Attention is currently required from: Anil Kumar K, Bora Guvendik, Julius Werner, Subrata Banik, Wonkyu Kim.
Hello Anil Kumar K, Bora Guvendik, Jérémy Compostella, Subrata Banik, Wonkyu Kim, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/83153?usp=email
The following approvals got outdated and were removed: Code-Review+1 by Anil Kumar K, Verified+1 by build bot (Jenkins)
Change subject: lib: Add Kconfig variable for fw_config default value ......................................................................
This CONFIG_FW_CONFIG_DEFAULT_VALUE is used only when CBI fw_config value cannot be read from all sources such as Chrome EC and VPD. It defaults to the same value as UNDEFINED_FW_CONFIG defined in fw_config.h. and it won't be used unless it is set to different value in config.<board> file. If a valid value is read from the Chrome EC or VPD, the fw_config value won't be not overriden by this flag.
TEST=boot and check fw_config value from coreboot log
Signed-off-by: Cliff Huang cliff.huang@intel.com Change-Id: I9694433e01bdcd9ff1e550585c14ea7ccee020a3 --- M src/Kconfig M src/lib/fw_config.c 2 files changed, 16 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/53/83153/4
