Arthur Heymans (arthur@aheymans.xyz) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/17998
commit afe06d625acfb89f96e342bc7ce9d5218d7c8466 Author: Arthur Heymans arthur@aheymans.xyz Date: Fri Dec 30 21:07:18 2016 +0100
nb/intel/x4x: Implement resume from S3 suspend
It rewrites the results of receive enable stored in the first 256 bits of the upper nvram region, to avoid running receive enable again.
Change-Id: Ib54bc5c7b0fed6d975ffc31f037b5179d9e5600b Signed-off-by: Arthur Heymans arthur@aheymans.xyz --- src/mainboard/gigabyte/ga-g41m-es2l/Kconfig | 1 + src/mainboard/gigabyte/ga-g41m-es2l/romstage.c | 7 +++-- src/northbridge/intel/x4x/pcie.c | 15 +++++++-- src/northbridge/intel/x4x/raminit_ddr2.c | 43 +++++++++++++++++++------- src/northbridge/intel/x4x/x4x.h | 2 +- 5 files changed, 51 insertions(+), 17 deletions(-)
diff --git a/src/mainboard/gigabyte/ga-g41m-es2l/Kconfig b/src/mainboard/gigabyte/ga-g41m-es2l/Kconfig index 3d2a892..ae57e5b 100644 --- a/src/mainboard/gigabyte/ga-g41m-es2l/Kconfig +++ b/src/mainboard/gigabyte/ga-g41m-es2l/Kconfig @@ -33,6 +33,7 @@ config BOARD_SPECIFIC_OPTIONS select REALTEK_8168_RESET select HAVE_OPTION_TABLE select HAVE_CMOS_DEFAULT + select HAVE_ACPI_RESUME
config MMCONF_BASE_ADDRESS hex diff --git a/src/mainboard/gigabyte/ga-g41m-es2l/romstage.c b/src/mainboard/gigabyte/ga-g41m-es2l/romstage.c index 2302842..f51f3a8 100644 --- a/src/mainboard/gigabyte/ga-g41m-es2l/romstage.c +++ b/src/mainboard/gigabyte/ga-g41m-es2l/romstage.c @@ -138,6 +138,7 @@ void mainboard_romstage_entry(unsigned long bist) // ch0 ch1 const u8 spd_addrmap[4] = { 0x50, 0, 0x52, 0 }; u8 boot_path = 0; + u8 s3_resume;
/* Disable watchdog timer */ RCBA32(0x3410) = RCBA32(0x3410) | 0x20; @@ -157,16 +158,18 @@ void mainboard_romstage_entry(unsigned long bist)
x4x_early_init();
+ s3_resume = southbridge_detect_s3_resume(); + if (s3_resume) + boot_path = BOOT_PATH_RESUME; if (MCHBAR32(PMSTS_MCHBAR) & PMSTS_WARM_RESET) boot_path = BOOT_PATH_RESET;
printk(BIOS_DEBUG, "Initializing memory\n"); sdram_initialize(boot_path, spd_addrmap); quick_ram_check(); - cbmem_initialize_empty(); printk(BIOS_DEBUG, "Memory initialized\n");
- x4x_late_init(); + x4x_late_init(s3_resume);
printk(BIOS_DEBUG, "x4x late init complete\n");
diff --git a/src/northbridge/intel/x4x/pcie.c b/src/northbridge/intel/x4x/pcie.c index f03869e..648f10d 100644 --- a/src/northbridge/intel/x4x/pcie.c +++ b/src/northbridge/intel/x4x/pcie.c @@ -18,10 +18,11 @@ #include <stddef.h> #include <string.h> #include <arch/io.h> +#include <cbmem.h> #include <device/pci_def.h> #include <device/pnp_def.h> #include <console/console.h> - +#include <romstage_handoff.h> #include "iomap.h" #include "x4x.h"
@@ -184,8 +185,18 @@ static void init_dmi(void) reg16 = DMIBAR16(0x88); }
