP_CHROMEEC`) enables Chrome EC related config options and enables TPM, whereas Intel EC (`BOARD_INTEL_PTLRVP`) disables Chrome EC related config options and uses MOCK TPM.
BUG=none TEST=Build the firmware for PTL RVP with both external and internal EC settings, verifying that the correct components are included based on the chosen configuration. Ensure that the board operates correctly with the selected EC setup.
Change-Id: Ic3e40f2a19d7ed4f7a16e6e516a284a9a778b9fd Signed-off-by: Bora Guvendik bora.guvendik@intel.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/86991 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Matt DeVillier matt.devillier@gmail.com Reviewed-by: Jérémy Compostella jeremy.compostella@intel.com --- M src/mainboard/intel/ptlrvp/Kconfig M src/mainboard/intel/ptlrvp/Kconfig.name M src/mainboard/intel/ptlrvp/Makefile.mk A src/mainboard/intel/ptlrvp/intel.c M src/mainboard/intel/ptlrvp/smihandler.c M src/mainboard/intel/ptlrvp/variants/baseboard/ptlrvp/Makefile.mk M src/mainboard/intel/ptlrvp/variants/baseboard/ptlrvp/devicetree.cb M src/mainboard/intel/ptlrvp/variants/ptlrvp/overridetree.cb A src/mainboard/intel/ptlrvp/variants/ptlrvp_chromeec/overridetree.cb 9 files changed, 974 insertions(+), 27 deletions(-)
Approvals: build bot (Jenkins): Verified Jérémy Compostella: Looks good to me, approved Matt DeVillier: Looks good to me, approved
diff --git a/src/mainboard/intel/ptlrvp/Kconfig b/src/mainboard/intel/ptlrvp/Kconfig index 73e170d..ad6ac41 100644 --- a/src/mainboard/intel/ptlrvp/Kconfig +++ b/src/mainboard/intel/ptlrvp/Kconfig @@ -16,21 +16,14 @@ select DRIVERS_SPI_ACPI select DUMP_SMBIOS_TYPE17 select EC_ACPI - select EC_GOOGLE_CHROMEEC - select EC_GOOGLE_CHROMEEC_BOARDID - select EC_GOOGLE_CHROMEEC_ESPI - select EC_GOOGLE_CHROMEEC_SMBIOS select FW_CONFIG - select FW_CONFIG_SOURCE_CHROMEEC_CBI select GENERATE_SMBIOS_TABLES select GOOGLE_SMBIOS_MAINBOARD_VERSION select HAVE_ACPI_RESUME select HAVE_ACPI_TABLES select HAVE_SPD_IN_CBFS - select I2C_TPM select INTEL_LPSS_UART_FOR_CONSOLE select MAINBOARD_DISABLE_STAGE_CACHE - select MAINBOARD_HAS_TPM2 select MB_COMPRESS_RAMSTAGE_LZ4 select PMC_IPC_ACPI_INTERFACE select SOC_INTEL_COMMON_BLOCK_VARIANT_POWER_LIMIT @@ -53,7 +46,6 @@ select SOC_INTEL_IOE_DIE_SUPPORT select SOC_INTEL_ENABLE_USB4_PCIE_RESOURCES select SYSTEM_TYPE_LAPTOP - select TPM_GOOGLE_TI50
config BOARD_INTEL_MODEL_PTLRVP def_bool n @@ -63,8 +55,22 @@
config BOARD_INTEL_PTLRVP select BOARD_INTEL_MODEL_PTLRVP - select EC_GOOGLE_CHROMEEC_MEC select MAINBOARD_USES_IFD_EC_REGION + select FW_CONFIG_SOURCE_CBFS + +config BOARD_INTEL_PTLRVP_CHROMEEC + select BOARD_INTEL_MODEL_PTLRVP + select EC_GOOGLE_CHROMEEC + select EC_GOOGLE_CHROMEEC_BOARDID + select EC_GOOGLE_CHROMEEC_ESPI + select EC_GOOGLE_CHROMEEC_MEC + select EC_GOOGLE_CHROMEEC_SKUID + select EC_GOOGLE_CHROMEEC_SMBIOS + select FW_CONFIG_SOURCE_CHROMEEC_CBI + select I2C_TPM + select MAINBOARD_HAS_TPM2 + select MAINBOARD_USES_IFD_EC_REGION + select TPM_GOOGLE_TI50
if BOARD_INTEL_PTLRVP_COMMON
@@ -73,7 +79,7 @@ default "ptlrvp"
config CHROMEOS - select EC_GOOGLE_CHROMEEC_SWITCHES + select EC_GOOGLE_CHROMEEC_SWITCHES if BOARD_INTEL_PTLRVP_CHROMEEC select GBB_FLAG_DISABLE_EC_SOFTWARE_SYNC select GBB_FLAG_FORCE_DEV_BOOT_USB select GBB_FLAG_FORCE_MANUAL_RECOVERY @@ -95,11 +101,11 @@
config DRIVER_TPM_I2C_ADDR hex - default 0x50 + default 0x50 if BOARD_INTEL_PTLRVP_CHROMEEC
config DRIVER_TPM_I2C_BUS hex - default 0x03 if BOARD_INTEL_MODEL_PTLRVP + default 0x03 if BOARD_INTEL_PTLRVP_CHROMEEC
config HAVE_SLP_S0_GATE def_bool n @@ -112,16 +118,16 @@ default "Intel_Ptlrvp"
config MAINBOARD_PART_NUMBER - default "Ptlrvp" if BOARD_INTEL_PTLRVP + default "Ptlrvp"
config MEMORY_SOLDERDOWN def_bool n - select CHROMEOS_DRAM_PART_NUMBER_IN_CBI if CHROMEOS + select CHROMEOS_DRAM_PART_NUMBER_IN_CBI if CHROMEOS && EC_GOOGLE_CHROMEEC_MEC select HAVE_SPD_IN_CBFS
config TPM_TIS_ACPI_INTERRUPT int - default 47 if BOARD_INTEL_MODEL_PTLRVP # GPE0_DW1_15 (GPP_D15) + default 47 if BOARD_INTEL_PTLRVP_CHROMEEC # GPE0_DW1_15 (GPP_D15)
# FIXME: update as per board schematics config UART_FOR_CONSOLE @@ -136,9 +142,11 @@ default "ptlrvp" if BOARD_INTEL_MODEL_PTLRVP
config OVERRIDE_DEVICETREE - default "variants/$(CONFIG_VARIANT_DIR)/overridetree.cb" + default "variants/$(CONFIG_VARIANT_DIR)/overridetree.cb" if BOARD_INTEL_PTLRVP + default "variants/$(CONFIG_VARIANT_DIR)_chromeec/overridetree.cb" if BOARD_INTEL_PTLRVP_CHROMEEC
