Furquan Shaikh has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/40824 )
Change subject: soc/amd/picasso: Move SPI init calls into sb_spi_init() ......................................................................
This change adds a helper sb_spi_init() that makes all the required calls for configuring SPI to ROM.
BUG=b:147758054,b:153675510 BRANCH=trembyle-bringup TEST=Verified that SPI configuration is correct for trembyle.
Signed-off-by: Furquan Shaikh furquan@google.com Change-Id: Ic5b395a8d3bdab449c24b05d1b6b8777e128b5e0 --- M src/soc/amd/picasso/southbridge.c 1 file changed, 15 insertions(+), 5 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/24/40824/1
diff --git a/src/soc/amd/picasso/southbridge.c b/src/soc/amd/picasso/southbridge.c index caf7171..c38f373 100644 --- a/src/soc/amd/picasso/southbridge.c +++ b/src/soc/amd/picasso/southbridge.c @@ -235,6 +235,20 @@ write32((void *)(base + SPI_CNTRL0), val | SPI_READ_MODE(mode)); }
+static void sb_spi_config_modes(void) +{ + sb_set_spi100(SPI_SPEED_33M, SPI_SPEED_33M, + SPI_SPEED_16M, SPI_SPEED_16M); +} + +static void sb_spi_init(void) +{ + lpc_enable_spi_prefetch(); + sb_init_spi_base(); + sb_disable_4dw_burst(); + sb_spi_config_modes(); +} + static void fch_smbus_init(void) { /* 400 kHz smbus speed. */ @@ -260,11 +274,7 @@ if (CONFIG(POST_IO) && (CONFIG_POST_IO_PORT == 0x80) && CONFIG(PICASSO_LPC_IOMUX)) lpc_enable_port80(); - lpc_enable_spi_prefetch(); - sb_init_spi_base(); - sb_disable_4dw_burst(); - sb_set_spi100(SPI_SPEED_33M, SPI_SPEED_33M, - SPI_SPEED_16M, SPI_SPEED_16M); + sb_spi_init(); enable_acpimmio_decode_pm04(); fch_smbus_init(); sb_enable_cf9_io();
Aaron Durbin has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/40824 )
Patch Set 2: Code-Review+2
Raul Rangel has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/40824 )
Patch Set 4: Code-Review+2
Furquan Shaikh has submitted this change. ( https://review.coreboot.org/c/coreboot/+/40824 )
Signed-off-by: Furquan Shaikh furquan@google.com Change-Id: Ic5b395a8d3bdab449c24b05d1b6b8777e128b5e0 Reviewed-on: https://review.coreboot.org/c/coreboot/+/40824 Reviewed-by: Raul Rangel rrangel@chromium.org Reviewed-by: Aaron Durbin adurbin@chromium.org Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/soc/amd/picasso/southbridge.c 1 file changed, 15 insertions(+), 5 deletions(-)
Approvals: build bot (Jenkins): Verified Aaron Durbin: Looks good to me, approved Raul Rangel: Looks good to me, approved
