Attention is currently required from: Angel Pons, Nicholas Chin, Václav Straka.
Hello Nicholas Chin, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/85825?usp=email
The following approvals got outdated and were removed: Code-Review+1 by Nicholas Chin, Verified+1 by build bot (Jenkins)
Change subject: mb/hp: Add Pro 3400 ......................................................................
mb/hp: Add Pro 3400
Based on autoport and HP Pro 3500. As part of this change renamed 3500 to 3x00 and added this as it's variant.
It's an almost identical board to the 3500 but has a smaller flash.
Other differences between boards were identified by autoport. They may or may not important but were included anyway.
Tested on HP Pro 3400, behaves exactly as 3500 described in the docs. Changes were not significant enough to require retesting on 3500.
Change-Id: I833996f6eddcaac91fb0ad0cd95fcc2a99447387 Signed-off-by: Vesek venda.straka@gmail.com --- M Documentation/mainboard/hp/pro_3500_series.md M Documentation/mainboard/index.md D src/mainboard/hp/pro_3500_series/Kconfig A src/mainboard/hp/pro_3x00_series/Kconfig R src/mainboard/hp/pro_3x00_series/Kconfig.name R src/mainboard/hp/pro_3x00_series/Makefile.mk R src/mainboard/hp/pro_3x00_series/acpi/ec.asl R src/mainboard/hp/pro_3x00_series/acpi/platform.asl R src/mainboard/hp/pro_3x00_series/acpi/superio.asl R src/mainboard/hp/pro_3x00_series/acpi_tables.c A src/mainboard/hp/pro_3x00_series/board_info.txt A src/mainboard/hp/pro_3x00_series/cmos.default A src/mainboard/hp/pro_3x00_series/cmos.layout R src/mainboard/hp/pro_3x00_series/common_defines.h R src/mainboard/hp/pro_3x00_series/devicetree.cb R src/mainboard/hp/pro_3x00_series/dsdt.asl R src/mainboard/hp/pro_3x00_series/early_init.c R src/mainboard/hp/pro_3x00_series/gma-mainboard.ads R src/mainboard/hp/pro_3x00_series/hda_verb.c R src/mainboard/hp/pro_3x00_series/led.c R src/mainboard/hp/pro_3x00_series/led.h R src/mainboard/hp/pro_3x00_series/mainboard.c R src/mainboard/hp/pro_3x00_series/smihandler.c C src/mainboard/hp/pro_3x00_series/variants/pro_3400_series/board_info.txt A src/mainboard/hp/pro_3x00_series/variants/pro_3400_series/data.vbt A src/mainboard/hp/pro_3x00_series/variants/pro_3400_series/gpio.c A src/mainboard/hp/pro_3x00_series/variants/pro_3400_series/overridetree.cb R src/mainboard/hp/pro_3x00_series/variants/pro_3500_series/board_info.txt R src/mainboard/hp/pro_3x00_series/variants/pro_3500_series/data.vbt R src/mainboard/hp/pro_3x00_series/variants/pro_3500_series/gpio.c A src/mainboard/hp/pro_3x00_series/variants/pro_3500_series/overridetree.cb 31 files changed, 426 insertions(+), 96 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/25/85825/11