config VBOOT select VBOOT_LID_SWITCH + select VBOOT_MOCK_SECDATA if BOARD_INTEL_PTLRVP
endif # BOARD_INTEL_PTLRVP_COMMON diff --git a/src/mainboard/intel/ptlrvp/Kconfig.name b/src/mainboard/intel/ptlrvp/Kconfig.name index f8d8f17..9bcf99b 100644 --- a/src/mainboard/intel/ptlrvp/Kconfig.name +++ b/src/mainboard/intel/ptlrvp/Kconfig.name @@ -4,3 +4,6 @@
config BOARD_INTEL_PTLRVP bool "-> Ptlrvp" + +config BOARD_INTEL_PTLRVP_CHROMEEC + bool "-> Google Chrome EC" diff --git a/src/mainboard/intel/ptlrvp/Makefile.mk b/src/mainboard/intel/ptlrvp/Makefile.mk index aea91d5..d2c78f4 100644 --- a/src/mainboard/intel/ptlrvp/Makefile.mk +++ b/src/mainboard/intel/ptlrvp/Makefile.mk @@ -3,14 +3,17 @@ bootblock-y += bootblock.c
verstage-$(CONFIG_CHROMEOS) += chromeos.c +verstage-$(CONFIG_BOARD_INTEL_PTLRVP) += intel.c
romstage-y += romstage.c romstage-$(CONFIG_CHROMEOS) += chromeos.c +romstage-$(CONFIG_BOARD_INTEL_PTLRVP) += intel.c
ramstage-y += mainboard.c ramstage-$(CONFIG_CHROMEOS) += chromeos.c ramstage-y += ec.c ramstage-$(CONFIG_SOC_INTEL_COMMON_BLOCK_HDA_VERB) += variants/$(VARIANT_DIR)/hda_verb.c +ramstage-$(CONFIG_BOARD_INTEL_PTLRVP) += intel.c
smm-$(CONFIG_HAVE_SMI_HANDLER) += smihandler.c
diff --git a/src/mainboard/intel/ptlrvp/intel.c b/src/mainboard/intel/ptlrvp/intel.c new file mode 100644 index 0000000..600d1b3 --- /dev/null +++ b/src/mainboard/intel/ptlrvp/intel.c @@ -0,0 +1,35 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ + +#include <bootmode.h> +#include <cpu/x86/smm.h> +#include <ec/google/chromeec/ec.h> +#include <elog.h> +#include <intelblocks/smihandler.h> +#include <vendorcode/google/chromeos/chromeos.h> + +void google_chromeec_events_init(const struct google_chromeec_event_info *info, + bool is_s3_wakeup) +{ + /* no-op */ +} + +int get_lid_switch(void) +{ + /* Lid always open */ + return 1; +} + +int get_recovery_mode_switch(void) +{ + return 0; +} + +bool chromeos_device_branded_plus_hard(void) +{ + return false; +} + +bool chromeos_device_branded_plus_soft(void) +{ + return false; +} diff --git a/src/mainboard/intel/ptlrvp/smihandler.c b/src/mainboard/intel/ptlrvp/smihandler.c index 9208d51..118f753 100644 --- a/src/mainboard/intel/ptlrvp/smihandler.c +++ b/src/mainboard/intel/ptlrvp/smihandler.c @@ -9,21 +9,34 @@
void mainboard_smi_sleep(u8 slp_typ) { + if (!CONFIG(EC_GOOGLE_CHROMEEC)) + return; + chromeec_smi_sleep(slp_typ, MAINBOARD_EC_S3_WAKE_EVENTS, MAINBOARD_EC_S5_WAKE_EVENTS); }
int mainboard_smi_apmc(u8 apmc) { + if (!CONFIG(EC_GOOGLE_CHROMEEC)) + return 0; + chromeec_smi_apmc(apmc, MAINBOARD_EC_SCI_EVENTS, MAINBOARD_EC_SMI_EVENTS); + return 0; }
void elog_gsmi_cb_mainboard_log_wake_source(void) { + if (!CONFIG(EC_GOOGLE_CHROMEEC)) + return; + google_chromeec_log_events(MAINBOARD_EC_LOG_EVENTS | MAINBOARD_EC_S0IX_WAKE_EVENTS); }
void mainboard_smi_espi_handler(void) { + if (!CONFIG(EC_GOOGLE_CHROMEEC)) + return; + chromeec_smi_process_events(); } diff --git a/src/mainboard/intel/ptlrvp/variants/baseboard/ptlrvp/Makefile.mk b/src/mainboard/intel/ptlrvp/variants/baseboard/ptlrvp/Makefile.mk index 47123cd..ff6ed05 100644 --- a/src/mainboard/intel/ptlrvp/variants/baseboard/ptlrvp/Makefile.mk +++ b/src/mainboard/intel/ptlrvp/variants/baseboard/ptlrvp/Makefile.mk @@ -1,4 +1,4 @@ ## SPDX-License-Identifier: GPL-2.0-only
romstage-y += memory.c -ramstage-y += ramstage.c +ramstage-$(CONFIG_EC_GOOGLE_CHROMEEC) += ramstage.c diff --git a/src/mainboard/intel/ptlrvp/variants/baseboard/ptlrvp/devicetree.cb b/src/mainboard/intel/ptlrvp/variants/baseboard/ptlrvp/devicetree.cb index 2cf249f9..c45738a 100644 --- a/src/mainboard/intel/ptlrvp/variants/baseboard/ptlrvp/devicetree.cb +++ b/src/mainboard/intel/ptlrvp/variants/baseboard/ptlrvp/devicetree.cb @@ -90,10 +90,5 @@ device ref pmc_shared_sram on end device ref heci1 on end device ref uart0 on end - device ref soc_espi on - chip ec/google/chromeec - device pnp 0c09.0 on end - end - end end end diff --git a/src/mainboard/intel/ptlrvp/variants/ptlrvp/overridetree.cb b/src/mainboard/intel/ptlrvp/variants/ptlrvp/overridetree.cb index cb4c21a..4a33387 100644 --- a/src/mainboard/intel/ptlrvp/variants/ptlrvp/overridetree.cb +++ b/src/mainboard/intel/ptlrvp/variants/ptlrvp/overridetree.cb @@ -793,11 +793,6 @@ probe AUDIO AUDIO_MAX98360_ALC5682I_I2S end end - chip drivers/i2c/tpm - register "hid" = ""GOOG0005"" - register "irq" = "ACPI_IRQ_EDGE_LOW(GPP_D15_IRQ)" - device i2c 50 on end - end end # I2C3 device ref i2c4 on chip drivers/i2c/hid diff --git a/src/mainboard/intel/ptlrvp/variants/ptlrvp_chromeec/overridetree.cb b/src/mainboard/intel/ptlrvp/variants/ptlrvp_chromeec/overridetree.cb new file mode 100644 index 0000000..d836ab5 --- /dev/null +++ b/src/mainboard/intel/ptlrvp/variants/ptlrvp_chromeec/overridetree.cb @@ -0,0 +1,895 @@ +fw_config + field AUDIO 0 3 + option AUDIO_NONE 0 + option AUDIO_MAX98373_ALC5682_SNDW 1 + option AUDIO_ALC722_SNDW 2 + option AUDIO_ALC256_HDA 3 + option AUDIO_MAX98360_ALC5682I_I2S 4 + option AUDIO_ALC721_SNDW 5 + end + field WIFI 4 5 + option WIFI_CNVI_6 0 + option WIFI_CNVI_7 1 + option WIFI_PCIE_6 2 + option WIFI_PCIE_7 3 + end + field CELLULAR 6 7 + option CELLULAR_ABSENT 0 + option CELLULAR_USB 1 + option CELLULAR_PCIE 2 + end + field TOUCHSCREEN 8 10 + option TOUCHSCREEN_NONE 0 + option TOUCHSCREEN_LPSS_I2C 1 + option TOUCHSCREEN_GSPI 2 + option TOUCHSCREEN_THC_SPI 3 + option TOUCHSCREEN_THC_I2C 4 + end + field TOUCHPAD 11 12 + option TOUCHPAD_NONE 0 + option TOUCHPAD_THC_I2C 1 + option TOUCHPAD_LPSS_I2C 2 + end + field SD 13 14 + option SD_NONE 0 + option SD_GENSYS 1 + option SD_BAYHUB 2 + end + field STORAGE 15 16 + option STORAGE_UNKNOWN 0 + option STORAGE_NVME_GEN4 1 + option STORAGE_NVME_GEN5 2 + option STORAGE_UFS 3 + end + field FP 17 + option FP_ABSENT 0 + option FP_PRESENT 1 + end + field DISPLAY 18 + option DISPLAY_ABSENT 0 + option DISPLAY_PRESENT 1 + end + field KB 19 + option KB_ABSENT 0 + option KB_PRESENT 1 + end + field UFC 20 21 + option UFC_ABSENT 0 + option UFC_MIPI 1 + option UFC_USB 2 + end + field WFC 22 23 + option WFC_ABSENT 0 + option WFC_MIPI 1 + option WFC_USB 2 + end + field ISH 24 + option ISH_DISABLE 0 + option ISH_ENABLE 1 + end +end + +chip soc/intel/pantherlake + + register "usb2_ports[0]" = "USB2_PORT_TYPE_C(OC_SKIP)" # USB2_C0 + register "usb2_ports[1]" = "USB2_PORT_TYPE_C(OC_SKIP)" # USB2_C1 + register "usb2_ports[2]" = "USB2_PORT_TYPE_C(OC_SKIP)" # USB2_C2 + register "usb2_ports[3]" = "USB2_PORT_TYPE_C(OC_SKIP)" # USB2_C3 + register "usb2_ports[4]" = "USB2_PORT_MID(OC0)" # Type-A Port A0 + register "usb2_ports[5]" = "USB2_PORT_MID(OC0)" # Type-A Port A1 / WWAN with rework + register "usb2_ports[7]" = "USB2_PORT_MID(OC_SKIP)" # CNVi BT or discrete BT + + register "usb3_ports[0]" = "USB3_PORT_DEFAULT(OC0)" # USB3.2 x1 Type-A Con #1 + register "usb3_ports[1]" = "USB3_PORT_DEFAULT(OC0)" # USB3.2 x1 Type-A Con #2 / M.2 WWAN with rework + + register "tcss_ports[0]" = "TCSS_PORT_DEFAULT(OC_SKIP)" + register "tcss_ports[1]" = "TCSS_PORT_DEFAULT(OC_SKIP)" + register "tcss_ports[2]" = "TCSS_PORT_DEFAULT(OC_SKIP)" + register "tcss_ports[3]" = "TCSS_PORT_DEFAULT(OC_SKIP)" + + register "tcss_cap_policy[0]" = "TCSS_TYPE_C_PORT_FULL_FUN" + register "tcss_cap_policy[1]" = "TCSS_TYPE_C_PORT_FULL_FUN" + register "tcss_cap_policy[2]" = "TCSS_TYPE_C_PORT_FULL_FUN" + register "tcss_cap_policy[3]" = "TCSS_TYPE_C_PORT_FULL_FUN" + + # Enable EDP in PortA + register "ddi_port_A_config" = "1" + register "ddi_ports_config" = "{ + [DDI_PORT_A] = DDI_ENABLE_HPD, + }" + + register "serial_io_i2c_mode" = "{ + [PchSerialIoIndexI2C0] = PchSerialIoPci, + [PchSerialIoIndexI2C1] = PchSerialIoPci, + [PchSerialIoIndexI2C2] = PchSerialIoPci, + [PchSerialIoIndexI2C3] = PchSerialIoPci, + [PchSerialIoIndexI2C4] = PchSerialIoPci, + [PchSerialIoIndexI2C5] = PchSerialIoPci, + }" + + register "serial_io_gspi_mode" = "{ + [PchSerialIoIndexGSPI0] = PchSerialIoPci, + [PchSerialIoIndexGSPI1] = PchSerialIoDisabled, + [PchSerialIoIndexGSPI0A] = PchSerialIoDisabled, + }" + + # Intel Common SoC Config + #+-------------------+---------------------------+ + #| Field | Value | + #+-------------------+---------------------------+ + #| I2C1 | Camera(CRD1) | + #| I2C2 | Camera(CRD2) | + #| I2C3 | Audio, TPM(cr50) | + #| I2C4 | Touchscreen | + #| I2C5 | Touchpad | + #+-------------------+---------------------------+ + register "common_soc_config" = "{ + .chipset_lockdown = CHIPSET_LOCKDOWN_COREBOOT, + .i2c[1] = { + .speed = I2C_SPEED_FAST, + }, + .i2c[2] = { + .speed = I2C_SPEED_FAST, + }, + .i2c[3] = { + .early_init = 1, + .speed = I2C_SPEED_FAST, + }, + .i2c[4] = { + .speed = I2C_SPEED_FAST, + }, + .i2c[5] = { + .speed = I2C_SPEED_FAST, + }, + }" + + device domain 0 on + device ref igpu on + probe DISPLAY DISPLAY_PRESENT + chip drivers/gfx/generic + register "device_count" = "5" + # DDIA for eDP + register "device[0].name" = ""LCD0"" + register "device[0].type" = "panel" + # DDIB for HDMI + # If HDMI is not enumerated in the kernel, then no GFX device should be added for DDIB + register "device[1].name" = ""DD01"" + # TCP0 (DP-1) for port C0 + register "device[2].name" = ""DD02"" + register "device[2].use_pld" = "true" + register "device[2].pld" = "ACPI_PLD_TYPE_C(LEFT, LEFT, ACPI_PLD_GROUP(1, 1))" + # TCP1 (DP-2) for port C1 + register "device[3].name" = ""DD03"" + register "device[3].use_pld" = "true" + register "device[3].pld" = "ACPI_PLD_TYPE_C(LEFT, RIGHT, ACPI_PLD_GROUP(2, 1))" + # TCP2 (DP-3) for port C2 + register "device[4].name" = ""DD04"" + register "device[4].use_pld" = "true" + register "device[4].pld" = "ACPI_PLD_TYPE_C(RIGHT, LEFT, ACPI_PLD_GROUP(3, 1))" + device generic 0 on end + end + end + + device ref dtt on + chip drivers/intel/dptf + ## sensor information + register "options.tsr[0].desc" = ""DDR_SOC"" + register "options.tsr[1].desc" = ""Ambient"" + register "options.tsr[2].desc" = ""Charger"" + register "options.tsr[3].desc" = ""wwan"" + + ## Active Policy + # FIXME: below values are initial reference values only + register "policies.active" = "{ + [0] = { + .target = DPTF_TEMP_SENSOR_0, + .thresholds = { + TEMP_PCT(70, 97), + TEMP_PCT(65, 90), + TEMP_PCT(60, 80), + TEMP_PCT(55, 75), + TEMP_PCT(50, 65), + TEMP_PCT(45, 45), + TEMP_PCT(43, 30), + } + }, + [1] = { + .target = DPTF_TEMP_SENSOR_1, + .thresholds = { + TEMP_PCT(70, 97), + TEMP_PCT(65, 90), + TEMP_PCT(60, 80), + TEMP_PCT(55, 75), + TEMP_PCT(50, 65), + TEMP_PCT(45, 45), + TEMP_PCT(43, 30), + } + }, + [2] = { + .target = DPTF_TEMP_SENSOR_2, + .thresholds = { + TEMP_PCT(75, 90), + TEMP_PCT(70, 80), + TEMP_PCT(65, 70), + TEMP_PCT(60, 50), + } + }, + [3] = { + .target = DPTF_TEMP_SENSOR_3, + .thresholds = { + TEMP_PCT(75, 90), + TEMP_PCT(70, 80), + TEMP_PCT(65, 70), + TEMP_PCT(60, 60), + TEMP_PCT(55, 50), + TEMP_PCT(50, 40), + TEMP_PCT(45, 30), + } + } + }" + + ## Passive Policy + # TODO: below values are initial reference values only + register "policies.passive" = "{ + [0] = DPTF_PASSIVE(CPU, CPU, 95, 5000), + [1] = DPTF_PASSIVE(CPU, TEMP_SENSOR_0, 80, 5000), + [2] = DPTF_PASSIVE(CPU, TEMP_SENSOR_1, 80, 5000), + [3] = DPTF_PASSIVE(CHARGER, TEMP_SENSOR_2, 75, 5000), + [4] = DPTF_PASSIVE(CPU, TEMP_SENSOR_3, 80, 5000), + }" + + ## Critical Policy + # TODO: below values are initial reference values only + register "policies.critical" = "{ + [0] = DPTF_CRITICAL(CPU, 105, SHUTDOWN), + [1] = DPTF_CRITICAL(TEMP_SENSOR_0, 85, SHUTDOWN), + [2] = DPTF_CRITICAL(TEMP_SENSOR_1, 85, SHUTDOWN), + [3] = DPTF_CRITICAL(TEMP_SENSOR_2, 85, SHUTDOWN), + [4] = DPTF_CRITICAL(TEMP_SENSOR_3, 85, SHUTDOWN), + }" + + ## Power Limits Control + register "controls.power_limits" = "{ + .pl1 = { + .min_power = 25000, + .max_power = 25000, + .time_window_min = 28 * MSECS_PER_SEC, + .time_window_max = 32 * MSECS_PER_SEC, + .granularity = 200, + }, + .pl2 = { + .min_power = 95000, + .max_power = 95000, + .time_window_min = 28 * MSECS_PER_SEC, + .time_window_max = 32 * MSECS_PER_SEC, + .granularity = 1000, + } + }" + + ## Charger Performance Control (Control, mA) + register "controls.charger_perf" = "{ + [0] = { 255, 3000 }, + [1] = { 24, 1500 }, + [2] = { 16, 1000 }, + [3] = { 8, 500 } + }" + + ## Fan Performance Control (Percent, Speed, Noise, Power) + register "controls.fan_perf" = "{ + [0] = { 90, 6700, 220, 2200, }, + [1] = { 80, 5800, 180, 1800, }, + [2] = { 70, 5000, 145, 1450, }, + [3] = { 60, 4900, 115, 1150, }, + [4] = { 50, 3838, 90, 900, }, + [5] = { 40, 2904, 55, 550, }, + [6] = { 30, 2337, 30, 300, }, + [7] = { 20, 1608, 15, 150, }, + [8] = { 10, 800, 10, 100, }, + [9] = { 0, 0, 0, 50, } + }" + + ## Fan options + register "options.fan.fine_grained_control" = "true" + register "options.fan.step_size" = "2" + + device generic 0 alias dptf_policy on end + end + end + + device ref ipu on + chip drivers/intel/mipi_camera + register "acpi_uid" = "0x50000" + register "acpi_name" = ""IPU0"" + register "device_type" = "INTEL_ACPI_CAMERA_CIO2" + register "cio2_num_ports" = "2" + register "cio2_lanes_used" = "{4,2}" # 4 and 2 CSI Camera lanes are used + register "cio2_lane_endpoint[0]" = ""^I2C1.CAM0"" + register "cio2_lane_endpoint[1]" = ""^I2C2.CAM1"" + register "cio2_prt[0]" = "0" + register "cio2_prt[1]" = "2" + device generic 0 on + probe UFC UFC_MIPI + probe WFC WFC_MIPI + end + end + end + + device ref iaa off end + + device ref thc0 on + probe TOUCHSCREEN TOUCHSCREEN_THC_SPI + probe TOUCHSCREEN TOUCHSCREEN_THC_I2C + # THC0 is function 0; hence it needs to be enabled when THC1 is to be enabled. + probe TOUCHPAD TOUCHPAD_THC_I2C + end + device ref thc1 on + probe TOUCHPAD TOUCHPAD_THC_I2C + end + + device ref tbt_pcie_rp0 on end + device ref tbt_pcie_rp1 on end + device ref tbt_pcie_rp2 on end + device ref tbt_pcie_rp3 on end + device ref tcss_xhci on + chip drivers/usb/acpi + device ref tcss_root_hub on + chip drivers/usb/acpi + register "desc" = ""USB3 Type-C Port C0"" + register "type" = "UPC_TYPE_C_USB2_SS_SWITCH" + register "group" = "ACPI_PLD_GROUP(4, 2)" + device ref tcss_usb3_port0 on end + end + chip drivers/usb/acpi + register "desc" = ""USB3 Type-C Port C1"" + register "type" = "UPC_TYPE_C_USB2_SS_SWITCH" + register "group" = "ACPI_PLD_GROUP(3, 2)" + device ref tcss_usb3_port1 on end + end + chip drivers/usb/acpi + register "desc" = ""USB3 Type-C Port C2"" + register "type" = "UPC_TYPE_C_USB2_SS_SWITCH" + register "group" = "ACPI_PLD_GROUP(2, 2)" + device ref tcss_usb3_port2 on end + end + chip drivers/usb/acpi + register "desc" = ""USB3 Type-C Port C3"" + register "type" = "UPC_TYPE_C_USB2_SS_SWITCH" + register "group" = "ACPI_PLD_GROUP(1, 2)" + device ref tcss_usb3_port3 on end + end + end + end + end + + device ref tcss_dma0 on + chip drivers/intel/usb4/retimer + register "dfp[0].power_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_B21)" + use tcss_usb3_port0 as dfp[0].typec_port + device generic 0 on end + end + chip drivers/intel/usb4/retimer + register "dfp[1].power_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_B21)" + use tcss_usb3_port1 as dfp[1].typec_port + device generic 0 on end + end + end + device ref tcss_dma1 on + chip drivers/intel/usb4/retimer + register "dfp[0].power_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_B21)" + use tcss_usb3_port2 as dfp[0].typec_port + device generic 0 on end + end + chip drivers/intel/usb4/retimer + register "dfp[1].power_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_B21)" + use tcss_usb3_port3 as dfp[1].typec_port + device generic 0 on end + end + end + + device ref ish on + probe ISH ISH_ENABLE + probe FP FP_PRESENT + chip drivers/intel/ish + register "add_acpi_dma_property" = "true" + device generic 0 on end + end + end + + device ref xhci on + chip drivers/usb/acpi + device ref xhci_root_hub on + chip drivers/usb/acpi + register "desc" = ""USB2 Type-C Port C0"" + register "type" = "UPC_TYPE_C_USB2_SS_SWITCH" + register "group" = "ACPI_PLD_GROUP(1, 1)" + device ref usb2_port1 on end + end + chip drivers/usb/acpi + register "desc" = ""USB2 Type-C Port C1"" + register "type" = "UPC_TYPE_C_USB2_SS_SWITCH" + register "group" = "ACPI_PLD_GROUP(2, 1)" + device ref usb2_port2 on end + end + chip drivers/usb/acpi + register "desc" = ""USB2 Type-C Port C2"" + register "type" = "UPC_TYPE_C_USB2_SS_SWITCH" + register "group" = "ACPI_PLD_GROUP(3, 1)" + device ref usb2_port3 on end + end + chip drivers/usb/acpi + register "desc" = ""USB2 Type-C Port C3"" + register "type" = "UPC_TYPE_C_USB2_SS_SWITCH" + register "group" = "ACPI_PLD_GROUP(4, 1)" + device ref usb2_port4 on end + end + chip drivers/usb/acpi + register "desc" = ""USB2 Type-A Port 1"" + register "type" = "UPC_TYPE_A" + register "group" = "ACPI_PLD_GROUP(5, 1)" + device ref usb2_port5 on end + end + chip drivers/usb/acpi + register "desc" = ""USB2 Type-A Port 2"" + register "type" = "UPC_TYPE_A" + register "group" = "ACPI_PLD_GROUP(6, 1)" + device ref usb2_port6 on end + end + chip drivers/usb/acpi + register "desc" = ""USB2 Type-A Port 3"" + register "type" = "UPC_TYPE_A" + register "group" = "ACPI_PLD_GROUP(7, 1)" + device ref usb2_port7 on end + end + chip drivers/usb/acpi + register "desc" = ""USB2 Bluetooth"" + register "type" = "UPC_TYPE_INTERNAL" + register "reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_A16)" + device ref usb2_port8 on end + end + chip drivers/usb/acpi + register "desc" = ""USB3 Type-A Port 1"" + register "type" = "UPC_TYPE_USB3_A" + register "group" = "ACPI_PLD_GROUP(1, 2)" + device ref usb3_port1 on end + end + chip drivers/usb/acpi + register "desc" = ""USB3 Type-A Port 2"" + register "type" = "UPC_TYPE_USB3_A" + register "group" = "ACPI_PLD_GROUP(2, 