Attention is currently required from: Sridhar Siricilla, Nick Vaccaro, Balaji Manigandan, Krishna P Bhat D, Karthik Ramasubramanian. Hello build bot (Jenkins), Tim Wawrzynczak, Sridhar Siricilla, Nick Vaccaro, Balaji Manigandan, Krishna P Bhat D, Karthik Ramasubramanian,
https://review.coreboot.org/c/coreboot/+/58679
Change subject: util/spd_tools: Add LP5 support for ADL ......................................................................
Add LP5 support to spd_tools. Currently, only Intel Alder Lake (ADL) is supported.
The SPDs are generated based on a combination of: - The LPDDR5 spec JESD209-5B. - The SPD spec SPD4.1.2.M-2 (the LPDDR3/4 spec is used since JEDEC has not released an SPD spec for LPDDR5). - Intel recommendations in advisory #616599.
BUG=b:201234943, b:198704251 TEST=Generate the SPD and manifests for a test part, and check that the SPD matches Intel's expectation. More details in CB:58680.
Change-Id: Ic1e68d44f7c0ad64aa9904b7e1297d24bd5db56e Signed-off-by: Reka Norman rekanorman@google.com --- M util/spd_tools/src/part_id_gen/part_id_gen.go A util/spd_tools/src/spd_gen/lp5.go M util/spd_tools/src/spd_gen/spd_gen.go 3 files changed, 629 insertions(+), 6 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/79/58679/7
