Keith Hui has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/39903 )
Change subject: asus/p2b-d: Transform into variant ......................................................................
TEST=build with BUILD_TIMELESS=1, binary does not change
Change-Id: I1161c726c8c752b5b1e152e1617811989631096e Signed-off-by: Keith Hui buurin@gmail.com --- D src/mainboard/asus/p2b-d/Kconfig D src/mainboard/asus/p2b-d/Kconfig.name D src/mainboard/asus/p2b-d/romstage.c M src/mainboard/asus/p2b/Kconfig M src/mainboard/asus/p2b/Kconfig.name M src/mainboard/asus/p2b/Makefile.inc R src/mainboard/asus/p2b/variants/p2b-d/board_info.txt R src/mainboard/asus/p2b/variants/p2b-d/devicetree.cb R src/mainboard/asus/p2b/variants/p2b-d/irq_tables.c R src/mainboard/asus/p2b/variants/p2b-d/mptable.c 10 files changed, 19 insertions(+), 65 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/03/39903/1
diff --git a/src/mainboard/asus/p2b-d/Kconfig b/src/mainboard/asus/p2b-d/Kconfig deleted file mode 100644 index 2b61db7..0000000 --- a/src/mainboard/asus/p2b-d/Kconfig +++ /dev/null @@ -1,45 +0,0 @@ -## -## This file is part of the coreboot project. -## -## -## This program is free software; you can redistribute it and/or modify -## it under the terms of the GNU General Public License as published by -## the Free Software Foundation; version 2 of the License. -## -## This program is distributed in the hope that it will be useful, -## but WITHOUT ANY WARRANTY; without even the implied warranty of -## MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -## GNU General Public License for more details. -## -if BOARD_ASUS_P2B_D - -config BOARD_SPECIFIC_OPTIONS - def_bool y - select CPU_INTEL_SLOT_1 - select NORTHBRIDGE_INTEL_I440BX - select SOUTHBRIDGE_INTEL_I82371EB - select SUPERIO_WINBOND_W83977TF - select HAVE_PIRQ_TABLE - select HAVE_MP_TABLE - select SMP - select IOAPIC - select BOARD_ROMSIZE_KB_256 - select SDRAMPWR_4DIMM - -config MAINBOARD_DIR - string - default "asus/p2b-d" - -config MAINBOARD_PART_NUMBER - string - default "P2B-D" - -config IRQ_SLOT_COUNT - int - default 6 - -config MAX_CPUS - int - default 2 - -endif # BOARD_ASUS_P2B_D diff --git a/src/mainboard/asus/p2b-d/Kconfig.name b/src/mainboard/asus/p2b-d/Kconfig.name deleted file mode 100644 index 23e7808..0000000 --- a/src/mainboard/asus/p2b-d/Kconfig.name +++ /dev/null @@ -1,2 +0,0 @@ -config BOARD_ASUS_P2B_D - bool "P2B-D" diff --git a/src/mainboard/asus/p2b-d/romstage.c b/src/mainboard/asus/p2b-d/romstage.c deleted file mode 100644 index b996f1e..0000000 --- a/src/mainboard/asus/p2b-d/romstage.c +++ /dev/null @@ -1,17 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; either version 2 of the License, or - * (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -/* Shares romstage with P2B-DS */ -#include "../p2b-ds/romstage.c" diff --git a/src/mainboard/asus/p2b/Kconfig b/src/mainboard/asus/p2b/Kconfig index 694469d..36d882f 100644 --- a/src/mainboard/asus/p2b/Kconfig +++ b/src/mainboard/asus/p2b/Kconfig @@ -11,7 +11,14 @@ ## MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the ## GNU General Public License for more details. ## -if BOARD_ASUS_P2B || BOARD_ASUS_P2B_F || BOARD_ASUS_P2B_LS +if BOARD_ASUS_P2B || BOARD_ASUS_P2B_D || BOARD_ASUS_P2B_F || BOARD_ASUS_P2B_LS + +config BASE_ASUS_P2B_D + def_bool n + select SDRAMPWR_4DIMM + select HAVE_MP_TABLE + select IOAPIC + select SMP
config BOARD_SPECIFIC_OPTIONS def_bool y @@ -23,6 +30,11 @@ select BOARD_ROMSIZE_KB_256 select SDRAMPWR_4DIMM if BOARD_ASUS_P2B_LS select HAVE_ACPI_TABLES if BOARD_ASUS_P2B || BOARD_ASUS_P2B_LS + select BASE_ASUS_P2B_D if BOARD_ASUS_P2B_D + +config MAX_CPUS + int + default 2 if BASE_ASUS_P2B_D
