Timothy Pearson (tpearson@raptorengineeringinc.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/13523
commit cc7a37ad68da58a959778933c69efaaa44be88ba Author: Timothy Pearson tpearson@raptorengineeringinc.com Date: Tue Nov 24 14:17:49 2015 -0600
mainboard/asus/kcma-d8: Add initial ASUS KCMA-D8 support
Change-Id: Idefa304a27823c741fab72ff5c2f20fed1aa5a39 Signed-off-by: Timothy Pearson tpearson@raptorengineeringinc.com --- src/mainboard/asus/kcma-d8/cmos.default | 1 - src/mainboard/asus/kcma-d8/cmos.layout | 1 - src/mainboard/asus/kcma-d8/devicetree.cb | 40 +++++--------- src/mainboard/asus/kcma-d8/dsdt.asl | 92 +++++++++----------------------- src/mainboard/asus/kcma-d8/mptable.c | 34 ++++++------ src/mainboard/asus/kcma-d8/resourcemap.c | 8 +-- src/mainboard/asus/kcma-d8/romstage.c | 62 ++++++--------------- 7 files changed, 77 insertions(+), 161 deletions(-)
diff --git a/src/mainboard/asus/kcma-d8/cmos.default b/src/mainboard/asus/kcma-d8/cmos.default index 0e7afb3..c8edd97 100644 --- a/src/mainboard/asus/kcma-d8/cmos.default +++ b/src/mainboard/asus/kcma-d8/cmos.default @@ -23,7 +23,6 @@ sata_alpm = Disable maximum_p_state_limit = 0xf probe_filter = Auto l3_cache_partitioning = Disable -ieee1394_controller = Enable gart = Enable experimental_memory_speed_boost = Disable power_on_after_fail = On diff --git a/src/mainboard/asus/kcma-d8/cmos.layout b/src/mainboard/asus/kcma-d8/cmos.layout index 075388e..9bda1f6 100644 --- a/src/mainboard/asus/kcma-d8/cmos.layout +++ b/src/mainboard/asus/kcma-d8/cmos.layout @@ -46,7 +46,6 @@ entries 473 2 e 13 dimm_spd_checksum 475 1 e 14 probe_filter 476 1 e 1 l3_cache_partitioning -477 1 e 1 ieee1394_controller 478 1 e 1 iommu 479 1 e 1 cpu_core_boost 480 1 e 1 experimental_memory_speed_boost diff --git a/src/mainboard/asus/kcma-d8/devicetree.cb b/src/mainboard/asus/kcma-d8/devicetree.cb index 4bf1603..9eb38c7 100644 --- a/src/mainboard/asus/kcma-d8/devicetree.cb +++ b/src/mainboard/asus/kcma-d8/devicetree.cb @@ -7,11 +7,10 @@ chip northbridge/amd/amdfam10/root_complex # Root complex device domain 0 on # PCI domain subsystemid 0x1043 0x8163 inherit chip northbridge/amd/amdfam10 # Northbridge / RAM controller - register "maximum_memory_capacity" = "0x4000000000" # 256GB + register "maximum_memory_capacity" = "0x2000000000" # 128GB device pci 18.0 on end # Link 0 == LDT 0 device pci 18.0 on end # Link 1 == LDT 1 - device pci 18.0 on end # Link 2 == LDT 2 - device pci 18.0 on # Link 3 == LDT 3 [SB on link 3] + device pci 18.0 on # Link 2 == LDT 2 [SB on link 2] chip southbridge/amd/sr5650 # Primary southbridge device pci 0.0 on end # HT Root Complex 0x9600 device pci 0.1 on end # CLKCONFIG @@ -36,16 +35,10 @@ chip northbridge/amd/amdfam10/root_complex # Root complex device pci b.0 on # Bridge (GPP2 Port0) # Slot # PCI E 4 end - device pci c.0 on # Bridge (GPP2 Port1) - # Slot # PCI E 5 - end - device pci d.0 on # Bridge (GPP3b Port0) - # Slot # PCI E 3 - end