Subrata Banik has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/45738 )
Change subject: soc/intel: Fix GRXS function to get GPIO number proper ......................................................................
This patch ensures that GRXS perform PAD_CFG0_RX_STATE mask first and then right shift PAD_CFG0_RX_STATE_BIT to get correct GPIO number.
Change-Id: I96611936f70f79e9dc5ee9414ec68cef00d0d13a Signed-off-by: Subrata Banik subrata.banik@intel.com --- M src/soc/intel/cannonlake/acpi/gpio_op.asl M src/soc/intel/icelake/acpi/gpio.asl M src/soc/intel/jasperlake/acpi/gpio_op.asl M src/soc/intel/skylake/acpi/gpio.asl M src/soc/intel/tigerlake/acpi/gpio_op.asl 5 files changed, 5 insertions(+), 5 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/38/45738/1
diff --git a/src/soc/intel/cannonlake/acpi/gpio_op.asl b/src/soc/intel/cannonlake/acpi/gpio_op.asl index 7f2a40c..98a4f24 100644 --- a/src/soc/intel/cannonlake/acpi/gpio_op.asl +++ b/src/soc/intel/cannonlake/acpi/gpio_op.asl @@ -11,7 +11,7 @@ { VAL0, 32 } - Local0 = GPIORXSTATE_MASK & (VAL0 >> GPIORXSTATE_SHIFT) + Local0 = (GPIORXSTATE_MASK & VAL0) >> GPIORXSTATE_SHIFT
Return (Local0) } diff --git a/src/soc/intel/icelake/acpi/gpio.asl b/src/soc/intel/icelake/acpi/gpio.asl index f0a6fa0..71acb75 100644 --- a/src/soc/intel/icelake/acpi/gpio.asl +++ b/src/soc/intel/icelake/acpi/gpio.asl @@ -114,7 +114,7 @@ { VAL0, 32 } - Local0 = GPIORXSTATE_MASK & (VAL0 >> GPIORXSTATE_SHIFT) + Local0 = (GPIORXSTATE_MASK & VAL0) >> GPIORXSTATE_SHIFT
Return (Local0) } diff --git a/src/soc/intel/jasperlake/acpi/gpio_op.asl b/src/soc/intel/jasperlake/acpi/gpio_op.asl index 9b9dc44..ff12da4 100644 --- a/src/soc/intel/jasperlake/acpi/gpio_op.asl +++ b/src/soc/intel/jasperlake/acpi/gpio_op.asl @@ -11,7 +11,7 @@ { VAL0, 32 } - Local0 = PAD_CFG0_RX_STATE & (VAL0 >> PAD_CFG0_RX_STATE_BIT) + Local0 = (PAD_CFG0_RX_STATE & VAL0) >> PAD_CFG0_RX_STATE_BIT
Return (Local0) } diff --git a/src/soc/intel/skylake/acpi/gpio.asl b/src/soc/intel/skylake/acpi/gpio.asl index de6ff42..f83069f 100644 --- a/src/soc/intel/skylake/acpi/gpio.asl +++ b/src/soc/intel/skylake/acpi/gpio.asl @@ -119,7 +119,7 @@ { VAL0, 32 } - Local0 = GPIORXSTATE_MASK & (VAL0 >> PAD_CFG0_RX_STATE_BIT) + Local0 = (GPIORXSTATE_MASK & VAL0) >> PAD_CFG0_RX_STATE_BIT
Return (Local0) } diff --git a/src/soc/intel/tigerlake/acpi/gpio_op.asl b/src/soc/intel/tigerlake/acpi/gpio_op.asl index 9b9dc44..ff12da4 100644 --- a/src/soc/intel/tigerlake/acpi/gpio_op.asl +++ b/src/soc/intel/tigerlake/acpi/gpio_op.asl @@ -11,7 +11,7 @@ { VAL0, 32 } - Local0 = PAD_CFG0_RX_STATE & (VAL0 >> PAD_CFG0_RX_STATE_BIT) + Local0 = (PAD_CFG0_RX_STATE & VAL0) >> PAD_CFG0_RX_STATE_BIT
Return (Local0) }
Tim Wawrzynczak has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/45738 )
Patch Set 1: Code-Review+2
https://review.coreboot.org/c/coreboot/+/45738/1//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/45738/1//COMMIT_MSG@9 PS1, Line 9: This patch ensures that GRXS perform PAD_CFG0_RX_STATE : mask first and then right shift PAD_CFG0_RX_STATE_BIT to : get correct GPIO number. 72 chars wide
Hello build bot (Jenkins), Furquan Shaikh, Tim Wawrzynczak, Angel Pons, Patrick Rudolph,
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/38/45738/2
Subrata Banik has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/45738 )
Patch Set 2:
72 chars wide
Ack
Furquan Shaikh has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/45738 )
Patch Set 2:
https://review.coreboot.org/c/coreboot/+/45738/2/src/soc/intel/cannonlake/ac... File src/soc/intel/cannonlake/acpi/gpio_op.asl:
https://review.coreboot.org/c/coreboot/+/45738/2/src/soc/intel/cannonlake/ac... PS2, Line 14: (GPIORXSTATE_MASK & VAL0) >> GPIORXSTATE_SHIFT No, this is not correct. The bug was only in TGL and JSL which are using the common code macro PAD_CFG0_RX_STATE.
GPIORXSTATE_MASK is defined differently and so what we had before here is correct.
Patch Set 2: -Code-Review
... and that's why this needs to get fixed 😄
Change subject: soc/intel/{jsl,tgl}: Fix GRXS function to get GPIO number proper ......................................................................
Change-Id: I96611936f70f79e9dc5ee9414ec68cef00d0d13a Signed-off-by: Subrata Banik subrata.banik@intel.com --- M src/soc/intel/jasperlake/acpi/gpio_op.asl M src/soc/intel/tigerlake/acpi/gpio_op.asl 2 files changed, 2 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/38/45738/3
Patch Set 3: Code-Review+2
Patch Set 3:
No, this is not correct. […]
looks like i got carried away 🙏
Angel Pons has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/45738 )
Subrata Banik has submitted this change. ( https://review.coreboot.org/c/coreboot/+/45738 )
Change-Id: I96611936f70f79e9dc5ee9414ec68cef00d0d13a Signed-off-by: Subrata Banik subrata.banik@intel.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/45738 Reviewed-by: Furquan Shaikh furquan@google.com Reviewed-by: Angel Pons th3fanbus@gmail.com Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/soc/intel/jasperlake/acpi/gpio_op.asl M src/soc/intel/tigerlake/acpi/gpio_op.asl 2 files changed, 2 insertions(+), 2 deletions(-)
Approvals: build bot (Jenkins): Verified Furquan Shaikh: Looks good to me, approved Angel Pons: Looks good to me, approved
Return (Local0) }
