Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/64052 )
Change subject: soc/amd/common/include/espi: generalize IO/MMIO decode range macros ......................................................................
Sabrina has more eSPI decode ranges than Picasso or Cezanne. Those registers are however not in one block where it's easy to calculate the addresses of a register from the index of the decode range. Within one group of decode range registers it's still easy to calculate the register address, so move the base address from within the macro to the instantiation of the macro as a preparation for adding the support for the additional ranges.
TEST=Timeless build results in identical binary for Mandolin
Signed-off-by: Felix Held felix-coreboot@felixheld.de Change-Id: Id309d955fa3558d660db37a2075240f938361e83 Reviewed-on: https://review.coreboot.org/c/coreboot/+/64052 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Raul Rangel rrangel@chromium.org Reviewed-by: Fred Reitberger reitbergerfred@gmail.com --- M src/soc/amd/common/block/include/amdblocks/espi.h M src/soc/amd/common/block/lpc/espi_util.c 2 files changed, 8 insertions(+), 8 deletions(-)
Approvals: build bot (Jenkins): Verified Raul Rangel: Looks good to me, approved Fred Reitberger: Looks good to me, but someone else must approve
diff --git a/src/soc/amd/common/block/include/amdblocks/espi.h b/src/soc/amd/common/block/include/amdblocks/espi.h index cfba50b..45a220e 100644 --- a/src/soc/amd/common/block/include/amdblocks/espi.h +++ b/src/soc/amd/common/block/include/amdblocks/espi.h @@ -25,10 +25,10 @@ #define ESPI_MMIO_SIZE_REG0 0x60 #define ESPI_MMIO_SIZE_REG1 0x64
-#define ESPI_IO_RANGE_BASE(range) (ESPI_IO_BASE_REG0 + ((range) & 3) * 2) -#define ESPI_IO_RANGE_SIZE(range) (ESPI_IO_SIZE0 + ((range) & 3)) -#define ESPI_MMIO_RANGE_BASE(range) (ESPI_MMIO_BASE_REG0 + ((range) & 3) * 4) -#define ESPI_MMIO_RANGE_SIZE(range) (ESPI_MMIO_SIZE_REG0 + ((range) & 3) * 2) +#define ESPI_IO_RANGE_BASE_REG(base, range) ((base) + ((range) & 3) * 2) +#define ESPI_IO_RANGE_SIZE_REG(base, range) ((base) + ((range) & 3)) +#define ESPI_MMIO_RANGE_BASE_REG(base, range) ((base) + ((range) & 3) * 4) +#define ESPI_MMIO_RANGE_SIZE_REG(base, range) ((base) + ((range) & 3) * 2)
#define ESPI_GENERIC_IO_WIN_COUNT 4 #define ESPI_GENERIC_IO_MAX_WIN_SIZE 0x100 diff --git a/src/soc/amd/common/block/lpc/espi_util.c b/src/soc/amd/common/block/lpc/espi_util.c index c4d15e4..a5f43f4 100644 --- a/src/soc/amd/common/block/lpc/espi_util.c +++ b/src/soc/amd/common/block/lpc/espi_util.c @@ -72,22 +72,22 @@
static inline unsigned int espi_io_range_base_reg(unsigned int idx) { - return ESPI_IO_RANGE_BASE(idx); + return ESPI_IO_RANGE_BASE_REG(ESPI_IO_BASE_REG0, idx); }
static inline unsigned int espi_io_range_size_reg(unsigned int idx) { - return ESPI_IO_RANGE_SIZE(idx); + return ESPI_IO_RANGE_SIZE_REG(ESPI_IO_SIZE0, idx); }
static inline unsigned int espi_mmio_range_base_reg(unsigned int idx) { - return ESPI_MMIO_RANGE_BASE(idx); + return ESPI_MMIO_RANGE_BASE_REG(ESPI_MMIO_BASE_REG0, idx); }
static inline unsigned int espi_mmio_range_size_reg(unsigned int idx) { - return ESPI_MMIO_RANGE_SIZE(idx); + return ESPI_MMIO_RANGE_SIZE_REG(ESPI_MMIO_SIZE_REG0, idx); }
static void espi_enable_decode(uint32_t decode_en)
