Hello Aaron Durbin, Patrick Rudolph, Paul Menzel, build bot (Jenkins), Patrick Georgi, Martin Roth,
https://review.coreboot.org/c/coreboot/+/26926
to look at the new patch set (#43).
Change subject: nb/intel/haswell: Add an option for where verstage starts ......................................................................
Previously Haswell used a romcc bootblock and starting verstage in romstage was madatory but with C_ENVIRONMENT_BOOTBLOCK it is also possible to have a separate verstage.
This selects using a separate verstage by default but still keeps the option around to use verstage in romstage.
Also make sure mrc.bin is only added to the COREBOOT fmap region as it requires to be run at a specific offset. This means that coreboot will have to jump from a RW region to the RO region for that binary and back to that RW region after that binary is done initializing the memory.
Change-Id: I3b7b29f4a24c0fb830ff76fe31a35b6afcae4e67 Signed-off-by: Arthur Heymans arthur@aheymans.xyz --- M src/cpu/intel/haswell/Makefile.inc M src/mainboard/google/beltino/Makefile.inc M src/mainboard/intel/baskingridge/Makefile.inc M src/northbridge/intel/haswell/Kconfig M src/southbridge/intel/common/Makefile.inc M src/southbridge/intel/lynxpoint/Makefile.inc M src/southbridge/intel/lynxpoint/pmutil.c 7 files changed, 36 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/26/26926/43
