Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/79113?usp=email )
1 is the latest approved patch-set. No files were changed between the latest approved patch-set and the submitted one. )Change subject: nb/intel/sandybridge: assign host bridge ops in chipset devicetree ......................................................................
Since the host bridge is always function 0 of device 0 on bus 0, the device operations can be statically assigned in the devicetree and there's no need to bind the host bridge device operations to the PCI device during runtime via a list of PCI IDs.
TEST=Lenovo X220 still boots to Linux
Signed-off-by: Felix Held felix-coreboot@felixheld.de Tested-by: Patrick Rudolph patrick.rudolph@9elements.com Change-Id: Icf3d9f8cd2be2f8ef71fd9fdb5f005f3b683332e Reviewed-on: https://review.coreboot.org/c/coreboot/+/79113 Reviewed-by: Arthur Heymans arthur@aheymans.xyz Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Patrick Rudolph patrick.rudolph@9elements.com --- M src/northbridge/intel/sandybridge/chipset.cb M src/northbridge/intel/sandybridge/northbridge.c 2 files changed, 2 insertions(+), 14 deletions(-)
Approvals: Patrick Rudolph: Looks good to me, approved Arthur Heymans: Looks good to me, approved build bot (Jenkins): Verified
diff --git a/src/northbridge/intel/sandybridge/chipset.cb b/src/northbridge/intel/sandybridge/chipset.cb index 5635ca6..9fb1701 100644 --- a/src/northbridge/intel/sandybridge/chipset.cb +++ b/src/northbridge/intel/sandybridge/chipset.cb @@ -10,7 +10,7 @@ end device domain 0 on ops sandybridge_pci_domain_ops - device pci 00.0 alias host_bridge on end # host bridge + device pci 00.0 alias host_bridge on ops sandybridge_host_bridge_ops end device pci 01.0 alias peg10 off end # PEG10 device pci 01.1 alias peg11 off end # PEG11 device pci 01.2 alias peg12 off end # PEG12 diff --git a/src/northbridge/intel/sandybridge/northbridge.c b/src/northbridge/intel/sandybridge/northbridge.c index 9511cc3..6b89710 100644 --- a/src/northbridge/intel/sandybridge/northbridge.c +++ b/src/northbridge/intel/sandybridge/northbridge.c @@ -390,7 +390,7 @@ set_above_4g_pci(dev); }
-static struct device_operations mc_ops = { +struct device_operations sandybridge_host_bridge_ops = { .read_resources = mc_read_resources, .set_resources = pci_dev_set_resources, .enable_resources = pci_dev_enable_resources, @@ -399,18 +399,6 @@ .acpi_fill_ssdt = mc_gen_ssdt, };
-static const unsigned short pci_device_ids[] = { - 0x0100, 0x0104, 0x0108, /* Sandy Bridge */ - 0x0150, 0x0154, 0x0158, /* Ivy Bridge */ - 0 -}; - -static const struct pci_driver mc_driver __pci_driver = { - .ops = &mc_ops, - .vendor = PCI_VID_INTEL, - .devices = pci_device_ids, -}; - struct device_operations sandybridge_cpu_bus_ops = { .read_resources = noop_read_resources, .set_resources = noop_set_resources,