register "gpp1_configuration" = "0" # Configuration 16:0 default register "gpp2_configuration" = "1" # Configuration 8:8 register "gpp3a_configuration" = "2" # Configuration 4:1:1:0:0:0 - register "port_enable" = "0x3f1c" # Enable all ports except 0, 1, 5, 6, and 7 + register "port_enable" = "0x0f1c" # Enable all ports except 0, 1, 5, 6, and 7 register "pcie_settling_time" = "1000000" # Allow PIKE to be detected / configured end chip southbridge/amd/sb700 # Secondary southbridge @@ -150,7 +143,7 @@ chip northbridge/amd/amdfam10/root_complex # Root complex register "vsen5_low_limit_mv" = "1150" # VSEN5 (Node 0 HT link voltage) low limit to 1.15V register "vsen6_high_limit_mv" = "1250" # VSEN6 (Node 1 HT link voltage) high limit to 1.25V register "vsen6_low_limit_mv" = "1150" # VSEN6 (Node 1 HT link voltage) low limit to 1.15V - register "vsen7_high_limit_mv" = "1250" # VSEN7 (Northbridge core voltage) high limit to 1.25V + register "vsen7_high_limit_mv" = "1150" # VSEN7 (Northbridge core voltage) high limit to 1.15V register "vsen7_low_limit_mv" = "1050" # VSEN7 (Northbridge core voltage) low limit to 1.05V register "vsen8_high_limit_mv" = "1900" # VSEN8 (+1.8V) high limit to 1.9V register "vsen8_low_limit_mv" = "1700" # VSEN8 (+1.8V) low limit to 1.7V @@ -216,11 +209,16 @@ chip northbridge/amd/amdfam10/root_complex # Root complex end end device pci 14.4 on # Bridge - device pci 1.0 on end # VGA - device pci 2.0 on end # FireWire - device pci 3.0 on # Slot + device pci 1.0 on # Slot # Slot # PCI 0 end + device pci 2.0 on # Slot + # Slot # PCI 1 + end + device pci 3.0 on # Slot + # Slot # PCI 2 + end + device pci 5.0 on end # VGA end device pci 14.5 on end # USB OHCI2 0x4399 end @@ -230,24 +228,12 @@ chip northbridge/amd/amdfam10/root_complex # Root complex device pci 18.3 on end device pci 18.4 on end device pci 18.5 on end - device pci 19.0 on end # Socket 0 node 1 + device pci 19.0 on end # Socket 1 node 0 device pci 19.1 on end device pci 19.2 on end device pci 19.3 on end device pci 19.4 on end device pci 19.5 on end - device pci 1a.0 on end # Socket 1 node 0 - device pci 1a.1 on end - device pci 1a.2 on end - device pci 1a.3 on end - device pci 1a.4 on end - device pci 1a.5 on end - device pci 1b.0 on end # Socket 1 node 1 - device pci 1b.1 on end - device pci 1b.2 on end - device pci 1b.3 on end - device pci 1b.4 on end - device pci 1b.5 on end end end end diff --git a/src/mainboard/asus/kcma-d8/dsdt.asl b/src/mainboard/asus/kcma-d8/dsdt.asl index 5f9195a..ef87d31 100644 --- a/src/mainboard/asus/kcma-d8/dsdt.asl +++ b/src/mainboard/asus/kcma-d8/dsdt.asl @@ -1,7 +1,7 @@ /* * This file is part of the coreboot project. * - * Copyright (C) 2015 Timothy Pearson tpearson@raptorengineeringinc.com, Raptor Engineering + * Copyright (C) 2015 Raptor Engineering * Copyright (C) 2005 - 2012 Advanced Micro Devices, Inc. * Copyright (C) 2007-2009 coresystems GmbH * Copyright (C) 2004 Nick Barker Nick.Barker9@btinternet.com @@ -116,8 +116,6 @@ DefinitionBlock ( Notify (_SB.PCI0.NICA, 0x02) /* NOTIFY_DEVICE_WAKE */ Notify (_SB.PCI0.NICB, 0x02) /* NOTIFY_DEVICE_WAKE */ Notify (_SB.PCI0.PCE4, 0x02) /* NOTIFY_DEVICE_WAKE */ - Notify (_SB.PCI0.PCE5, 0x02) /* NOTIFY_DEVICE_WAKE */ - Notify (_SB.PCI0.PCE3, 0x02) /* NOTIFY_DEVICE_WAKE */ }