2)" + device ref usb3_port2 on end + end + end + end + end + + device ref ufs on + probe STORAGE STORAGE_UFS + probe STORAGE STORAGE_UNKNOWN + end + + device ref pcie_rp2 on + probe CELLULAR CELLULAR_PCIE + register "pcie_rp[PCIE_RP(2)]" = "{ + .clk_src = 5, + .clk_req = 5, + .flags = PCIE_RP_CLK_REQ_DETECT | PCIE_RP_LTR | PCIE_RP_AER, + }" + chip soc/intel/common/block/pcie/rtd3 + register "reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_D03)" + register "reset_off_delay_ms" = "20" + register "srcclk_pin" = "5" + register "ext_pm_support" = "ACPI_PCIE_RP_EMIT_ALL" + register "skip_on_off_support" = "true" + register "use_rp_mutex" = "true" + device generic 0 alias rp2_rtd3 on end + end + chip drivers/wwan/fm + register "fcpo_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_A09)" + register "reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_B20)" + register "perst_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_D03)" + register "wake_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_E02)" + register "add_acpi_dma_property" = "true" + use rp2_rtd3 as rtd3dev + device generic 0 on end + end + end # WWAN + device ref pcie_rp3 on + probe SD SD_GENSYS + probe SD SD_BAYHUB + # Enable PCH PCIE x1 slot using CLK 3 + register "pcie_rp[PCIE_RP(3)]" = "{ + .clk_src = 2, + .clk_req = 2, + .flags = PCIE_RP_CLK_REQ_DETECT | PCIE_RP_LTR | PCIE_RP_AER, + }" + chip soc/intel/common/block/pcie/rtd3 + register "enable_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_A08)" + register "enable_delay_ms" = "100" + register "reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_D19)" + register "reset_delay_ms" = "20" + register "srcclk_pin" = "2" + device generic 0 on end + end + end # PCIE x1 slot + device ref pcie_rp4 on + probe WIFI WIFI_PCIE_6 + probe WIFI WIFI_PCIE_7 + register "pcie_rp[PCH_RP(4)]" = "{ + .clk_src = 4, + .clk_req = 4, + .flags = PCIE_RP_CLK_REQ_DETECT | PCIE_RP_LTR | PCIE_RP_AER, + }" + chip soc/intel/common/block/pcie/rtd3 + register "reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_A11)" + register "srcclk_pin" = "4" + device pci 00.0 on end + end + chip drivers/wifi/generic + register "add_acpi_dma_property" = "true" + register "wake" = "GPE0_DW0_12" # GPP_A12 + use usb2_port7 as bluetooth_companion + device pci 00.0 on end + end + end # discrete WLAN + device ref pcie_rp5 on + probe STORAGE STORAGE_NVME_GEN4 + probe STORAGE STORAGE_UNKNOWN + register "pcie_rp[PCIE_RP(5)]" = "{ + .clk_src = 6, + .clk_req = 6, + .flags = PCIE_RP_CLK_REQ_DETECT | PCIE_RP_LTR | PCIE_RP_AER, + }" + chip soc/intel/common/block/pcie/rtd3 + register "is_storage" = "true" + register "enable_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_B10)" + register "reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_B09)" + register "srcclk_pin" = "6" + device generic 0 on end + end + end # Gen4 M.2 SSD + device ref pcie_rp9 on + probe STORAGE STORAGE_NVME_GEN5 + probe STORAGE STORAGE_UNKNOWN + register "pcie_rp[PCIE_RP(9)]" = "{ + .clk_src = 1, + .clk_req = 1, + .flags = PCIE_RP_CLK_REQ_DETECT | PCIE_RP_LTR | PCIE_RP_AER, + }" + chip soc/intel/common/block/pcie/rtd3 + register "is_storage" = "true" + register "enable_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_B16)" + register "reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_E03)" + register "srcclk_pin" = "1" + device generic 0 on end + end + end # Gen5 M.2 SSD + device ref cnvi_wifi on + probe WIFI WIFI_CNVI_6 + probe WIFI WIFI_CNVI_7 + chip drivers/wifi/generic + register "wake" = "GPE0_PME_B0" + register "add_acpi_dma_property" = "true" + register "enable_cnvi_ddr_rfim" = "true" + device generic 0 on end + end + end # CNVi + # NOTE: i2c0 is function 0; hence it needs to be enabled when any of i2c1-5 is enabled. + # TPM device is under i2c3. Therefore, i2c0 needs to be enabled anyways. + device ref i2c0 on end + device ref i2c1 on + chip drivers/intel/mipi_camera + register "acpi_hid" = ""OVTIDB10"" + register "acpi_uid" = "0" + register "acpi_name" = ""CAM0"" + register "chip_name" = ""Ov 13b10 Camera"" + register "device_type" = "INTEL_ACPI_CAMERA_SENSOR" + + register "ssdb.vcm_type" = "0x0C" + register "vcm_name" = ""VCM1"" + + register "ssdb.lanes_used" = "4" + register "num_freq_entries" = "1" + register "link_freq[0]" = "560 * MHz" # 560 MHz + register "remote_name" = ""IPU0"" + register "max_dstate_for_probe" = "ACPI_DEVICE_SLEEP_D3_COLD" + + register "has_power_resource" = "true" + #Controls + register "clk_panel.clks[0].clknum" = "0" # IMGCLKOUT_0 + register "clk_panel.clks[0].freq" = "1" #19.2 Mhz + register "gpio_panel.gpio[0].gpio_num" = "GPP_C05" #power_enable + register "gpio_panel.gpio[1].gpio_num" = "GPP_E10" #reset + + #_ON + register "on_seq.ops_cnt" = "4" + register "on_seq.ops[0]" = "SEQ_OPS_CLK_ENABLE(0, 0)" + register "on_seq.ops[1]" = "SEQ_OPS_GPIO_ENABLE(0, 2)" + register "on_seq.ops[2]" = "SEQ_OPS_GPIO_DISABLE(1, 1)" + register "on_seq.ops[3]" = "SEQ_OPS_GPIO_ENABLE(1, 1)" + + #_OFF + register "off_seq.ops_cnt" = "3" + register "off_seq.ops[0]" = "SEQ_OPS_CLK_DISABLE(0, 0)" + register "off_seq.ops[1]" = "SEQ_OPS_GPIO_DISABLE(1, 0)" + register "off_seq.ops[2]" = "SEQ_OPS_GPIO_DISABLE(0, 0)" + + device i2c 36 on + probe WFC WFC_MIPI + end + end + chip drivers/intel/mipi_camera + register "acpi_uid" = "3" + register "acpi_name" = ""VCM1"" + register "chip_name" = ""DW AF VCM"" + register "device_type" = "INTEL_ACPI_CAMERA_VCM" + + register "vcm_compat" = ""dongwoon,dw9714"" + + register "max_dstate_for_probe" = "ACPI_DEVICE_SLEEP_D0" + + register "has_power_resource" = "true" + + #Controls + register "gpio_panel.gpio[0].gpio_num" = "GPP_C05" #power_enable + + #_ON + register "on_seq.ops_cnt" = "1" + register "on_seq.ops[0]" = "SEQ_OPS_GPIO_ENABLE(0, 0)" + + #_OFF + register "off_seq.ops_cnt" = "1" + register "off_seq.ops[0]" = "SEQ_OPS_GPIO_DISABLE(0, 0)" + + device i2c 0C on + probe WFC WFC_MIPI + end + end + chip drivers/intel/mipi_camera + register "acpi_uid" = "1" + register "acpi_name" = ""NVM1"" + register "chip_name" = ""BRCA016GWZ"" + register "device_type" = "INTEL_ACPI_CAMERA_NVM" + + register "nvm_compat" = ""atmel,24c16"" + + register "nvm_size" = "0x800" + register "nvm_pagesize" = "0x01" + register "nvm_readonly" = "0x01" + register "nvm_width" = "0x08" + + register "max_dstate_for_probe" = "ACPI_DEVICE_SLEEP_D0" + + register "has_power_resource" = "true" + + #Controls + register "gpio_panel.gpio[0].gpio_num" = "GPP_C05" #power_enable + + #_ON + register "on_seq.ops_cnt" = "1" + register "on_seq.ops[0]" = "SEQ_OPS_GPIO_ENABLE(0, 0)" + + #_OFF + register "off_seq.ops_cnt" = "1" + register "off_seq.ops[0]" = "SEQ_OPS_GPIO_DISABLE(0, 0)" + + device i2c 50 on + probe WFC WFC_MIPI + end + end + end # I2C1 + device ref i2c2 on + chip drivers/intel/mipi_camera + register "acpi_hid" = ""OVTIDB10"" + register "acpi_uid" = "0" + register "acpi_name" = ""CAM1"" + register "chip_name" = ""Ov 13b10 Camera"" + register "device_type" = "INTEL_ACPI_CAMERA_SENSOR" + + register "ssdb.vcm_type" = "0x0C" + register "vcm_name" = ""VCM1"" + + register "ssdb.lanes_used" = "2" + register "num_freq_entries" = "1" + register "link_freq[0]" = "560 * MHz" # 560 MHz + register "remote_name" = ""IPU0"" + register "max_dstate_for_probe" = "ACPI_DEVICE_SLEEP_D3_COLD" + + register "has_power_resource" = "true" + #Controls + register "clk_panel.clks[0].clknum" = "1" # IMGCLKOUT_1 + register "clk_panel.clks[0].freq" = "1" #19.2 Mhz + register "gpio_panel.gpio[0].gpio_num" = "GPP_C08" #power_enable + register "gpio_panel.gpio[1].gpio_num" = "GPP_E01" #reset + + #_ON + register "on_seq.ops_cnt" = "4" + register "on_seq.ops[0]" = "SEQ_OPS_CLK_ENABLE(0, 0)" + register "on_seq.ops[1]" = "SEQ_OPS_GPIO_ENABLE(0, 2)" + register "on_seq.ops[2]" = "SEQ_OPS_GPIO_DISABLE(1, 1)" + register "on_seq.ops[3]" = "SEQ_OPS_GPIO_ENABLE(1, 1)" + + #_OFF + register "off_seq.ops_cnt" = "3" + register "off_seq.ops[0]" = "SEQ_OPS_CLK_DISABLE(0, 0)" + register "off_seq.ops[1]" = "SEQ_OPS_GPIO_DISABLE(1, 0)" + register "off_seq.ops[2]" = "SEQ_OPS_GPIO_DISABLE(0, 0)" + + device i2c 36 on + probe UFC UFC_MIPI + end + end + chip drivers/intel/mipi_camera + register "acpi_uid" = "3" + register "acpi_name" = ""VCM1"" + register "chip_name" = ""DW AF VCM"" + register "device_type" = "INTEL_ACPI_CAMERA_VCM" + + register "vcm_compat" = ""dongwoon,dw9714"" + + register "max_dstate_for_probe" = "ACPI_DEVICE_SLEEP_D0" + + register "has_power_resource" = "true" + + #Controls + register "gpio_panel.gpio[0].gpio_num" = "GPP_C08" #power_enable + + #_ON + register "on_seq.ops_cnt" = "1" + register "on_seq.ops[0]" = "SEQ_OPS_GPIO_ENABLE(0, 0)" + + #_OFF + register "off_seq.ops_cnt" = "1" + register "off_seq.ops[0]" = "SEQ_OPS_GPIO_DISABLE(0, 0)" + + device i2c 0C on + probe UFC UFC_MIPI + end + end + chip drivers/intel/mipi_camera + register "acpi_uid" = "1" + register "acpi_name" = ""NVM1"" + register "chip_name" = ""BRCA016GWZ"" + register "device_type" = "INTEL_ACPI_CAMERA_NVM" + + register "nvm_compat" = ""atmel,24c16"" + + register "nvm_size" = "0x800" + register "nvm_pagesize" = "0x01" + register "nvm_readonly" = "0x01" + register "nvm_width" = "0x08" + + register "max_dstate_for_probe" = "ACPI_DEVICE_SLEEP_D0" + + register "has_power_resource" = "true" + + #Controls + register "gpio_panel.gpio[0].gpio_num" = "GPP_C08" #power_enable + + #_ON + register "on_seq.ops_cnt" = "1" + register "on_seq.ops[0]" = "SEQ_OPS_GPIO_ENABLE(0, 0)" + + #_OFF + register "off_seq.ops_cnt" = "1" + register "off_seq.ops[0]" = "SEQ_OPS_GPIO_DISABLE(0, 0)" + + device i2c 50 on + probe UFC UFC_MIPI + end + end + end # I2C2 + device ref i2c3 on + chip drivers/i2c/generic + register "hid" = ""RTL5682"" + register "name" = ""RT58"" + register "desc" = ""Headset Codec"" + register "irq_gpio" = "ACPI_GPIO_IRQ_EDGE_BOTH(GPP_F17)" + # Set the jd_src to RT5668_JD1 for jack detection + register "property_count" = "1" + register "property_list[0].type" = "ACPI_DP_TYPE_INTEGER" + register "property_list[0].name" = ""realtek,jd-src"" + register "property_list[0].integer" = "1" + device i2c 1a on + probe AUDIO AUDIO_MAX98360_ALC5682I_I2S + end + end + chip drivers/i2c/tpm + register "hid" = ""GOOG0005"" + register "irq" = "ACPI_IRQ_EDGE_LOW(GPP_D15_IRQ)" + device i2c 50 on end + end + end # I2C3 + device ref i2c4 on + chip drivers/i2c/hid + register "generic.hid" = ""ELAN6918"" + register "generic.desc" = ""ELAN Touchscreen"" + register "generic.irq" = "ACPI_IRQ_LEVEL_LOW(GPP_E18_IRQ)" + register "generic.probed" = "1" + register "generic.reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_E16)" + register "generic.reset_delay_ms" = "20" + register "generic.reset_off_delay_ms" = "2" + register "generic.enable_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_F08)" + register "generic.enable_delay_ms" = "1" + register "generic.has_power_resource" = "1" + register "hid_desc_reg_offset" = "0x01" + device i2c 16 on + probe TOUCHSCREEN TOUCHSCREEN_LPSS_I2C + end + end + end # I2C4 + device ref i2c5 on + chip drivers/i2c/hid + register "generic.hid" = ""HFW68H"" + register "generic.desc" = ""Hynitron TOUCHPAD"" + register "generic.irq" = "ACPI_IRQ_WAKE_LEVEL_LOW(GPP_A13_IRQ)" + register "generic.wake" = "GPE0_DW0_13" + register "generic.uid" = "5" + register "generic.detect" = "1" + register "hid_desc_reg_offset" = "0x20" + device i2c 2c on + probe TOUCHPAD TOUCHPAD_LPSS_I2C + end + end + end # I2C5 + + device ref gspi0 on + chip drivers/spi/acpi + register "name" = ""CRFP"" + register "hid" = "ACPI_DT_NAMESPACE_HID" + register "uid" = "1" + register "compat_string" = ""google,cros-ec-spi"" + register "irq" = "ACPI_IRQ_WAKE_LEVEL_LOW(GPP_D01_IRQ)" + register "wake" = "GPE0_DW1_01" + register "has_power_resource" = "true" + register "reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_C15)" + register "enable_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_E19)" + register "enable_delay_ms" = "3" + device spi 0 on + probe FP FP_PRESENT + end + end # FPMCU + end + + device ref smbus on end + device ref npk on end + device ref hda on + chip drivers/intel/soundwire + device generic 0 on + chip drivers/soundwire/alc711 + register "desc" = ""Headset Codec"" + register "alc711_address.version" = "SOUNDWIRE_VERSION_1_2" + register "alc711_address.class" = "MIPI_CLASS_SDCA" + register "alc711_address.part_id" = "MIPI_DEV_ID_REALTEK_ALC722" + # SoundWire Link 1 ID 1 + device generic 1.1 on + probe AUDIO AUDIO_ALC722_SNDW + end + end + chip drivers/soundwire/alc711 + register "desc" = ""Headset Codec"" + register "alc711_address.version" = "SOUNDWIRE_VERSION_1_2" + register "alc711_address.class" = "MIPI_CLASS_SDCA" + register "alc711_address.part_id" = "MIPI_DEV_ID_REALTEK_ALC721" + # SoundWire Link 3 ID 1 + device generic 3.1 on + probe AUDIO AUDIO_ALC721_SNDW + end + end + end + end + chip drivers/generic/max98357a + register "hid" = ""MX98360A"" + register "sdmode_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_E19)" + register "sdmode_delay" = "5" + device generic 0 on + probe AUDIO AUDIO_MAX98360_ALC5682I_I2S + end + end + end + device ref soc_espi on + chip ec/google/chromeec + device pnp 0c09.0 on end + end + end + end +end
