Duncan Laurie has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/31919
Change subject: ec/google/wilco: Fix handling of commands that do not respond ......................................................................
If the command does not respond the driver should not wait for it to complete before returning.
Tested with SMI debug enabled to ensure that the final command does not report a failure.
Change-Id: I7c1bfa19a92e8332ac1aa6ff95f94ff4cbdf789d Signed-off-by: Duncan Laurie dlaurie@google.com --- M src/ec/google/wilco/mailbox.c 1 file changed, 6 insertions(+), 6 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/19/31919/1
diff --git a/src/ec/google/wilco/mailbox.c b/src/ec/google/wilco/mailbox.c index 1c38a5b..d47290c 100644 --- a/src/ec/google/wilco/mailbox.c +++ b/src/ec/google/wilco/mailbox.c @@ -155,12 +155,6 @@ /* Start the command */ outb(EC_MAILBOX_START_COMMAND, CONFIG_EC_BASE_HOST_COMMAND);
- /* Wait for it to complete */ - if (wilco_ec_response_timed_out()) { - printk(BIOS_ERR, "%s: response timed out\n", __func__); - return -1; - } - /* Some commands will put the EC into a state where it cannot respond */ if (msg->type == WILCO_EC_MSG_NO_RESPONSE) { printk(BIOS_DEBUG, "%s: EC does not respond to this command\n", @@ -168,6 +162,12 @@ return 0; }
+ /* Wait for it to complete */ + if (wilco_ec_response_timed_out()) { + printk(BIOS_ERR, "%s: response timed out\n", __func__); + return -1; + } + /* Check result */ msg->result = inb(CONFIG_EC_BASE_HOST_DATA); if (msg->result != 0) {
Furquan Shaikh has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/31919 )
Patch Set 1: Code-Review+2
Patrick Georgi has submitted this change and it was merged. ( https://review.coreboot.org/c/coreboot/+/31919 )
Change-Id: I7c1bfa19a92e8332ac1aa6ff95f94ff4cbdf789d Signed-off-by: Duncan Laurie dlaurie@google.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/31919 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Furquan Shaikh furquan@google.com --- M src/ec/google/wilco/mailbox.c 1 file changed, 6 insertions(+), 6 deletions(-)