} /* End Scope GPE */ @@ -125,13 +123,13 @@ DefinitionBlock ( /* Root of the bus hierarchy */ Scope (_SB) { - /* Top southbridge PCI device (SR5690 + SP5100) */ + /* Top southbridge PCI device (SR5670 + SP5100) */ Device (PCI0) { /* BUS0 root bus */
- Name (_HID, EisaId ("PNP0A08")) /* PCI-e root bus (SR5690) */ - Name (_CID, EisaId ("PNP0A03")) /* PCI root bus (SP5100) */ + Name (_HID, EisaId ("PNP0A08")) /* PCI-e root bus (SR5670) */ + Name (_CID, EisaId ("PNP0A03")) /* PCI root bus (SP5100) */ Name (_ADR, 0x00180001) Name (_UID, 0x00)
@@ -162,7 +160,7 @@ DefinitionBlock ( /* PCI Routing Tables */ Name (PR00, Package () { /* PIC */ - /* Top southbridge device (SR5690) */ + /* Top southbridge device (SR5670) */ /* HT Link */ Package (0x04) { 0x0000FFFF, 0x00, LNKA, 0x00 },
@@ -178,12 +176,6 @@ DefinitionBlock ( /* PCI-E Slot 4 (Bridge) */ Package (0x04) { 0x000BFFFF, 0x00, LNKG, 0x00 },
- /* PCI-E Slot 5 (Bridge) */ - Package (0x04) { 0x000CFFFF, 0x00, LNKG, 0x00 }, - - /* PCI-E Slot 3 (Bridge) */ - Package (0x04) { 0x000DFFFF, 0x00, LNKG, 0x00 }, - /* Bottom southbridge device (SP5100) */ /* SATA 0 */ Package (0x04) { 0x0011FFFF, 0x00, LNKG, 0x00 }, @@ -200,7 +192,7 @@ DefinitionBlock ( Package (0x04) { 0x0013FFFF, 0x02, LNKA, 0x00 }, Package (0x04) { 0x0013FFFF, 0x03, LNKB, 0x00 },
- /* SMBUS / IDE / LPC / VGA / FireWire / PCI Slot 0 */ + /* SMBUS / IDE / LPC / VGA / PCI Slots 0 - 2 */ Package (0x04) { 0x0014FFFF, 0x00, LNKA, 0x00 }, Package (0x04) { 0x0014FFFF, 0x01, LNKB, 0x00 }, Package (0x04) { 0x0014FFFF, 0x02, LNKC, 0x00 }, @@ -209,7 +201,7 @@ DefinitionBlock (
Name (AR00, Package () { /* APIC */ - /* Top southbridge device (SR5690) */ + /* Top southbridge device (SR5670) */ /* HT Link */ Package (0x04) { 0x0000FFFF, 0x00, 0x00, 55 },
@@ -225,12 +217,6 @@ DefinitionBlock ( /* PCI-E Slot 4 (Bridge) */ Package (0x04) { 0x000BFFFF, 0x00, 0x00, 54 },
- /* PCI-E Slot 5 (Bridge) */ - Package (0x04) { 0x000CFFFF, 0x00, 0x00, 54 }, - - /* PCI-E Slot 3 (Bridge) */ - Package (0x04) { 0x000DFFFF, 0x00, 0x00, 54 }, - /* Bottom southbridge device (SP5100) */ /* SATA 0 */ Package (0x04) { 0x0011FFFF, 0x00, 0x00, 22 }, @@ -247,7 +233,7 @@ DefinitionBlock ( Package (0x04) { 0x0013FFFF, 0x02, 0x00, 16 }, Package (0x04) { 0x0013FFFF, 0x03, 0x00, 17 },
- /* SMBUS / IDE / LPC / VGA / FireWire / PCI Slot 0 */ + /* SMBUS / IDE / LPC / VGA / PCI Slots 0 - 2 */ Package (0x04) { 0x0014FFFF, 0x00, 0x00, 16 }, Package (0x04) { 0x0014FFFF, 0x01, 0x00, 17 }, Package (0x04) { 0x0014FFFF, 0x02, 0x00, 18 }, @@ -256,22 +242,36 @@ DefinitionBlock (
