Timothy Pearson (tpearson@raptorengineeringinc.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/13522
commit 77b5b0aba7e7baba6b1be7628e539293950ebfd5 Author: Timothy Pearson tpearson@raptorengineeringinc.com Date: Tue Nov 24 14:12:08 2015 -0600
mainboard/asus/kcma-d8: Initial modification for KCMA-D8 name strings
Change-Id: I841965279fae202894c31663b41610c5f069e125 Signed-off-by: Timothy Pearson tpearson@raptorengineeringinc.com --- src/mainboard/asus/kcma-d8/Kconfig | 18 +++++++++--------- src/mainboard/asus/kcma-d8/Kconfig.name | 4 ++-- src/mainboard/asus/kcma-d8/abuild.disabled | 2 -- src/mainboard/asus/kcma-d8/mainboard.c | 2 +- src/mainboard/asus/kcma-d8/romstage.c | 24 +++++------------------- src/mainboard/asus/kgpe-d16/abuild.disabled | 2 -- 6 files changed, 17 insertions(+), 35 deletions(-)
diff --git a/src/mainboard/asus/kcma-d8/Kconfig b/src/mainboard/asus/kcma-d8/Kconfig index 23c91f0..3c8cdcd 100644 --- a/src/mainboard/asus/kcma-d8/Kconfig +++ b/src/mainboard/asus/kcma-d8/Kconfig @@ -1,8 +1,8 @@ -if BOARD_ASUS_KGPE_D16 +if BOARD_ASUS_KCMA_D8
config BOARD_SPECIFIC_OPTIONS # dummy def_bool y - select CPU_AMD_SOCKET_G34_NON_AGESA + select CPU_AMD_SOCKET_C32_NON_AGESA select DIMM_DDR3 select DIMM_REGISTERED # select QRANK_DIMM_SUPPORT @@ -37,11 +37,11 @@ config BOARD_SPECIFIC_OPTIONS # dummy
config MAINBOARD_DIR string - default "asus/kgpe-d16" + default "asus/kcma-d8"
config BOOTBLOCK_MAINBOARD_INIT string - default "mainboard/asus/kgpe-d16/bootblock.c" + default "mainboard/asus/kcma-d8/bootblock.c"
config DCACHE_RAM_BASE hex @@ -57,7 +57,7 @@ config APIC_ID_OFFSET
config MAINBOARD_PART_NUMBER string - default "KGPE-D16" + default "KCMA-D8"
config HW_MEM_HOLE_SIZEK hex @@ -65,12 +65,12 @@ config HW_MEM_HOLE_SIZEK
config MAX_CPUS int - default 32 + default 16
-# 2 (internal) processors per G34 socket +# 1 (internal) processor per C32 socket config MAX_PHYSICAL_CPUS int - default 4 + default 2
config HT_CHAIN_UNITID_BASE hex @@ -100,4 +100,4 @@ config MAX_REBOOT_CNT int default 10
-endif # BOARD_ASUS_KGPE_D16 +endif # BOARD_ASUS_KCMA_D8 diff --git a/src/mainboard/asus/kcma-d8/Kconfig.name b/src/mainboard/asus/kcma-d8/Kconfig.name index bdfa31a..69b63ea 100644 --- a/src/mainboard/asus/kcma-d8/Kconfig.name +++ b/src/mainboard/asus/kcma-d8/Kconfig.name @@ -1,2 +1,2 @@ -config BOARD_ASUS_KGPE_D16 - bool "KGPE-D16" +config BOARD_ASUS_KCMA_D8 + bool "KCMA-D8" diff --git a/src/mainboard/asus/kcma-d8/abuild.disabled b/src/mainboard/asus/kcma-d8/abuild.disabled deleted file mode 100644 index 5003c92..0000000 --- a/src/mainboard/asus/kcma-d8/abuild.disabled +++ /dev/null @@ -1,2 +0,0 @@ -Build disabled until name string update in subsequent patch -Required as Jenkins will prevent merge if the direct copy is built diff --git a/src/mainboard/asus/kcma-d8/mainboard.c b/src/mainboard/asus/kcma-d8/mainboard.c index 65029d4..0219ee6 100644 --- a/src/mainboard/asus/kcma-d8/mainboard.c +++ b/src/mainboard/asus/kcma-d8/mainboard.c @@ -52,7 +52,7 @@ void set_pcie_dereset(void) *************************************************/ static void mainboard_enable(device_t dev) { - printk(BIOS_INFO, "Mainboard KGPE-D16 Enable. dev=0x%p\n", dev); + printk(BIOS_INFO, "Mainboard KCMA-D8 initializing, dev=0x%p\n", dev);
