Duncan Laurie has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/31918
Change subject: soc/intel/common: Update ESPI disable option ......................................................................
Update the Kconfig option for disabling ESPI SMI source to disable it entirely, not just when ACPI mode is disabled.
For the situations where this is needed (just the sarien board) it is better to completely stop the EC from sending any SMI events as no actions are taken.
Change-Id: Id94481bb2f0cfc948f350be45d360bfe40ddf018 Signed-off-by: Duncan Laurie dlaurie@google.com --- M src/mainboard/google/sarien/Kconfig M src/soc/intel/common/block/smm/Kconfig M src/soc/intel/common/block/smm/smihandler.c M src/soc/intel/common/block/smm/smm.c 4 files changed, 10 insertions(+), 19 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/18/31918/1
diff --git a/src/mainboard/google/sarien/Kconfig b/src/mainboard/google/sarien/Kconfig index 8f8b37c..6164c8e 100644 --- a/src/mainboard/google/sarien/Kconfig +++ b/src/mainboard/google/sarien/Kconfig @@ -18,7 +18,7 @@ select SOC_INTEL_COMMON_ACPI_EC_PTS_WAK select SOC_INTEL_WHISKEYLAKE select SOC_INTEL_COMMON_BLOCK_HDA_VERB - select SOC_INTEL_COMMON_BLOCK_SMM_ESPI_ACPI_DIS + select SOC_INTEL_COMMON_BLOCK_SMM_ESPI_DISABLE select SPD_READ_BY_WORD select SYSTEM_TYPE_LAPTOP if BOARD_GOOGLE_SARIEN select SYSTEM_TYPE_CONVERTIBLE if BOARD_GOOGLE_ARCADA diff --git a/src/soc/intel/common/block/smm/Kconfig b/src/soc/intel/common/block/smm/Kconfig index cc6bc44..a58c631 100644 --- a/src/soc/intel/common/block/smm/Kconfig +++ b/src/soc/intel/common/block/smm/Kconfig @@ -8,13 +8,12 @@ help Intel Processor trap flag if it is supported
-config SOC_INTEL_COMMON_BLOCK_SMM_ESPI_ACPI_DIS +config SOC_INTEL_COMMON_BLOCK_SMM_ESPI_DISABLE bool default n help - Disable eSPI SMI when ACPI mode is enabled. This will - prevent the embedded controller from asserting SMI when - booted into an ACPI aware OS. + Disable eSPI SMI source to prevent the embedded controller + from asserting SMI while in firmware.
config SOC_INTEL_COMMON_BLOCK_SMM_S5_DELAY_MS int diff --git a/src/soc/intel/common/block/smm/smihandler.c b/src/soc/intel/common/block/smm/smihandler.c index 16bb3a2..7aa69c5 100644 --- a/src/soc/intel/common/block/smm/smihandler.c +++ b/src/soc/intel/common/block/smm/smihandler.c @@ -361,14 +361,10 @@ break; case APM_CNT_ACPI_DISABLE: pmc_disable_pm1_control(SCI_EN); - if (CONFIG(SOC_INTEL_COMMON_BLOCK_SMM_ESPI_ACPI_DIS)) - pmc_enable_smi(ESPI_SMI_EN); printk(BIOS_DEBUG, "SMI#: ACPI disabled.\n"); break; case APM_CNT_ACPI_ENABLE: pmc_enable_pm1_control(SCI_EN); - if (CONFIG(SOC_INTEL_COMMON_BLOCK_SMM_ESPI_ACPI_DIS)) - pmc_disable_smi(ESPI_SMI_EN); printk(BIOS_DEBUG, "SMI#: ACPI enabled.\n"); break; case APM_CNT_GNVS_UPDATE: diff --git a/src/soc/intel/common/block/smm/smm.c b/src/soc/intel/common/block/smm/smm.c index dd8bab3..75b933e 100644 --- a/src/soc/intel/common/block/smm/smm.c +++ b/src/soc/intel/common/block/smm/smm.c @@ -41,6 +41,8 @@
void smm_southbridge_enable(uint16_t pm1_events) { + uint32_t smi_params = ENABLE_SMI_PARAMS; + printk(BIOS_DEBUG, "Enabling SMIs.\n"); /* Configure events */ pmc_enable_pm1(pm1_events); @@ -60,14 +62,16 @@ * - on APMC writes (io 0xb2) * - on writes to SLP_EN (sleep states) * - on writes to GBL_RLS (bios commands) - * - on eSPI events (does nothing on LPC systems) + * - on eSPI events, unless disabled (does nothing on LPC systems) * No SMIs: * - on microcontroller writes (io 0x62/0x66) * - on TCO events */ + if (CONFIG(SOC_INTEL_COMMON_BLOCK_SMM_ESPI_DISABLE)) + smi_params &= ~ESPI_SMI_EN;
/* Enable SMI generation: */ - pmc_enable_smi(ENABLE_SMI_PARAMS); + pmc_enable_smi(smi_params); }
void smm_setup_structures(void *gnvs, void *tcg, void *smi1) @@ -94,11 +98,3 @@ *start = (void *)sa_get_tseg_base(); *size = sa_get_tseg_size(); } - -#if CONFIG(SOC_INTEL_COMMON_BLOCK_SMM_ESPI_ACPI_DIS) -static void smm_disable_espi(void *dest) -{ - pmc_disable_smi(ESPI_SMI_EN); -} -BOOT_STATE_INIT_ENTRY(BS_OS_RESUME, BS_ON_ENTRY, smm_disable_espi, NULL); -#endif
Furquan Shaikh has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/31918 )
Patch Set 1: Code-Review+2
Patrick Georgi has submitted this change and it was merged. ( https://review.coreboot.org/c/coreboot/+/31918 )
Change-Id: Id94481bb2f0cfc948f350be45d360bfe40ddf018 Signed-off-by: Duncan Laurie dlaurie@google.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/31918 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Furquan Shaikh furquan@google.com --- M src/mainboard/google/sarien/Kconfig M src/soc/intel/common/block/smm/Kconfig M src/soc/intel/common/block/smm/smihandler.c M src/soc/intel/common/block/smm/smm.c 4 files changed, 10 insertions(+), 19 deletions(-)