Name (PR01, Package () { /* PIC */ - Package (0x04) { 0x1FFFF, 0x00, LNKF, 0x00 }, - Package (0x04) { 0x2FFFF, 0x00, LNKE, 0x00 }, + Package (0x04) { 0x1FFFF, 0x00, LNKE, 0x00 }, + Package (0x04) { 0x1FFFF, 0x01, LNKF, 0x00 }, + Package (0x04) { 0x1FFFF, 0x02, LNKG, 0x00 }, + Package (0x04) { 0x1FFFF, 0x03, LNKH, 0x00 }, + Package (0x04) { 0x2FFFF, 0x00, LNKF, 0x00 }, + Package (0x04) { 0x2FFFF, 0x01, LNKG, 0x00 }, + Package (0x04) { 0x2FFFF, 0x02, LNKH, 0x00 }, + Package (0x04) { 0x2FFFF, 0x03, LNKE, 0x00 }, Package (0x04) { 0x3FFFF, 0x00, LNKG, 0x00 }, Package (0x04) { 0x3FFFF, 0x01, LNKH, 0x00 }, Package (0x04) { 0x3FFFF, 0x02, LNKE, 0x00 }, Package (0x04) { 0x3FFFF, 0x03, LNKF, 0x00 }, + Package (0x04) { 0x5FFFF, 0x00, LNKH, 0x00 }, })
Name (AR01, Package () { /* APIC */ - Package (0x04) { 0x1FFFF, 0x00, 0x00, 21 }, - Package (0x04) { 0x2FFFF, 0x00, 0x00, 20 }, + Package (0x04) { 0x1FFFF, 0x00, 0x00, 20 }, + Package (0x04) { 0x1FFFF, 0x01, 0x00, 21 }, + Package (0x04) { 0x1FFFF, 0x02, 0x00, 22 }, + Package (0x04) { 0x1FFFF, 0x03, 0x00, 23 }, + Package (0x04) { 0x2FFFF, 0x00, 0x00, 21 }, + Package (0x04) { 0x2FFFF, 0x01, 0x00, 22 }, + Package (0x04) { 0x2FFFF, 0x02, 0x00, 23 }, + Package (0x04) { 0x2FFFF, 0x03, 0x00, 20 }, Package (0x04) { 0x3FFFF, 0x00, 0x00, 22 }, Package (0x04) { 0x3FFFF, 0x01, 0x00, 23 }, Package (0x04) { 0x3FFFF, 0x02, 0x00, 20 }, Package (0x04) { 0x3FFFF, 0x03, 0x00, 21 }, + Package (0x04) { 0x5FFFF, 0x00, 0x00, 23 }, })
Name (PR02, Package () { @@ -734,46 +734,6 @@ DefinitionBlock ( Name(_PRW, Package () {0x0B, 0x04}) // Wake from S1-S4 } } - - /* 6:00.0 PCIe x16 */ - Device (PCE5) - { - Name (_ADR, 0x000C0000) // _ADR: Address - Name(_PRW, Package () {0x11, 0x04}) // Wake from S1-S4 - Method (_PRT, 0, NotSerialized) // _PRT: PCI Routing Table - { - If (PICM) { - Return (AR07) - } Else { - Return (PR07) - } - } - Device (SLT1) - { - Name (_ADR, 0xFFFF) // _ADR: Address - Name(_PRW, Package () {0x0B, 0x04}) // Wake from S1-S4 - } - } - - /* 7:00.0 PCIe x16 */ - Device (PCE3) - { - Name (_ADR, 0x000D0000) // _ADR: Address - Name(_PRW, Package () {0x11, 0x04}) // Wake from S1-S4 - Method (_PRT, 0, NotSerialized) // _PRT: PCI Routing Table - { - If (PICM) { - Return (AR08) - } Else { - Return (PR08) - } - } - Device (SLT1) - { - Name (_ADR, 0xFFFF) // _ADR: Address - Name(_PRW, Package () {0x0B, 0x04}) // Wake from S1-S4 - } - } }
Device (PWRB) { /* Start Power button device */ diff --git a/src/mainboard/asus/kcma-d8/mptable.c b/src/mainboard/asus/kcma-d8/mptable.c index c869d31..8967560 100644 --- a/src/mainboard/asus/kcma-d8/mptable.c +++ b/src/mainboard/asus/kcma-d8/mptable.c @@ -132,7 +132,6 @@ static void *smp_write_config_table(void *v) smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, 0, (((10)<<2)|(0)), apicid_sr5650, 30); /* Device 10 (LNKG, APIC pin 30) */ smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, 0, (((11)<<2)|(0)), apicid_sr5650, 30); /* Device 11 (LNKG, APIC pin 30) */ smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, 0, (((12)<<2)|(0)), apicid_sr5650, 30); /* Device 12 (LNKG, APIC pin 30) */ - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, 0, (((13)<<2)|(0)), apicid_sr5650, 30); /* Device 13 (LNKG, APIC pin 30)) */