msr_t msr, msr2;
diff --git a/src/mainboard/asus/kcma-d8/romstage.c b/src/mainboard/asus/kcma-d8/romstage.c index 1904bc2..4210a92 100644 --- a/src/mainboard/asus/kcma-d8/romstage.c +++ b/src/mainboard/asus/kcma-d8/romstage.c @@ -1,7 +1,7 @@ /* * This file is part of the coreboot project. * - * Copyright (C) 2015 Timothy Pearson tpearson@raptorengineeringinc.com, Raptor Engineering + * Copyright (C) 2015 Raptor Engineering * * Copyright (C) 2007 AMD * Written by Yinghai Lu yinghailu@amd.com for AMD. @@ -67,7 +67,7 @@ static inline int spd_read_byte(unsigned device, unsigned address) #include "northbridge/amd/amdfam10/early_ht.c"
/* - * ASUS KGPE-D16 specific SPD enable/disable magic. + * ASUS KCMA-D8 specific SPD enable/disable magic. * * Setting SP5100 GPIOs 59 and 60 controls an SPI mux with four settings: * 0: Disabled @@ -116,22 +116,8 @@ static const uint8_t spd_addr_fam10[] = { };
static void activate_spd_rom(const struct mem_controller *ctrl) { - struct sys_info *sysinfo = &sysinfo_car; - + /* Nothing needs to be done as there is no SPD mux on this board */ printk(BIOS_DEBUG, "activate_spd_rom() for node %02x\n", ctrl->node_id); - if (ctrl->node_id == 0) { - printk(BIOS_DEBUG, "enable_spd_node0()\n"); - switch_spd_mux(0x2); - } else if (ctrl->node_id == 1) { - printk(BIOS_DEBUG, "enable_spd_node1()\n"); - switch_spd_mux((is_fam15h() || (sysinfo->nodes <= 2))?0x2:0x3); - } else if (ctrl->node_id == 2) { - printk(BIOS_DEBUG, "enable_spd_node2()\n"); - switch_spd_mux((is_fam15h() || (sysinfo->nodes <= 2))?0x3:0x2); - } else if (ctrl->node_id == 3) { - printk(BIOS_DEBUG, "enable_spd_node3()\n"); - switch_spd_mux(0x3); - } }
/* Voltages are specified by index @@ -414,8 +400,8 @@ void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) enable_sr5650_dev8(); sb7xx_51xx_lpc_init();
- if (CONFIG_MAX_PHYSICAL_CPUS != 4) - printk(BIOS_WARNING, "CONFIG_MAX_PHYSICAL_CPUS is %d, but this is a dual socket AMD G34 board!\n", CONFIG_MAX_PHYSICAL_CPUS); + if (CONFIG_MAX_PHYSICAL_CPUS != 2) + printk(BIOS_WARNING, "CONFIG_MAX_PHYSICAL_CPUS is %d, but this is a dual socket AMD C32 board!\n", CONFIG_MAX_PHYSICAL_CPUS);
/* Halt if there was a built in self test failure */ report_bist_failure(bist); diff --git a/src/mainboard/asus/kgpe-d16/abuild.disabled b/src/mainboard/asus/kgpe-d16/abuild.disabled deleted file mode 100644 index 5003c92..0000000 --- a/src/mainboard/asus/kgpe-d16/abuild.disabled +++ /dev/null @@ -1,2 +0,0 @@ -Build disabled until name string update in subsequent patch -Required as Jenkins will prevent merge if the direct copy is built
