Duncan Laurie has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/31920
Change subject: ec/google/wilco: Enable software sync for VBOOT ......................................................................
Enable software sync by default if VBOOT is enabled. The slow update option is also needed, but this is moving to depthcharge so it is not defined here.
Change-Id: I046661fae7315f84e96293532b4e1568558df962 Signed-off-by: Duncan Laurie dlaurie@google.com --- M src/ec/google/wilco/Kconfig 1 file changed, 1 insertion(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/20/31920/1
diff --git a/src/ec/google/wilco/Kconfig b/src/ec/google/wilco/Kconfig index 4202c1d..f4a4111 100644 --- a/src/ec/google/wilco/Kconfig +++ b/src/ec/google/wilco/Kconfig @@ -3,6 +3,7 @@ default n select EC_GOOGLE_COMMON_MEC select EC_ACPI + select VBOOT_EC_SOFTWARE_SYNC if VBOOT help Google Wilco Embedded Controller interface.
Furquan Shaikh has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/31920 )
Patch Set 1: Code-Review+2
Patrick Georgi has submitted this change and it was merged. ( https://review.coreboot.org/c/coreboot/+/31920 )
Change-Id: I046661fae7315f84e96293532b4e1568558df962 Signed-off-by: Duncan Laurie dlaurie@google.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/31920 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Furquan Shaikh furquan@google.com --- M src/ec/google/wilco/Kconfig 1 file changed, 1 insertion(+), 0 deletions(-)
