Hello Aaron Durbin, Duncan Laurie, build bot (Jenkins),
https://review.coreboot.org/19829
Change subject: mainboard/google/poppy: Add PowerResource for touchscreen device ......................................................................
1. Do not enable touchscreen device by default in gpio configuration. 2. Select use of PowerResource for touchscreen device in devicetree so that the ACPI subsystem can take care of powering on/off the device. When system enters suspend, touchscreen device is powered off and on resume, it is powered back on.
BUG=b:62028489 TEST=Verified 100 cycles of suspend-resume. Touchscreen still works on poppy.
Change-Id: Ia0bebc7259b10cc60a9fa5b53542dfdd9685663e Signed-off-by: Furquan Shaikh furquan@chromium.org --- M src/mainboard/google/poppy/variants/baseboard/devicetree.cb M src/mainboard/google/poppy/variants/baseboard/gpio.c M src/mainboard/google/poppy/variants/soraka/devicetree.cb 3 files changed, 9 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/29/19829/3