dev = dev_find_slot(0, PCI_DEVFN(0x2, 0)); if (dev && dev->enabled) { @@ -164,11 +163,6 @@ static void *smp_write_config_table(void *v) uint8_t bus_pci = dev->link_list->secondary; smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_pci, (((0)<<0xc)|(0)), apicid_sr5650, 0); /* card behind dev12 */ } - dev = dev_find_slot(0, PCI_DEVFN(0xd, 0)); - if (dev && dev->enabled) { - uint8_t bus_pci = dev->link_list->secondary; - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_pci, (((0)<<0xd)|(0)), apicid_sr5650, 0); /* card behind dev13 */ - }
/* PCI interrupts are level triggered, and are * associated with a specific bus/device/function tuple. @@ -195,23 +189,29 @@ static void *smp_write_config_table(void *v) if (dev && dev->enabled) { u8 bus_pci = dev->link_list->secondary;
- /* PCI_SLOT 0. */ - PCI_INT(bus_pci, 0x1, 0x0, 0x15); - PCI_INT(bus_pci, 0x1, 0x1, 0x16); - PCI_INT(bus_pci, 0x1, 0x2, 0x17); - PCI_INT(bus_pci, 0x1, 0x3, 0x14); + /* PCI_SLOT 0 */ + PCI_INT(bus_pci, 0x1, 0x0, 0x14); + PCI_INT(bus_pci, 0x1, 0x1, 0x15); + PCI_INT(bus_pci, 0x1, 0x2, 0x16); + PCI_INT(bus_pci, 0x1, 0x3, 0x17);
- /* PCI_SLOT 1. */ - PCI_INT(bus_pci, 0x2, 0x0, 0x14); - PCI_INT(bus_pci, 0x2, 0x1, 0x15); - PCI_INT(bus_pci, 0x2, 0x2, 0x16); - PCI_INT(bus_pci, 0x2, 0x3, 0x17); + /* PCI_SLOT 1 */ + PCI_INT(bus_pci, 0x2, 0x0, 0x15); + PCI_INT(bus_pci, 0x2, 0x1, 0x16); + PCI_INT(bus_pci, 0x2, 0x2, 0x17); + PCI_INT(bus_pci, 0x2, 0x3, 0x14);
- /* PCI_SLOT 2. */ + /* PCI_SLOT 2 */ PCI_INT(bus_pci, 0x3, 0x0, 0x16); PCI_INT(bus_pci, 0x3, 0x1, 0x17); PCI_INT(bus_pci, 0x3, 0x2, 0x14); PCI_INT(bus_pci, 0x3, 0x3, 0x15); + + /* VGA */ + PCI_INT(bus_pci, 0x5, 0x0, 0x17); + PCI_INT(bus_pci, 0x5, 0x1, 0x14); + PCI_INT(bus_pci, 0x5, 0x2, 0x15); + PCI_INT(bus_pci, 0x5, 0x3, 0x16); }
/*Local Ints: Type Polarity Trigger Bus ID IRQ APIC ID PIN# */ diff --git a/src/mainboard/asus/kcma-d8/resourcemap.c b/src/mainboard/asus/kcma-d8/resourcemap.c index 8bcb28b..f7a2133 100644 --- a/src/mainboard/asus/kcma-d8/resourcemap.c +++ b/src/mainboard/asus/kcma-d8/resourcemap.c @@ -196,7 +196,7 @@ static void setup_mb_resource_map(void) * This field defines the end of PCI I/O region n * [31:25] Reserved */ - PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xC4), 0xFE000FC8, 0x00fff010, /* link 1 of cpu 0 --> AMD SR5690 */ + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xC4), 0xFE000FC8, 0x00fff020, /* link 2 of cpu 0 --> AMD SR5690 */ PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xCC), 0xFE000FC8, 0x00000000, PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xD4), 0xFE000FC8, 0x00000000, PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xDC), 0xFE000FC8, 0x00000000, @@ -267,7 +267,7 @@ static void setup_mb_resource_map(void) * [31:24] Bus Number Limit i * This field defines the highest bus number in configuration region i */ - PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xE0), 0x0000FC88, 0x05000103, /* link 1 of cpu 0 --> AMD SR5690 */ + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xE0), 0x0000FC88, 0x05000203, /* link 2 of cpu 0 --> AMD SR5690 */ PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xE4), 0x0000FC88, 0x00000000, PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xE8), 0x0000FC88, 0x00000000, PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xEC), 0x0000FC88, 0x00000000, @@ -451,7 +451,7 @@ static void setup_mb_resource_map(void) * This field defines the end of PCI I/O region n * [31:25] Reserved */ - PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xC4), 0xFE000FC8, 0x00fff110, /* link 3 of cpu 0 --> AMD SR5690 */ + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xC4), 0xFE000FC8, 0x00fff020, /* link 2 of cpu 0 --> AMD SR5690 */ PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xCC), 0xFE000FC8, 0x00000000, PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xD4), 0xFE000FC8, 0x00000000, PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xDC), 0xFE000FC8, 0x00000000, @@ -522,7 +522,7 @@ static void setup_mb_resource_map(void) * [31:24] Bus Number Limit i * This field defines the highest bus number in configuration region i */ - PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xE0), 0x0000FC88, 0x05000303, /* link 3 of cpu 0 --> AMD SR5690 */ + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xE0), 0x0000FC88, 0x05000203, /* link 2 of cpu 0 --> AMD SR5690 */ PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xE4), 0x0000FC88, 0x00000000, PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xE8), 0x0000FC88, 0x00000000, PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xEC), 0x0000FC88, 0x00000000, diff --git a/src/mainboard/asus/kcma-d8/romstage.c b/src/mainboard/asus/kcma-d8/romstage.c index 4210a92..4552b1c 100644 --- a/src/mainboard/asus/kcma-d8/romstage.c +++ b/src/mainboard/asus/kcma-d8/romstage.c @@ -96,28 +96,26 @@ static void switch_spd_mux(uint8_t channel) static const uint8_t spd_addr_fam15[] = { // Socket 0 Node 0 ("Node 0") RC00, DIMM0, DIMM1, 0, 0, DIMM2, DIMM3, 0, 0, - // Socket 0 Node 1 ("Node 1") - RC00, DIMM4, DIMM5, 0, 0, DIMM6, DIMM7, 0, 0, - // Socket 1 Node 0 ("Node 2") + // Socket 1 Node 0 ("Node 1") RC01, DIMM0, DIMM1, 0, 0, DIMM2, DIMM3, 0, 0, - // Socket 1 Node 1 ("Node 3") - RC01, DIMM4, DIMM5, 0, 0, DIMM6, DIMM7, 0, 0, };
static const uint8_t spd_addr_fam10[] = { // Socket 0 Node 0 ("Node 0") RC00, DIMM0, DIMM1, 0, 0, DIMM2, DIMM3, 0, 0, - // Socket 0 Node 1 ("Node 1") - RC00, DIMM4, DIMM5, 0, 0, DIMM6, DIMM7, 0, 0, - // Socket 1 Node 1 ("Node 2") - RC01, DIMM4, DIMM5, 0, 0, DIMM6, DIMM7, 0, 0, - // Socket 1 Node 0 ("Node 3") + // Socket 1 Node 0 ("Node 1") RC01, DIMM0, DIMM1, 0, 0, DIMM2, DIMM3, 0, 0, };
