Ravi Kumar Bokka has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/63408 )
Change subject: soc/qualcomm/common: update size of memchipinfo structure ......................................................................
BUG=b:182963902,b:177917361 TEST=Validated on qualcomm sc7280 development board
Signed-off-by: Ravi Kumar Bokka rbokka@codeaurora.org Change-Id: I51113c61d6e54268a46d53ac9e4c846ccaec4e21 --- M src/soc/qualcomm/common/qclib.c 1 file changed, 17 insertions(+), 9 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/08/63408/1
diff --git a/src/soc/qualcomm/common/qclib.c b/src/soc/qualcomm/common/qclib.c index 43b6399..3e7682c 100644 --- a/src/soc/qualcomm/common/qclib.c +++ b/src/soc/qualcomm/common/qclib.c @@ -24,22 +24,31 @@
static void write_mem_chip_information(struct qclib_cb_if_table_entry *te) { - /* Save mem_chip_info in local variables ahead of hook running */ - mem_chip_addr = (void *)te->blob_address; + if (te->size > sizeof(struct mem_chip_info) && + te->size == mem_chip_info_size((void *)te->blob_address)) { + /* Save mem_chip_info in local variables ahead of hook running */ + mem_chip_addr = (uint64_t *)te->blob_address; + } }
static void add_mem_chip_info(int unused) { void *mem_region_base = NULL; + size_t size; + + if (!mem_chip_addr) { + printk(BIOS_ERR, "Did not receive valid mem_chip_info from QcLib!"); + return; + } + + size = mem_chip_info_size(mem_chip_addr);
/* Add cbmem table */ - if (sizeof(struct mem_chip_info) != 0) - mem_region_base = cbmem_add(CBMEM_ID_MEM_CHIP_INFO, - sizeof(struct mem_chip_info)); + mem_region_base = cbmem_add(CBMEM_ID_MEM_CHIP_INFO, size); ASSERT(mem_region_base != NULL);
/* Migrate the data into CBMEM */ - memcpy(mem_region_base, mem_chip_addr, sizeof(struct mem_chip_info)); + memcpy(mem_region_base, mem_chip_addr, size); }
ROMSTAGE_CBMEM_INIT_HOOK(add_mem_chip_info); @@ -168,9 +177,8 @@ qclib_add_if_table_entry(QCLIB_TE_DDR_TRAINING_DATA, _ddr_training, REGION_SIZE(ddr_training), 0);
- /* Attempt to read MEM CHIP information */ - qclib_add_if_table_entry(QCLIB_TE_MEM_CHIP_INFO, - mem_chip_addr, sizeof(mem_chip_addr), 0); + /* Address and size of this entry will be filled in by QcLib. */ + qclib_add_if_table_entry(QCLIB_TE_MEM_CHIP_INFO, NULL, 0, 0);
/* Attempt to load PMICCFG Blob */ data_size = cbfs_load(CONFIG_CBFS_PREFIX "/pmiccfg",
