Michał Żygowski has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/39699 )
Change subject: drivers/pc80/tpm/tis.c: change the _HID and _CID for TPM2 device ......................................................................
According TCG PC Client Platform Firmware Profile Specification Revision 1.04 Chapter 8.1 the TPM device object should have the _CID and _HID value set to MSFT0101 for TPM2.
FreeBSD also detects TPM2 device only MSFT0101 _HID and _CID only.
TEST=boot FreeBSD 12.1 on PC Engines apu2 and check in dmesg that TPM2.0 is detected
Signed-off-by: Michał Żygowski michal.zygowski@3mdeb.com Change-Id: I45123f272038e664b834cabd9d8525baca0eb583 --- M src/drivers/pc80/tpm/tis.c 1 file changed, 9 insertions(+), 4 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/99/39699/1
diff --git a/src/drivers/pc80/tpm/tis.c b/src/drivers/pc80/tpm/tis.c index a35ef83..0c8e9c3 100644 --- a/src/drivers/pc80/tpm/tis.c +++ b/src/drivers/pc80/tpm/tis.c @@ -896,11 +896,16 @@ acpigen_write_scope(path); acpigen_write_device(acpi_device_name(dev));
- acpigen_write_name("_HID"); - acpigen_emit_eisaid("PNP0C31"); + if (CONFIG(TPM2)) { + acpigen_write_name_string("_HID", "MSFT0101"); + acpigen_write_name_string("_CID", "MSFT0101"); + } else { + acpigen_write_name("_HID"); + acpigen_emit_eisaid("PNP0C31");
- acpigen_write_name("_CID"); - acpigen_emit_eisaid("PNP0C31"); + acpigen_write_name("_CID"); + acpigen_emit_eisaid("PNP0C31"); + }
acpi_device_write_uid(dev);
Patrick Rudolph has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/39699 )
Patch Set 1:
https://review.coreboot.org/c/coreboot/+/39699/1/src/drivers/pc80/tpm/tis.c File src/drivers/pc80/tpm/tis.c:
https://review.coreboot.org/c/coreboot/+/39699/1/src/drivers/pc80/tpm/tis.c@... PS1, Line 900: acpigen_write_name_string("_HID", "MSFT0101"); the TPM spec says that either _HID or _CID must be MSFT0101. I'd set _CID to MSFT0101 and _HID to PNP0C31.
Michał Żygowski has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/39699 )
Patch Set 1:
the TPM spec says that either _HID or _CID must be MSFT0101. […]
Hmm, maybe you are looking on an outdated spec:
``` 8.1 ACPI Device Object for TPM A TPM device object MUST contain a. a _HID object with a value that is formatted according to the ACPI Specification and contains the manufacturer ID of the TPM vendor and a unique identifier and is in the format “AAA####” or “NNNN####”, and b. a _CID object with the value of “MSFT0101” or evaluate to a package where the 2515 value “MSFT0101” is one of the IDs within the package, or c. A TPM device object MUST contain a _HID object with the value of “MSFT0101” ```
Point b says CID must be MSFT0101. Point c says HID must be MSFT0101
Patch Set 1:
Hmm, maybe you are looking on an outdated spec: […]
The detail here is the ", or" at the end of b. So as long as either b. or c. is implemented the condition is true IMHO.
Patch Set 1:
The detail here is the ", or" at the end of b. […]
Right, I missed that or and assumed all 3 conditions must be met. Will test with MSFT0101 CID only.
Patch Set 1:
Tested following configurations: HID and CID MSFT0101 - Linux and FreeBSD 12.1 works well HID PNP0C31, CID MSFT0101 - Linux works well, FreeBSD 12.1 does not work (not probed as TPM 2.0) HID MSFT0101, CID PNP0C31 - it doesn't work anywhere HID and CID PNP0C31 - Linux works well, FreeBSD 12.1 does not work (not probed as TPM 2.0)
I guess the only option is to go with both HID and CID MSFT0101.
Hello Philipp Deppenwiese, build bot (Jenkins),
According TCG PC Client Platform Firmware Profile Specification Revision 1.04 Chapter 8.1 the TPM device object should have the _CID and _HID values set to MSFT0101 for TPM2.
FreeBSD also detects TPM2 device using MSFT0101 _HID and _CID only.
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/99/39699/2
Patch Set 3: Code-Review+1
Tested following configurations: […]
Does it still work on Windows10?
Patch Set 3:
Unfortunately I have no way to test on Windows 10.
Patch Set 3: Code-Review+2
Patch Set 3:
Ack
Philipp Deppenwiese has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/39699 )
Angel Pons has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/39699 )
Ack
If a thing with "MSFT" on its name isn't working on Windows, I think it's not our problem :^)
Michał Żygowski has submitted this change. ( https://review.coreboot.org/c/coreboot/+/39699 )
Signed-off-by: Michał Żygowski michal.zygowski@3mdeb.com Change-Id: I45123f272038e664b834cabd9d8525baca0eb583 Reviewed-on: https://review.coreboot.org/c/coreboot/+/39699 Reviewed-by: Patrick Rudolph siro@das-labor.org Reviewed-by: Philipp Deppenwiese zaolin.daisuki@gmail.com Reviewed-by: Angel Pons th3fanbus@gmail.com Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/drivers/pc80/tpm/tis.c 1 file changed, 9 insertions(+), 4 deletions(-)
Approvals: build bot (Jenkins): Verified Philipp Deppenwiese: Looks good to me, approved Patrick Rudolph: Looks good to me, approved Angel Pons: Looks good to me, approved
diff --git a/src/drivers/pc80/tpm/tis.c b/src/drivers/pc80/tpm/tis.c index 98d31c0..1081410 100644 --- a/src/drivers/pc80/tpm/tis.c +++ b/src/drivers/pc80/tpm/tis.c @@ -886,11 +886,16 @@ acpigen_write_scope(path); acpigen_write_device(acpi_device_name(dev));
9elements QA has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/39699 )
Patch Set 4:
Automatic boot test returned (PASS/FAIL/TOTAL): 3/0/3 Emulation targets: EMULATION_QEMU_X86_Q35 using payload TianoCore : SUCCESS : https://lava.9esec.io/r/2154 EMULATION_QEMU_X86_Q35 using payload SeaBIOS : SUCCESS : https://lava.9esec.io/r/2153 EMULATION_QEMU_X86_I440FX using payload SeaBIOS : SUCCESS : https://lava.9esec.io/r/2152