-void x4x_late_init(void) +static void x4x_prepare_resume(int s3resume) +{ + int cbmem_was_initted; + + cbmem_was_initted = !cbmem_recovery(s3resume); + + romstage_handoff_init(cbmem_was_initted && s3resume); +} + +void x4x_late_init(int s3resume) { init_egress(); init_dmi(); + x4x_prepare_resume(s3resume); } diff --git a/src/northbridge/intel/x4x/raminit_ddr2.c b/src/northbridge/intel/x4x/raminit_ddr2.c index ef21cb8..819b5a2 100644 --- a/src/northbridge/intel/x4x/raminit_ddr2.c +++ b/src/northbridge/intel/x4x/raminit_ddr2.c @@ -262,6 +262,16 @@ static void checkreset_ddr2(struct sysinfo *s) u8 pmcon2; u8 reset = 0; u32 pmir; + u32 pmsts = MCHBAR32(PMSTS_MCHBAR); + + if (s->boot_path >= 1) { + if !(pmsts & 1) + printk(BIOS_DEBUG, + "Channel 0 possibly not in self refresh\n"); + if !(pmsts & 2) + printk(BIOS_DEBUG, + "Channel 1 possibly not in self refresh\n"); + }
pmir = pci_read_config32(PCI_DEV(0, 0x1f, 0), 0xac); pmcon2 = pci_read_config8(PCI_DEV(0, 0x1f, 0), 0xa2); @@ -1560,7 +1570,8 @@ static void sdram_program_receive_enable(struct sysinfo *s) RCBA32(0x3400) = (1 << 2);
/* Program Receive Enable Timings */ - if (s->boot_path == BOOT_PATH_RESET) { + if ((s->boot_path == BOOT_PATH_RESET) + || (s->boot_path == BOOT_PATH_RESUME)) { sdram_recover_receive_enable(); } else { rcven_ddr2(s); @@ -2048,7 +2059,8 @@ void raminit_ddr2(struct sysinfo *s) printk(BIOS_DEBUG, "Done pre-jedec\n");
// JEDEC reset - jedec_ddr2(s); + if (s->boot_path == BOOT_PATH_NORMAL) + jedec_ddr2(s);
printk(BIOS_DEBUG, "Done jedec steps\n");
@@ -2095,16 +2107,23 @@ void raminit_ddr2(struct sysinfo *s) MCHBAR8(0x5dc) = MCHBAR8(0x5dc) | 0x80;
// Dummy writes / reads - volatile u32 data; - FOR_EACH_POPULATED_RANK(s->dimms, ch, r) { - for (bank = 0; bank < 4; bank++) { - reg32 = (ch << 29) | (r*0x8000000) | (bank << 12); - write32((u32 *)reg32, 0xffffffff); - data = read32((u32 *)reg32); - printk(BIOS_DEBUG, "Wrote ones, Read: [0x%08x]=0x%08x\n", reg32, data); - write32((u32 *)reg32, 0x00000000); - data = read32((u32 *)reg32); - printk(BIOS_DEBUG, "Wrote zeros, Read: [0x%08x]=0x%08x\n", reg32, data); + if (s->boot_path == BOOT_PATH_NORMAL) { + volatile u32 data; + FOR_EACH_POPULATED_RANK(s->dimms, ch, r) { + for (bank = 0; bank < 4; bank++) { + reg32 = (ch << 29) | (r*0x8000000) | + (bank << 12); + write32((u32 *)reg32, 0xffffffff); + data = read32((u32 *)reg32); + printk(BIOS_DEBUG, "Wrote ones"); + printk(BIOS_DEBUG, "Read: [0x%08x]=0x%08x\n", + reg32, data); + write32((u32 *)reg32, 0x00000000); + data = read32((u32 *)reg32); + printk(BIOS_DEBUG, "Wrote zeros"); + printk(BIOS_DEBUG, "Read: [0x%08x]=0x%08x\n", + reg32, data); + } } } printk(BIOS_DEBUG, "Done dummy reads\n"); diff --git a/src/northbridge/intel/x4x/x4x.h b/src/northbridge/intel/x4x/x4x.h index 1823b8c..25d4022 100644 --- a/src/northbridge/intel/x4x/x4x.h +++ b/src/northbridge/intel/x4x/x4x.h @@ -322,7 +322,7 @@ enum ddr2_signals {
#ifndef __BOOTBLOCK__ void x4x_early_init(void); -void x4x_late_init(void); +void x4x_late_init(int s3resume); u32 decode_igd_memory_size(u32 gms); u32 decode_igd_gtt_size(u32 gsm); u8 decode_pciebar(u32 *const base, u32 *const len);