config MAINBOARD_DIR string @@ -31,12 +43,14 @@ config MAINBOARD_PART_NUMBER string default "P2B" if BOARD_ASUS_P2B + default "P2B-D" if BOARD_ASUS_P2B_D default "P2B-F" if BOARD_ASUS_P2B_F default "P2B-LS" if BOARD_ASUS_P2B_LS
config VARIANT_DIR string default "p2b" if BOARD_ASUS_P2B + default "p2b-d" if BOARD_ASUS_P2B_D default "p2b-f" if BOARD_ASUS_P2B_F default "p2b-ls" if BOARD_ASUS_P2B_LS
diff --git a/src/mainboard/asus/p2b/Kconfig.name b/src/mainboard/asus/p2b/Kconfig.name index fd645f0..8c42258 100644 --- a/src/mainboard/asus/p2b/Kconfig.name +++ b/src/mainboard/asus/p2b/Kconfig.name @@ -1,6 +1,9 @@ config BOARD_ASUS_P2B bool "P2B"
+config BOARD_ASUS_P2B_D + bool "P2B-D" + config BOARD_ASUS_P2B_F bool "P2B-F"
diff --git a/src/mainboard/asus/p2b/Makefile.inc b/src/mainboard/asus/p2b/Makefile.inc index 640396e..ca08106 100644 --- a/src/mainboard/asus/p2b/Makefile.inc +++ b/src/mainboard/asus/p2b/Makefile.inc @@ -1 +1,2 @@ ramstage-$(CONFIG_GENERATE_PIRQ_TABLE) += variants/$(VARIANT_DIR)/irq_tables.c +ramstage-$(CONFIG_GENERATE_MP_TABLE) += variants/$(VARIANT_DIR)/mptable.c diff --git a/src/mainboard/asus/p2b-d/board_info.txt b/src/mainboard/asus/p2b/variants/p2b-d/board_info.txt similarity index 100% rename from src/mainboard/asus/p2b-d/board_info.txt rename to src/mainboard/asus/p2b/variants/p2b-d/board_info.txt diff --git a/src/mainboard/asus/p2b-d/devicetree.cb b/src/mainboard/asus/p2b/variants/p2b-d/devicetree.cb similarity index 100% rename from src/mainboard/asus/p2b-d/devicetree.cb rename to src/mainboard/asus/p2b/variants/p2b-d/devicetree.cb diff --git a/src/mainboard/asus/p2b-d/irq_tables.c b/src/mainboard/asus/p2b/variants/p2b-d/irq_tables.c similarity index 100% rename from src/mainboard/asus/p2b-d/irq_tables.c rename to src/mainboard/asus/p2b/variants/p2b-d/irq_tables.c diff --git a/src/mainboard/asus/p2b-d/mptable.c b/src/mainboard/asus/p2b/variants/p2b-d/mptable.c similarity index 100% rename from src/mainboard/asus/p2b-d/mptable.c rename to src/mainboard/asus/p2b/variants/p2b-d/mptable.c
Hello build bot (Jenkins), Patrick Georgi, Martin Roth,
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/03/39903/2
Angel Pons has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/39903 )
Patch Set 2: Code-Review+2
https://review.coreboot.org/c/coreboot/+/39903/2/src/mainboard/asus/p2b/Kcon... File src/mainboard/asus/p2b/Kconfig:
https://review.coreboot.org/c/coreboot/+/39903/2/src/mainboard/asus/p2b/Kcon... PS2, Line 16: BASE nit: BASE looks too similar to BOARD :S
Patch Set 2:
Maybe call it HAS_TWO_CPU_SLOTS ?
Hello build bot (Jenkins), Patrick Georgi, Martin Roth, Angel Pons,
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/03/39903/4
Patch Set 4:
We'll fix this later
Angel Pons has submitted this change. ( https://review.coreboot.org/c/coreboot/+/39903 )
Change-Id: I1161c726c8c752b5b1e152e1617811989631096e Signed-off-by: Keith Hui buurin@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/39903 Reviewed-by: Angel Pons th3fanbus@gmail.com Tested-by: build bot (Jenkins) no-reply@coreboot.org --- D src/mainboard/asus/p2b-d/Kconfig D src/mainboard/asus/p2b-d/Kconfig.name D src/mainboard/asus/p2b-d/romstage.c M src/mainboard/asus/p2b/Kconfig M src/mainboard/asus/p2b/Kconfig.name M src/mainboard/asus/p2b/Makefile.inc R src/mainboard/asus/p2b/variants/p2b-d/board_info.txt R src/mainboard/asus/p2b/variants/p2b-d/devicetree.cb R src/mainboard/asus/p2b/variants/p2b-d/irq_tables.c R src/mainboard/asus/p2b/variants/p2b-d/mptable.c 10 files changed, 19 insertions(+), 65 deletions(-)
