Attention is currently required from: Angel Pons, Felix Singer, Jan Philipp Groß, Máté Kukri.
Hello Angel Pons, Máté Kukri, Nicholas Chin, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/82906?usp=email
Change subject: mb/asrock: Add Z87M OC Formula (Haswell) ......................................................................
This port was done via autoport and subsequent manual tweaking. Special thanks to Nicholas Chin! This port would have never succeeded without his help.
The board features two socketed DIP-8 SPI flash chips, as well as a BIOS selection switch and onboard Power and Reset switches.
Working: - Haswell MRC.bin - All four DDR3/DDR3L DIMM slots - S3 suspend and resume - Libgfxinit - HDMI-Out Port - USB 2.0 Ports - Vertical Type A USB 2.0 - USB 3.1 Gen1 Ports - HD Audio Jack (audio output) - Front panel audio connector (audio output) - RJ-45 Gigabit LAN Port - SATA3 6.0 Gb/s connectors - mSATA/mini-PCI Express slot - half mini-PCI Express slot - PCI Express 3.0 x16 slots (both) - PCI Express 2.0 x4 slot - PCI Express 2.0 x1 slot
Working (board-specific) - Power Switch with LED (functional, yet no LED) - Reset Switch with LED (functional, yet no LED) - BIOS Selection Switch - Slow Mode Switch (locks the CPU at 800MHz)
not (yet) tested: - IR header - COM Port header - Power LED header - eSATA connector - USB 2.0 headers - PS/2 Mouse/Keyboard Port - HDMI-In Port - Optical SPDIF Out Port
not (yet) working: - Software fan control: While the Nuvoton chip is correctly discovered, the numbering of the fan connectors is faulty, resulting in the wrong fan being controlled. - Dr. Debug: on vendor firmware, the LEDs turn off after successful boot. On coreboot, the LED shows two bright zeros after boot. - Post Status Checker (PSC)
Change-Id: Iaa156b34ed65e66dd5de5a26010409999a5f8746 Signed-off-by: Jan Philipp Groß jeangrande@mailbox.org --- A src/mainboard/asrock/z87m_oc_formula/Kconfig A src/mainboard/asrock/z87m_oc_formula/Kconfig.name A src/mainboard/asrock/z87m_oc_formula/Makefile.mk A src/mainboard/asrock/z87m_oc_formula/acpi/ec.asl A src/mainboard/asrock/z87m_oc_formula/acpi/platform.asl A src/mainboard/asrock/z87m_oc_formula/acpi/superio.asl A src/mainboard/asrock/z87m_oc_formula/board_info.txt A src/mainboard/asrock/z87m_oc_formula/bootblock.c A src/mainboard/asrock/z87m_oc_formula/data.vbt A src/mainboard/asrock/z87m_oc_formula/devicetree.cb A src/mainboard/asrock/z87m_oc_formula/dsdt.asl A src/mainboard/asrock/z87m_oc_formula/gma-mainboard.ads A src/mainboard/asrock/z87m_oc_formula/gpio.c A src/mainboard/asrock/z87m_oc_formula/hda_verb.c A src/mainboard/asrock/z87m_oc_formula/romstage.c 15 files changed, 510 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/06/82906/11
