Alexandru Gagniuc (mr.nuke.me@gmail.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/13350
commit 7f8382a7873989df7599d2456942a4dc476f6834 Author: Alexandru Gagniuc alexandrux.gagniuc@intel.com Date: Mon Nov 9 17:07:18 2015 -0800
drivers/intel/fsp2_0: Add infrastructure to parse resource HOBs
This adds the minimal infrastructure to allow printing reource HOBs returned by FSP memory_init, and to allow locating the FSP reserved memory area.
Change-Id: Ie79441aacdb808200921817f537bf01e0456b72c Signed-off-by: Alexandru Gagniuc alexandrux.gagniuc@intel.com --- src/drivers/intel/fsp2_0/Makefile.inc | 2 + src/drivers/intel/fsp2_0/hand_off_block.c | 230 ++++++++++++++++++++++++++++ src/drivers/intel/fsp2_0/include/fsp/util.h | 14 ++ 3 files changed, 246 insertions(+)
diff --git a/src/drivers/intel/fsp2_0/Makefile.inc b/src/drivers/intel/fsp2_0/Makefile.inc index ef0cae8..e7081a7 100644 --- a/src/drivers/intel/fsp2_0/Makefile.inc +++ b/src/drivers/intel/fsp2_0/Makefile.inc @@ -1,3 +1,5 @@ + +romstage-y += hand_off_block.c romstage-y += util.c romstage-y += memory_init.c
diff --git a/src/drivers/intel/fsp2_0/hand_off_block.c b/src/drivers/intel/fsp2_0/hand_off_block.c new file mode 100644 index 0000000..8529b58 --- /dev/null +++ b/src/drivers/intel/fsp2_0/hand_off_block.c @@ -0,0 +1,230 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2015 Intel Corp. + * (Written by Alexandru Gagniuc alexandrux.gagniuc@intel.com for Intel Corp.) + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + */ + +#include <arch/io.h> +#include <cbmem.h> +#include <commonlib/helpers.h> +#include <console/console.h> +#include <fsp/util.h> +#include <inttypes.h> +#include <lib.h> +#include <string.h> + +void hoboparse (const void *hob); + +#define HOB_HEADER_LEN 8 + +struct hob_header { + uint16_t type; + uint16_t length; +} __attribute__((packed)); + +struct hob_resource { + uint8_t owner_guid[16]; + uint32_t type; + uint32_t attribute_type; + uint64_t addr; + uint64_t length; +} __attribute__((packed)); + +enum resource_type { + EFI_RESOURCE_SYSTEM_MEMORY = 0, + EFI_RESOURCE_MEMORY_MAPPED_IO = 1, + EFI_RESOURCE_IO = 2, + EFI_RESOURCE_FIRMWARE_DEVICE = 3, + EFI_RESOURCE_MEMORY_MAPPED_IO_PORT = 4, + EFI_RESOURCE_MEMORY_RESERVED = 5, + EFI_RESOURCE_IO_RESERVED = 6, + EFI_RESOURCE_MAX_MEMORY_TYPE = 7, +}; + +static const char *resource_names[] = { + [EFI_RESOURCE_SYSTEM_MEMORY] = "SYSTEM_MEMORY", + [EFI_RESOURCE_MEMORY_MAPPED_IO] = "MMIO", + [EFI_RESOURCE_IO] = "IO", + [EFI_RESOURCE_FIRMWARE_DEVICE] = "FIRMWARE_DEVICE", + [EFI_RESOURCE_MEMORY_MAPPED_IO_PORT] = "MMIO_PORT", + [EFI_RESOURCE_MEMORY_RESERVED] = "MEMORY_RESERVED", + [EFI_RESOURCE_IO_RESERVED] = "IO_RESERVED", +}; + +enum hob_type { + HOB_TYPE_HANDOFF = 0x0001, + HOB_TYPE_MEMORY_ALLOCATION = 0x0002, + HOB_TYPE_RESOURCE_DESCRIPTOR = 0x0003, + HOB_TYPE_GUID_EXTENSION = 0x0004, + HOB_TYPE_FV = 0x0005, + HOB_TYPE_CPU = 0x0006, + HOB_TYPE_MEMORY_POOL = 0x0007, + HOB_TYPE_FV2 = 0x0009, + HOB_TYPE_LOAD_PEIM_UNUSED = 0x000A, + HOB_TYPE_UCAPSULE = 0x000B, + HOB_TYPE_UNUSED = 0xFFFE, + HOB_TYPE_END_OF_HOB_LIST = 0xFFFF, +}; + +/* UUIDs (GUIDs) in little-endian, so they can be used with memcmp() */ +static const uint8_t uuid_owner_fsp[16] = { + 0x59, 0x97, 0xa7, 0x69, 0x73, 0x13, 0x67, 0x43, + 0xa6, 0xc4, 0xc7, 0xf5, 0x9e, 0xfd, 0x98, 0x6e, +}; + +static const uint8_t empty_uuid[16] = { + 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 +}; + +static const char *resource_name(enum resource_type type) +{ + if (type >= ARRAY_SIZE(resource_names)) + return "UNKNOWN"; + return resource_names[type]; +} + +/* + * Utilities for walking HOBs + */ + +static bool uuid_compare(const uint8_t uuid1[16], const uint8_t uuid2[16]) +{ + return !memcmp(uuid1, uuid2, 16); +} + +static const struct hob_header *next_hob(const struct hob_header *parent) +{ + union { + const struct hob_header *hob; + uintptr_t addr; + } hob_walker; + + hob_walker.hob = parent; + hob_walker.addr += parent->length; + return hob_walker.hob; +} + +static const void *hob_header_to_struct(const struct hob_header *hob) +{ + union { + const struct hob_header *hob_hdr; + const void *hob_descr; + uintptr_t addr; + } hob_walker; + + hob_walker.hob_hdr = hob; + hob_walker.addr += HOB_HEADER_LEN; + return hob_walker.hob_descr; +} + +static const +struct hob_resource *hob_header_to_resource(const struct hob_header *hob) +{ + return hob_header_to_struct(hob); +} + +/* + * Utilities for locating and identifying HOBs + */ + +void fsp_save_hob_list(void *hob_list_ptr) +{ + void **cbmem_loc; + cbmem_loc = cbmem_add(CBMEM_ID_FSP_RUNTIME, sizeof(*hob_list_ptr)); + *cbmem_loc = hob_list_ptr; +} + +const void *fsp_get_hob_list(void) +{ + void **list_loc = cbmem_find(CBMEM_ID_FSP_RUNTIME); + + return (list_loc) ? (*list_loc) : NULL; +} + +static const +struct hob_resource *find_resource_hob_by_uuid(const struct hob_header *hob, + const uint8_t uuid[16]) +{ + const struct hob_resource *res; + + for ( ; hob->type != HOB_TYPE_END_OF_HOB_LIST; hob = next_hob(hob)) { + + if (hob->type != HOB_TYPE_RESOURCE_DESCRIPTOR) + continue; + + res = hob_header_to_resource(hob); + if (uuid_compare(res->owner_guid, uuid)) + return res; + } + return NULL; +} + +void fsp_find_reserved_memory(struct resource *res, const void *hob_list) +{ + const struct hob_resource *fsp_mem; + + res->size = 0; + res->align = 0; + res->gran = 0; + res->next = NULL; + + fsp_mem = find_resource_hob_by_uuid(hob_list, uuid_owner_fsp); + + if (!fsp_mem) { + return; + } + + res->base = fsp_mem->addr; + res->size = fsp_mem->length; +} + +/* + * Utilities for printing HOB information + */ + +static void print_guid(const void *base) +{ + uint32_t big; + uint16_t mid[2]; + + const uint8_t *id = base; + big = read32(id + 0); + mid[0] = read16(id + 4); + mid[1] = read16(id + 6); + + printk(BIOS_DEBUG, "%08x-%04x-%04x-%02x%02x%02x%02x%02x%02x%02x%02x\n", + big, mid[0], mid[1], + id[8], id[9], id[10], id[11], id[12], id[13],id[14], id[15]); +} + +static void print_resource_descriptor(const void *base) +{ + const struct hob_resource *res; + + res = hob_header_to_resource(base); + + printk(BIOS_DEBUG, "Resource %s, attribute %x\n", + resource_name(res->type), res->attribute_type); + printk(BIOS_DEBUG, "\t0x%08llx + 0x%08llx\n", res->addr, res->length); + if (!uuid_compare(res->owner_guid, empty_uuid)) { + printk(BIOS_DEBUG, "\tOwner GUID: "); + print_guid(res->owner_guid); + } +} + + +void fsp_print_memory_resource_hobs(const void *hob_list) +{ + const struct hob_header *hob = hob_list; + + for ( ; hob->type != HOB_TYPE_END_OF_HOB_LIST; hob = next_hob(hob)) { + if (hob->type == HOB_TYPE_RESOURCE_DESCRIPTOR) + print_resource_descriptor(hob); + } +} diff --git a/src/drivers/intel/fsp2_0/include/fsp/util.h b/src/drivers/intel/fsp2_0/include/fsp/util.h index abdbcf0..0e3f412 100644 --- a/src/drivers/intel/fsp2_0/include/fsp/util.h +++ b/src/drivers/intel/fsp2_0/include/fsp/util.h @@ -14,6 +14,20 @@ #define _FSP2_0_UTIL_H_
#include <fsp/info_header.h> +#include <device/resource.h> + +/* + * Hand-off-block handling functions that depend on CBMEM, and thus can only + * be used after cbmem_initialize(). + */ +void fsp_save_hob_list(void *hob_list_ptr); +const void *fsp_get_hob_list(void); +/* + * Hand-off-block utilities which do not depend on CBMEM, but need to be passed + * the HOB list explicitly. + */ +void fsp_find_reserved_memory(struct resource *res, const void *hob_list); +void fsp_print_memory_resource_hobs(const void *hob_list);
/* Load an FSP binary into CBFS, and fill the associated fsp_header struct */ enum cb_err fsp_load_binary(struct fsp_header *hdr, const char *name);
