Attention is currently required from: Reka Norman, Tim Wawrzynczak, Rizwan Qureshi, Sridhar Siricilla, Angel Pons. Hello Sam McNally, build bot (Jenkins), Reka Norman, Kangheui Won, Rizwan Qureshi, Tim Wawrzynczak, Sridhar Siricilla, Angel Pons, Eric Lai,
https://review.coreboot.org/c/coreboot/+/63365
Change subject: soc/intel/alderlake: Add support to update descriptor at runtime ......................................................................
On nereid, we need to update the descriptor based on fw_config (see the follow-up patch), so add support to update the descriptor at runtime. This is a temporary workaround while we find a better solution.
This is basically adding back the configure_pmc_descriptor() function removed in CB:63339, just making it generic and allowing it to update multiple bytes at once.
BUG=b:226848617 TEST=With the following patch, Type-C and HDMI work on nereid.
Change-Id: I43c4d2888706561e42ff6b8ce0377eedbc38dbfe Signed-off-by: Reka Norman rekanorman@google.com --- M src/soc/intel/alderlake/Kconfig M src/soc/intel/alderlake/Makefile.inc A src/soc/intel/alderlake/bootblock/update_descriptor.c M src/soc/intel/alderlake/include/soc/bootblock.h 4 files changed, 107 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/65/63365/8
