Bora Guvendik has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/54036 )
Change subject: [WIP]soc/intel/alderlake: Update meminit code due to upd changes FSP 2147 onwards ......................................................................
DisableDimmMc0Ch0 upds changed to DisableMc0Ch0 in new FSP releases. The definition of the upd also changed. Changed FSP meminit code to work based on new definition of the UPDs.
Before: 0:Enable both DIMMs, 1:Disable DIMM0, 2:Disable DIMM1, 3:Disable both DIMMs
After: 0:Enable, 1:Disable
TEST=Boot to OS
Signed-off-by: Bora Guvendik bora.guvendik@intel.com Change-Id: I5af11ae99db3bbe3373a9bd4ce36453b58d62fec --- M src/soc/intel/alderlake/meminit.c 1 file changed, 14 insertions(+), 3 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/36/54036/1
diff --git a/src/soc/intel/alderlake/meminit.c b/src/soc/intel/alderlake/meminit.c index 33f26da..e6abb38 100644 --- a/src/soc/intel/alderlake/meminit.c +++ b/src/soc/intel/alderlake/meminit.c @@ -146,16 +146,27 @@
mem_cfg->MemorySpdDataLen = data->spd_len;
+ /* Disable all channels initially */ + mem_cfg->DisableMc0Ch0 = 1; + mem_cfg->DisableMc0Ch1 = 1; + mem_cfg->DisableMc0Ch2 = 1; + mem_cfg->DisableMc0Ch3 = 1; + mem_cfg->DisableMc1Ch0 = 1; + mem_cfg->DisableMc1Ch1 = 1; + mem_cfg->DisableMc1Ch2 = 1; + mem_cfg->DisableMc1Ch3 = 1; + for (ch = 0; ch < MRC_CHANNELS; ch++) { uint8_t *disable_dimm_ptr = disable_dimm_upds[ch]; - *disable_dimm_ptr = 0;
for (dimm = 0; dimm < CONFIG_DIMMS_PER_CHANNEL; dimm++) { uint32_t *spd_ptr = spd_upds[ch][dimm];
*spd_ptr = data->spd[ch][dimm]; - if (!*spd_ptr) - *disable_dimm_ptr |= BIT(dimm); + if (*spd_ptr) { + *disable_dimm_ptr = 0; + break; + } } } }