static void activate_spd_rom(const struct mem_controller *ctrl) { - /* Nothing needs to be done as there is no SPD mux on this board */ printk(BIOS_DEBUG, "activate_spd_rom() for node %02x\n", ctrl->node_id); + if (ctrl->node_id == 0) { + printk(BIOS_DEBUG, "enable_spd_node0()\n"); + switch_spd_mux(0x2); + } else if (ctrl->node_id == 1) { + printk(BIOS_DEBUG, "enable_spd_node1()\n"); + switch_spd_mux(0x3); + } }
/* Voltages are specified by index @@ -189,13 +187,12 @@ void DIMMSetVoltages(struct MCTStatStruc *pMCTstat, }
for (node = 0; node < MAX_NODES_SUPPORTED; node++) { - socket = node / 2; + socket = node; struct DCTStatStruc *pDCTstat; pDCTstat = pDCTstatA + node;
/* reset socket_allowed_voltages before processing each socket */ - if (!(node % 2)) - socket_allowed_voltages = allowed_voltages; + socket_allowed_voltages = allowed_voltages;
if (pDCTstat->NodePresent) { for (dimm = 0; dimm < MAX_DIMMS_SUPPORTED; dimm++) { @@ -203,10 +200,7 @@ void DIMMSetVoltages(struct MCTStatStruc *pMCTstat, socket_allowed_voltages &= pDCTstat->DimmSupportedVoltages[dimm]; } } - }
- /* set voltage per socket after processing last contained node */ - if (pDCTstat->NodePresent && (node % 2)) { /* Set voltages */ if (socket_allowed_voltages & 0x8) { set_voltage = 0x8; @@ -223,16 +217,8 @@ void DIMMSetVoltages(struct MCTStatStruc *pMCTstat, }
/* Save final DIMM voltages for MCT and SMBIOS use */ - if (pDCTstat->NodePresent) { - for (dimm = 0; dimm < MAX_DIMMS_SUPPORTED; dimm++) { - pDCTstat->DimmConfiguredVoltage[dimm] = set_voltage; - } - } - pDCTstat = pDCTstatA + (node - 1); - if (pDCTstat->NodePresent) { - for (dimm = 0; dimm < MAX_DIMMS_SUPPORTED; dimm++) { - pDCTstat->DimmConfiguredVoltage[dimm] = set_voltage; - } + for (dimm = 0; dimm < MAX_DIMMS_SUPPORTED; dimm++) { + pDCTstat->DimmConfiguredVoltage[dimm] = set_voltage; } } } @@ -243,23 +229,10 @@ void DIMMSetVoltages(struct MCTStatStruc *pMCTstat,
static void set_peripheral_control_lines(void) { uint8_t byte; - uint8_t nvram; - uint8_t enable_ieee1394; - - enable_ieee1394 = 1; - - if (get_option(&nvram, "ieee1394_controller") == CB_SUCCESS) - enable_ieee1394 = nvram & 0x1;
- if (enable_ieee1394) { - /* Enable PCICLK5 (onboard FireWire device) */ - outb(0x41, 0xcd6); - outb(0x02, 0xcd7); - } else { - /* Disable PCICLK5 (onboard FireWire device) */ - outb(0x41, 0xcd6); - outb(0x00, 0xcd7); - } + /* Enable PCICLK5 */ + outb(0x41, 0xcd6); + outb(0x02, 0xcd7);
/* Enable the RTC AltCentury register */ outb(0x41, 0xcd6); @@ -584,8 +557,7 @@ BOOL AMD_CB_ManualBUIDSwapList (u8 node, u8 link, const u8 **List) { /* Force BUID to 0 */ static const u8 swaplist[] = {0, 0, 0xFF, 0, 0xFF}; - if ((is_fam15h() && (node == 0) && (link == 1)) /* Family 15h BSP SB link */ - || (!is_fam15h() && (node == 0) && (link == 3))) { /* Family 10h BSP SB link */ + if ((node == 0) && (link == 2)) { /* BSP SB link */ *List = swaplist; return 1; }
